Old 06-09-2017, 06:43 PM   #491
ive noticed some newer IC busses that what looks like the exact same wheelchair door.. wonder if getting the VIN on a newer bus would help,
Paul's equiupment in ohio sometimes has quite a few scrapped out school busses..
Old 06-10-2017, 12:21 AM   #492
Originally Posted by 1olfart View Post
I don't recall where you are on your w/c door, but I did get over to a place that I passed on Interstate 10, East of Houston. They told me that they did deal in parts, as well as busses, and gave me a business card. Their site is
usedschoolbusesonline.com Phone # 855-607-6559
Also went by interstatebus@gmail.com AND interstatebusrentals.com
They weren't too chatty, with me, but I mentioned you had a AmTram and might need a w/c door. They needed the size, which I didn't know, so they said to check the website.
Good luck
Thanks I'll try them monday. I REALLY NEED THAT WC DOOR SEAL!
Roll Your Own Build Thread
Old 06-10-2017, 12:23 AM   #493
Thanks! ANY leads appreciated.
I've tried looking on the web for IC, AmTran, Ward, and had no luck. I hate calling places. IDK why but I just do. Guess I need to make more calls. I'm getting to that point of NEEDING these few parts and its holding me up a bit.
Old 06-10-2017, 08:24 AM   #494
I cut the rust hole out of the back, and the entire inside behind it was completely crumbling with rust.
Old 06-10-2017, 09:00 AM   #495
wow what a pain that is.. looks like that back window mustve leaked for awhile.. my carpenter bus the back windows are sloped just a little and water always runs down along those windows... not sure why they built busses that way but ive seen a lot..
Old 06-10-2017, 09:04 AM   #496
Yup, you're correct. It was the back window leaking, as well as the tail light.
The fiberglass that came out was MOLDY too.
Old 06-10-2017, 12:48 PM   #497
You may check to see if you can get a complete door, with seal. Not the cheapest way, but might be 'the way'
1olfart is offline   Reply With Quote
Old 06-10-2017, 03:30 PM   #498
IDK where I'd find that.
The few I've found online don't have the seal the door is hundreds and hundreds of dollars.
Old 06-10-2017, 06:22 PM   #499
CaptSquid's Avatar
Chassis: HDX
Engine: Cat C7
Rated Cap: 84 passenger
That's some NASTY cancer there.
Old 06-10-2017, 10:48 PM   #500
Everything in that rear wall under the window that wasn't galvanized rusted completely away. GONE!
The rest of the bus is virtually rust free. only the WC door and service door have any real rust otherwise.
