08-11-2017, 12:28 PM
Year: 2005
Coachwork: blue bird
Chassis: handy
Engine: e450 6.0
flooring...marine ply and liquid nails
finally, vinyl, rotten subfloor pulled, screw/bolt holes sealed, steel primed...now ready for new subfloor...any advice or cautions on sealing marine ply and then using liquid nails instead of making new screw holes in the steel floor?
08-11-2017, 01:31 PM
What method?
08-11-2017, 01:41 PM
Year: 2005
Chassis: handy
Engine: e450 6.0
08-11-2017, 02:35 PM
Chassis: Blue Bird
Engine: ISC 8.3
Originally Posted by Brewerbob
What method?
You're totally trolling for another pennies vs poker chips vs bubble gum thread on floor-hole-plugging!
I support the idea of using adhesive to fasten the new plywood down.
08-11-2017, 02:48 PM
Year: 2005
Chassis: handy
Engine: e450 6.0
yes...and i'm sure the debate will go on and on, but i chose tape because i don't have that many pennies, i don't play poker, and i always swallow my gum too early.
many thanks for the support of the adhesive solution...i was hoping i wouldn't get laughed off the forum.
08-11-2017, 02:59 PM
Nope, looking for the next 'Best idea ever" since I haven't gotten to mine yet.
08-11-2017, 03:12 PM
Year: 93
Engine: 7.3 idi
Why marine ply and not regular ply if you treated the floor? Are you insulating the floor at all? Liquid nails is awesome stuff will definitely work for you
08-11-2017, 03:23 PM
Year: 2005
Chassis: handy
Engine: e450 6.0
pacific northwet...perhaps marine is overkill, but my recent experience removing rotten ply flooring and seeing all the different caulkings used by the school district on all the body seams concerns me...not insulating...just thinking a boat on wheels in case the creek rises.
08-11-2017, 03:41 PM
Year: 93
Engine: 7.3 idi
I'm with you i feel theres alot to learn from boat builders. My guess would be the floor was rotten from water leaking through the windows and roof hatches. Definitely seal all that before proceeding. I made the mistake of waiting to seal my windows. My walls and floor took major water in heavy rains. You seem way smarter than me so sure you have it figured out. Cheers
08-11-2017, 03:42 PM
Year: 93
Engine: 7.3 idi
Oh one more thing I'm all about overkill then you won't have to redo it. Again smart
08-11-2017, 06:28 PM
Marine ply is the only way to go in my book. These rigs are gonna get wet (rain, spills, plumbing leaks, etc. ) and everything you build out will be sitting on top of it. Not the place to scrimp.
08-11-2017, 06:36 PM
I made the mistake of not sealing all my windows before floors. I ruined an area in the garage. Also had a minor flood while working on plumbing. Hit the same spot in the garage. Goodbye $2/sq.ft. I had to pull out a dehumidifier and leave it there for a few days. Definitely would have been a good idea to use marine ply.
08-14-2017, 07:37 AM
Better over than under.
You're going to need 10 sheets to do a 40 foot bus. The difference in price isn't going to break the bank (hopefully).
In a complete flood, I dunno if any wood is the right wood. It's still going to soak up water and possibly swell a little. Marine grade just isn't going to rot like the non treated.
08-14-2017, 08:16 AM
Coachwork: Carpenter (Cavalier)
Chassis: International Harvester
Engine: DTA360
Rated Cap: 63
I like your style if I can afford it I'll use Marine grade as well. And as far as the holes go I think most methods with something flat (I like to call it the bridge) over something hat adheres wel to metal should seal them. Also I think screws or bolts are overkill, liquid nails should work just fine. I've had success in our last bus with a complete floating floor, I mean after all the stuff we end up putting on top of the floor there's no way its coming up. We lived with a floating floor for two years in our first bus and saw no problems, the only thing I worried about was the seams or corners curling up, but I used OSB in our first bus and I would NEVER touch that stuff again because when it gets wet it swells, an will never go back to normal.
Looking good!
08-14-2017, 09:34 AM
Year: 2005
Chassis: handy
Engine: e450 6.0
[QUOTE=Brewerbob;219300]Better over than under.
sure glad my bus is a shorty...4 sheets better match my budget.
08-14-2017, 10:18 AM
Remember that when you're trying to shove one more cabinet for storage in there.
Shorties definitely have their place (especially in parking lots) but I want to try and live in mine. I'm not claustrophobic but might become so if I had to live in a shortie.
08-14-2017, 10:29 AM
Year: 2005
Chassis: handy
Engine: e450 6.0
true that.
08-14-2017, 04:04 PM
When I laid down marine ply on my shorty I used adhesive plus a few screws. Where I spent a little more time was on the joints. I used my router and glued bisquits into all the joined edges to keep them flat and flush. I will be putting raised dot rubber Pirelli tile throughout and don't want anything popping or buckling up later.
08-14-2017, 05:31 PM
Year: 2005
Chassis: handy
Engine: e450 6.0
thanks for the tip...also finishing with the pirelli sounds a perfect solution for your vintage bus.
08-14-2017, 06:31 PM
Traveling
Engine: 5.9L Cummins
Rated Cap: '00
Sure does meet almo$t all the requirements- flexible, comfortable, easy to clean, soundproof...
Am flooring shopping myself.
Pirelli info
