Old 06-13-2017, 03:59 PM   #531
Here's the cross section of the seal, and the channel in the door edge it fits into.
Here's how it fits onto the door
Roll Your Own Build Thread
Old 06-13-2017, 04:19 PM   #532
Chassis: B3800 Short bus
Ewww
It does look like there's a lip on the door frame that could take some standard d-shaped weather stripping. Assuming the lip is wide enough to engage the door...
Old 06-13-2017, 04:33 PM   #533
Yeah, then I'd just need to weld the edges of the door closed so they don't have that silly wide channel exposed all around the door when its shut.
Old 06-13-2017, 04:37 PM   #534
OR clean rust, prep.... Bondo! Those edges could be made oh so smooth..
Old 06-13-2017, 04:37 PM   #535
Mind you, that'd be a couple tins of Bondo to fill all that gap..
Old 06-13-2017, 04:42 PM   #536
IDk, but I gotta figure something out this is silly.
Old 06-13-2017, 04:48 PM   #537
oricha1984's Avatar
Engine: gasser probably
Maybe you can just get rid of the door and weld a sheet of metal or the door itself.
Sent from my BLU LIFE ONE X using Tapatalk
oricha1984 is offline   Reply With Quote
Old 06-13-2017, 05:08 PM   #538
Tootalltechie's Avatar
Year: 1974
Chassis: CHEVROLET C60 just under 19700 lbs body#B10353
Engine: 350 ci on propane
Rated Cap: 48
That seal looks great for holding moisture in the groove.
Could you use a cut off wheel to remove the channel and then use a large stick on "D" seal and a stick on flat seal? 2 seals to work as 1
Tootalltechie is offline   Reply With Quote
Old 06-13-2017, 05:14 PM   #539
But its the biggest, best door on the bus!
Old 06-13-2017, 06:30 PM   #540
Robin97396's Avatar
I say it's worth keeping the door. Weld on a few patches, smooth it up and paint it tiffany like the rest.
Robin
Nobody's Business
