Old 07-22-2019, 09:01 PM   #1
E350 vs e450 4 window bus?
Just wanted to see what would be better for a skoolie I found a nice e350 7.3 powerstroke thomas.
I want to convert it and maybe have it hold 40 gallons of water. And be capable of towing a small car?
Can I do this? or will I need to find a e450 7.3 powerstroke
Thanks for the help
Bpjr07 is offline   Reply With Quote
Old 07-22-2019, 10:38 PM   #2
From what I've read, it really depends on the specific chassis. Ford made small tweaks, changes, and adjustments to the different models over the years - which makes it hard to say outright that the 450 would be a better choice.
The big practical differences I believe are the rear end ratio, the spring package, and the breaks (which effect the GCVW.) It should be doable.
Old 07-23-2019, 10:04 AM   #3
roach711's Avatar
Rated Cap: 19
The E350 will have a lower gross weight rating than the 450. Usually the 350 has a 4.10 rear end ratio and the 450 has a 4.56. Some 350's come with single rear wheels. The RV folks claim that the 4.56 rear end ratio is better for towing.
My E450 has a 14,000lb gross weight rating and as converted our actual loaded weight is right at 12,000lbs.
The Roach Motel
Old 07-23-2019, 01:17 PM   #4
I noticed that most 4 windows are e350 unless it has a wheelchair lift.
I should be ok with the e350 especially getting a bit better milage.. should be fine towing a 3000 pound car on a dolley.
Old 07-23-2019, 02:12 PM   #5
Sleddgracer's Avatar
Chassis: still looking for my bus
somehow, I always seem to exceed suggested GVWR's, no matter what I'm driving - lol - ( that's why they make air bags and air shocks and after market springs ) - for something like a skoolie I'd be concerned that the 350 series was going to be able to do the job - it would be running at or near max 24/7
Old 07-23-2019, 02:37 PM   #6
Yes but with same engine, tranny and chassis on 19ft I am a firm believer of air bags too,might set them up if I need to. Having taller gears to give me better mpgis more of a plus.
Only plan on towing 1-2 times a year...would not mind taking it easy those times and have a tranny guage,
How would a cop catch me if I'm over? Do we need to stop at scales?
Old 07-23-2019, 02:54 PM   #7
no, but during a DOT road check they could and likely would check your weight
Old 07-23-2019, 03:02 PM   #8
will need to check that guess I'll keep in mind to build it light. Only making it a weekend camper not to live in. Was planing kn using steel studs for bed frame and bathroom walls that can be up to 4 times lighter
