01-08-2021, 12:32 PM
#221
Year: 98
Yesterday was a sunny day with still some snow on the ground.
The front door post was about 1/4 low but with a jack I was able to " straighten " that out. Now on to replacing the windshield.
Johan
01-11-2021, 06:00 PM
#222
Year: 98
Still not happy with the straightness and strength of the passenger side a frame pillar. I will make an extra vertical column from the top of the A frame pillar to old door rocker panel.
Did some more tweaking and unbending and started putting self tappers in to keep all the pieces in place.
Found a couple of " vintage" marker lights with aluminum frame. Hope that will be able to take the bearing of branches better then the current cute cat eyes.
Wire brushed the corrosion of it.
01-12-2021, 07:05 PM
#223
Year: 98
In both our van buses I have found leaks around the windshield and that both buses did not have the original windshield.
I noticed that the passenger A pillar is not supported very well and I wonder if that could be a reason that the stresses on the windshield are higher then normal.
To make our 4*4 bus a bit better I decided to make a vertical post from the top of the A pillar to the top side of the rocker panel. Now I can use a 1*12 plank or better plywood to connect the door post and A pillar support together in a much stronger fashion.
Also cleaned up the RV door frame and installed a rain gutter above the door.
01-12-2021, 07:18 PM
#224
Makes me wonder if taking out the passenger door and not having a factory body pillar at the back of the cab causes a vibration that weakens the A Pillar over time .
01-15-2021, 02:03 PM
#225
Year: 98
Hi Chris, that is what I think. Will find out soon enough if the windshield cracks after driving thru a pothole .
01-21-2021, 03:32 PM
#226
Year: 98
It looks like our bus again. A last push against the back and the windshield is glued in.
Tomorrow some more RV door work.
Johan
01-21-2021, 03:42 PM
#227
Coachwork: Bluebird, Collins
Following the rebuild has been inspiring. Windshields can be tricky from my limited experience. If it’s a used windshield or even a new windshield there can be tiny unnoticeable micro chips or imperfections that might cause a crack. The installer can cause them. Or whomever removed the windshield.
01-21-2021, 06:15 PM
#228
Year: 2009
Coachwork: Girardin
Engine: 6.6 turbo diesel
Rated Cap: ?
Pretty freakin amazing that you can do all of this. In AWE!!!
01-21-2021, 10:15 PM
#229
Year: 98
Sorry buster, can't take credit.. I had a professional install the window.. I wanted someone that could tell me if the frame fitted properly after me straightening with a forklift. Also there is a lot of specialized skill , tools and experience to installing a windshield..
These guys cut the remaining glue out, cleaned it, primed and then with a super consistent hand put an even bead along the frame..amazing to watch these guys work.
03-12-2021, 05:05 PM
#230
Year: 98
The better weather is here and in between other projects I have worked a little on Elfie.
The back door was racked so I took the window out and used hydraulics and a hammer to get it in a better shape.
Wanted to take a closer look at the last aluminum crossmember and had to take the rear bumper of to get a clear view.
Going to install a class 5 rear hitch behind the bumper.
Also working on 19.5" rims. The goal is to mount 265/70-R19.5 tires so that the load rating is much higher then the gvwr of the bus and also to have the same size as on our larger bus Dory.
03-14-2021, 03:00 PM
#231
Year: 98
Since most of the interior had to come out to straighten the body we decided to change the layout and get a shower/ bathroom... This bus is setup for 2 adults and 2 kids. Two dogs are crammed in there as well.
So I changed the driver to a swivel with quick remove so that it is easier to work on the engine with the doghouse of.
The forward looking seat moved on space up to make space for the shower. The backward looking seat got removed . The original folding table modified and enlarged.
Raised the skoolbus seat with a 2*4 so that adults can sit there as well.
03-14-2021, 04:20 PM
#232
Year: 2011
Coachwork: Girardin Microbird G5 HC
Chassis: GMC 4500
Engine: Vortex 6
Rated Cap: 24
Like Buster Junior, I too am in awe of your accomplishments in fixing the bus, and it is looking awesome!
I really like that youput the drivers.seat on a swivel. I thought about doing that in my bus, but I have a fuse box under seat, so I don't think I can do a swivel.
Looking forward to seeing more!
03-14-2021, 08:25 PM
#233
Year: 98
hi vineyardseashell,
Often wires to a fuse box come in from one side. Maybe the wire harness is under the carpet for a small distance. So you likely can move it from flat to vertical. It might nor interfere with the base of the swivel seat. Just take the seat and base out and check what is going on.
Making the driver seat a swivel creates a lot of precious space. I regret not doing it right away in the beginning.
Johan
03-15-2021, 07:43 PM
#234
Year: 2011
Chassis: GMC 4500
Engine: Vortex 6
Rated Cap: 24
Johan
Thanks for the suggestion. I would never have thought of it. So I will take a look at the fuse box under the seat and where the wires come into it are located.
03-16-2021, 07:24 PM
#235
Year: 98
Only put the rv door in to keep the weather out. Today I shortened another part of the door and took a rusted section of the first step out. That gives me the possibility to insulate a little there as well. To reinforce the first step I laid a pressure treated plank board on the original steel step. In between the or and the steel I put a 1/4 layer of foam to prevent the chemical of the pt to attack the steel.. this plank had dried out over a long time.
To shorten the door was a lot of work to mimick the original construction.. almost there. Once the door and door frame are solid it will be easier to attach it properly to the bus door opening.
Also plasma torched the class v hitch in three pieces so that it will fit the econoline frame. I like the receiver opening to be in the bus bumper as to not effect my departure angle worse then it is already. In my case it looks like I should invert the hitch. The safety chain links are now on top. Not optimal but doable I think.
Johan
03-20-2021, 01:22 PM
#236
Year: 98
Another thing I always wanted to do but kind of forgot..
The econoline cutaways have the cabin roof removed. Not sure how others are constructed / assembled but with this Thomas they did not pay a lot of attention to detail. The econoline top beam above the windshield is just an pressed profile.. the roof is cut away.. it would have been nice if they would have welder the remaining roof to the profile . Then it would have become a box and much stronger..
While the bed above the driver was still out it gave me better access. So pop rivetted every 3" or so to optimize the strength of the window frame..
Now I can go on to gluing the fiberglass front back to the remaining econoline roof.
03-21-2021, 05:22 PM
#237
Year: 98
Do not get the fiberglass sealed to the metal yet.
Bought loctite marine pl10 and will try a 1/4 thick bead.
Simultaneous working on 19.5 rims.
The e350 with single RW has a gvwr of 9600 lbs.
Sofar with the 4*4 and all I am weighing in at 8800 . With the additional mods , second fuel tank, bathroom, additional solar panel and rear hitch I expect to get close 9400. I like to have a lot extra on the tires.
With 19.5" that will be less of a problem..
Here the first rim.. I redrilled from 8*170MM to the 8*6.5" for the econoline. Tire is now 245/70R19.5. I like to upgrade to 265/70R19.5 . About a 34" tire. Will be interesting to see how the mog will work out with the harder / stiffer tires. Hope that my rear air suspension will keep the ride acceptable.
johan
03-22-2021, 03:44 PM
#238
Year: 98
Finally, some much needed progress. I do not like sealants. This marine adhesive sealant is pretty thick. Will see if it cleans up a little better later on.
Then I was able to put the upstairs bedroom back in. Our oldest, then 10 ,now 14 used to sleep there.
After the accident the passenger door metal support for messed up but the tube straightened out and I hammered a square piece of oak in there to reinforce the tubular ends. Stronger then it was before.
This is now setup for our youngest ,9.
She of course always wanted to be up there but had some reservations being a test case. Especially when I asked her to pull the cover up, her hand is still visible.
04-07-2021, 08:58 PM
#239
Year: 98
The emergency exit /skylight was damaged and some of the plastic cracked..
With a soldering iron I was able to "weld" the crack from both sides.. seemed strong. Removed the 6 kit...butyl..silicone..sikaflex..more silicone.. repair attempts from the school district shop...shoddy work. Earlier a different hatch had been installed and the outer aluminum skin was not reattached to the frame work.
Anyhow ...lots of rivets ..then sanding ..degreasing..and marine grade sealant.. will see how it holds up.
Another step forward.. at least it is better then it was before.
Johan
05-15-2021, 08:11 AM
#240
Year: 98
Very slow progress, to many other projects ..the unimog is coming along and trying to get our electric pickup truck on the road..
Have been putting with this 15000lbs hitch from an f250 super duty.
Took the back bumper and a piece of extension chassis to be able to mount it. A challenge was to allow the oversize tire 255/85R16 or soon to be 265/70r19.5 under the bus in between the hitch and the fuel tank.
Still have to try the 265/70r19.5 but all looks well..the original hitch had to be modified but it all worked out. Next is the holes, difficult access so I think about using the plasma cutter to burn them in.
I wanted the hitch high integrated in the original bumper. had to cut some in the bumper. It stick out about 5" .feels like a decent step up to get in the back.
