Thanks Spoutroot.
So we had a medical thing going on with one of the girls and had to stay put. Made some more improvements.
First we made some clothing storage above our bed in the rear. Going to see how well it goes with the doors off first.
http://www.skoolie.net/forums/member...ture15270.html
Found some furniture grade 1/4" plywood for the bottom and front, little quarter panel is made of 7/16 ply. I wanted to go light. W wll see if this to light. Used polyurethane floor coating and that made the surface a lot stronger.
Another storage for the kids toys above the kids dinette.
http://www.skoolie.net/forums/member...ture15271.html
Like to add one more bracket to reduce vibration issues.
The bottom is is only 4-3/4 " wide and it is hung from the bottom of the wiring duct with machine screws that were mounted in the wiring duct. Nuts are on the bottom. Extra thread is sticking out so that the same screw can hold the insulating blinds.
On the right are the solar controllers.
Here is a detail shot of the house electrical panel.
I had and like to use old style toggle switches and here you see it.
No relays. The switches against the window are the heat controls, webasto pump, webasto and several computer fans that circulate the air through the heater cores. The webasto has its own fuse. The other heat related stuff goes thru one 10 Amp reset fuse.
http://www.skoolie.net/forums/member...ture15269t.jpg
The switches on the front are for the fridge / freezer/ monitor/aux fan and master ceiling lights.
The battery monitor shows voltage , amp load, Ah and some other stuff. It relates only to the house battery. The solar is tied into amp meter the shunt resistor
Next to it is the master house switch fused with 30 Amp. The solar controller go directly to the battery and are individually fused.
Later J
So this whole message dissappeared again. i had it saved but the forum interface sucks.
