Old 07-25-2016, 09:32 PM   #71
joeblack5's Avatar
Year: 98
Hi Tedd,
I had to reread my scribbles myself. Sproutroot had two plugs. I have not checked if I have two as well. I did notice under my ford that there was 120 VAC wiring going to oil filter area, so i wonder if this diesel has an oil heater as well as a block coolant heater?
regarding co pilot safety. Does your bus still has the passenger airbag installed? Mine has not. I was wondering if I could re-purpose that for extra storage.
My swivel seat is pretty stout and anchored with plates and so on. Not sure if it would be useful to put the airbag back in.
later J
joeblack5 is online now   Reply With Quote
Old 07-26-2016, 06:41 AM   #72
Originally Posted by joeblack5 View Post
Hi Tedd,
later J
Don't know about an oil heater. I guess it's a possibility.
No ... dang it. There was no passenger side air bag. And no glove box either. I did note all that room up in what used to be the co-drivers space, but haven't planned a use for it yet.
There is no end of the fun you can have with a spare air bag and a little electricity!
I noted your co-driver's seat. Heavy duty! Looks comfy.
I don't mix religion and skoolies
Insulation Fanatics Suck
Bye.
Tedd is offline   Reply With Quote
Old 07-26-2016, 07:04 AM   #73
joeblack5's Avatar
Year: 98
It is the passenger seat out of our old Ford ambulance /camper. Several years ago I converted that to a swivel. Got is at Discount van and truck. It was a couple of hundred $$. It is pretty heavy.
I like to convert the driver as well but figure that I will find something in the junk yard ...give it some time.
I wanted a bus 4 window like you have but then in srw drive and ford and could not find it. This ford is a 5 window bus but we are in in with 2 adults 2 kids and our dog Rosie. So may be I was lucky that I did not find a 4. With the dinette/ booth setup we needed that seat as swivel to get max usable space and still get a cozy setup.
I really like your combined use of metal. It saves a lot of space. These small buses need a lot more creativity to get your max out of the space.
Later J
Old 07-27-2016, 09:43 AM   #74
later J
Your thread and question caused me to kinda revisit this issue in a spare moment.
Unless you are going to mount your co-drivers chair closer to the dash ... an airbag up there is almost as useless as that grab handle.
I had a chance to take all that dashboard stuff down when I found that a rodent ate the vacuum lines that control the various door for the heat and ventilation.
When these buses were thought out (2000 or so) the design called for mega a/c and heater systems to keep the little guys in the back warm or cool depending on the need. The designers went back to old vacuum operated doors and ducting. The benefit: this stuff is much smaller and less complicated then the computer controlled systems.
As the photo below illustrates, from just opposite the driver's boney old right knee, running over top of the dog-house for the engine then all the way over to that big side window there is a LOT of wasted space. I've decided that I am not going to put GM's plastic center storage panel back over the dog-house to make it easier for this old guy to rotate to the right and out of the driver's seat into the living area without having to take a LOT more yoga classes. There is a lot of stuff (Dynomat) that does not take up much room on the market that will insulate and sound-deaden the dog-house.
http://s239.photobucket.com/user/CPOT2877/media/SANY0403_zpsn4vtwqe3.jpg.html][/URL]
I do not want to loose nor block that “passing window”, and I don't want to build anything that will stick out beyond the back of the doghouse.
Electronics would fit nicely in that spot, so would a couple fire extinguishers, warning triangles, and other items you would need to give help in an emergency. Just remember not to mount anything that will make the removal of the dog-house much more difficult.
One way or the other, there is just too much useable space there to just let go to the rodents.
Bye.
Old 07-27-2016, 04:03 PM   #75
joeblack5's Avatar
Year: 98
There is also quite a bit of space between the passenger front wheel well and the entrance stair.
In the ford the fiberglass bezel around the window in front of the entrance door has a lip molded on to it that is part of the floor. Below that , the actual old entrance step. Nice amount of space. good as you say for a fire extinguisher and so on.
Later J
Old 07-31-2016, 08:36 PM   #76
joeblack5's Avatar
Year: 98
Elf Bus E350 Corbeil battery box window / interior
Evening dear folks,
Small progress. Made some under counter storage. Found a plywood with oak veneer cabinet that was just the right size to be modified. Turned out some plastic storage from sterilite fitted right in. I like the plastic that can be easily cleaned or replaced. The wife is not crazy about it so I will see if I can make it a little more appealing.
http://www.skoolie.net/forums/member...ture13796.html
The sink was recycled from a local Paneira. The nice think is that it has a lip around that prevents the water from running on the ground.
We will just put a bucket under it as a gray water tank. One of the flat clear 1 gallon tanks is standing on the ledge above the sink. just gravity.
To make the sink ledge as wide and efficient I pulled the windows out and moved them to the outside. This also gives me 1/2 " more space to for insulation. With some creativity I can use 2" alu foil polyiso with a R value of 13 ) according home depot.
http://www.skoolie.net/forums/member...ture13795.html
I am curious if it improves the stream line a little. The lower window glass is going to be replaced with metal that has the same line pattern. I also want to change covers for the post in between the windows to get a more uniform appearance.
Tomorrow morning back to the junk yard to get another piece of bus roofing that I used to cover the window openings
The next step will be the insulation and an one unit induction stove next to the sink. It will be a fold away that will be vertical to become part of the separation wall with the bed .
http://www.skoolie.net/forums/member...ture13797.html
After that wooden storage closets above the windows and more SS below the bus.
It is hard to see but the skylight in the escape hatch provides really nice light and gives a very spacious feel for such a small contraption.
Later J
Old 08-01-2016, 08:48 PM   #77
joeblack5's Avatar
Year: 98
Elf Bus E350 Corbeil battery box window modification
Pretty good day today, Went to the junkyard and the old bus was still there. You never know when things get scrapped. Cut another 4 feet section out and was just done before a thunderstorm rolled in.
Back at home took the window frames out and removed the lower part of the framing. The self tapping screws were corroded in the aluminum and I had to drill a 1/16 hole into the profile and squirted some wd 40 in there. A little more pounding on the head of the screw loosened it up enough so that I could take it out without the head stripping o breaking of.
Took the window out and used it as a template for the metal piece.
aligned the pattern in the metal with what was one the bus already and cut them out of the sheet.
Tomorrow will be rust removal, priming and painting.
Feels good that thing start coming together.
Later J
Old 08-02-2016, 08:53 AM   #78
Later J
I know that feeling.
Bye.
Old 08-04-2016, 08:13 PM   #79
joeblack5's Avatar
Year: 98
Elf Bus E350 Corbeil kitchen window modification
Yesterday and today was a slow process. Took the kitchen windows completely out, disassembled and installed metal. The metal frames moved 3/4 out wards to create more space on the inside between the sink. Glued and screwed everything back together.
http://www.skoolie.net/forums/member...ture13835.html
Coming Sunday we want to take Elfie out for a test camping trip close by and figured that we needed mosquito screen. Found a couple of old fridges and removed the magnetic strip. A couple of old window screens provided the material for the screens.
http://www.skoolie.net/forums/member...ture13836.html
Tomorrow I will put the first pieces of alu foil polyiso insulation in.
1" behind the lower kitchen windows.
Put the first pieces of fold out cooking induction burner in. Have to find a couple of more aluminum pieces to weld a proper frame.
For this camping trip I will be using grid power and convert it to 12 volt for the freezer and fridge.
I bought a couple of Mppt solar controllers on ebay with a BQ24650 Texas Instruments chip. ( $12.7 I will to try to modify them to about 10 Amp by doubling the mosfets , a larger inductor and smaller shunt resistor. Anyhow that will take a couple of weeks from China.
Later J
Old 08-06-2016, 07:59 PM   #80
joeblack5's Avatar
Year: 98
Elf Bus E350 Corbeil insulation polyiso
yesterday I glued the diver side panels in with window shield glue ( 3M). Degreased with Acetone and backed some of the 8-32 screws a little out so that it was easier to get the 3M stuff in between. All together it went pretty smooth. Next day I checked the adhesion, unreal , could not remove the glue from the metal. It rather tore in pieces.
It was a sunny / warm day in PA. and moved on with the bedroom wall insulation. Took the bed back out to make work easier. Cut the polyiso 1/2" smaller on each side so that I could easily fill the gap with large gap spray foam.
http://www.skoolie.net/forums/member...ture13852.html
Used gorilla and nomal construction glue to bond the polyiso to the metal.
Before assembly I sprayed spray foam in the rubbing rib as to not create hollow spaces.
So i used 2" polyiso. The framing is 1-3/4". I used 1/8" spacer between my metal panels and the frame and filled that gap with the 3M windshield glue.
That would leave 1/8 on the inside so that my wood paneling is not in direct contact with the vertical framing.
http://www.skoolie.net/forums/member...ture13853.html
After this all was done and the evening sun was beating on that side of the bus the framing metal was real hot. The interior felt cooler but that might have been wish full thinking.
Thru existing screw hole I filled up the hollow space inside the framing channel. The framing is galvanized. I will do some temp measurements between the "empty" framing and foam filled framing.
http://www.skoolie.net/forums/member...ture13854.html
Installed the insulation on the other side as well but have tear it all out because the metal pan needs to have some interior tarr coating removed before I can glue it to the framing.
Any how from an insulation perspective it will work OK.
Enough for today, time for some beer.
Later J
