Old 10-22-2019, 07:00 PM   #1
Ford e-350 Super Duty Engine issues?
Hi Everyone,
I'm giving serious thought to a Ford E-350 Super duty mini bus. It's from 2005 and has 154,000 miles. I'm not sure how long I'll be living in this.
It is a 5-speed automatic with a v8 engine.
I feel like I remember something about serious engine issues with some type of engine in these buses. Is anyone familiar?
Also, any opinions on this type of vehicle, or alternative recommendations?
Thanks so much everyone,
MR
MattRymond is offline   Reply With Quote
Old 10-22-2019, 08:06 PM   #2
Truthseeker4449's Avatar
Chassis: HDX
Engine: CAT 3126
Which v8? There were several that were offered in the E350s.
Truthseeker4449 is offline   Reply With Quote
Old 10-22-2019, 09:03 PM   #3
Johnny Mullet's Avatar
Engine: T444E 7.3L
2005 diesel would be the 6.0L engine. If you can afford to bulletproof it and hope for reliability, then good luck. Pass on that bus. I work on a lot of 6.0L Powerstroke engines and makes lots of money doing it.
Old 10-23-2019, 12:50 AM   #4
The V-10 gas engine and its smaller brother the 5.4 V8, had spark plug problems early in 1999 and up to 2002, but fixed in 2003. .If its the 6.0 diesel...what Mullet said.
JRandall is offline   Reply With Quote
Old 11-07-2019, 05:31 PM   #5
The 5.4 Liter 3 valve with variable valve timing is prone to failure. The cam phasers start acting up. Miss fires, sputtering, runs rough. Either cam phase failure or can be an oil pressure issue. the whole system works on oil pressure. Personally would stay away from this engine. 5.4 liter 2 valve is much more reliable.
DAlgozine is offline   Reply With Quote
Old 11-08-2019, 12:10 AM   #6
PatrickBaptist's Avatar
Coachwork: IC/AMTRANS RE
Engine: T444E 7.3 w/ MD3060
All the above commenters are correct. I'd avoid a 6.oh like the plague, only engine I've seen that was worse than the 6.0h powerstroke was the GM 6.2/6.5 diesels.
After ford dropped the 7.3 powerstroke all their newer diesels are money pits.
PatrickBaptist is offline   Reply With Quote
Old 11-08-2019, 07:35 AM   #7
Coachwork: Startrans
Engine: 5.4 litre
Rated Cap: 12
5.4 liter isn't to bad and the 460 and 351 gas engines are all ok in my book.Although they do have some problems they easily last 150 - 200 thousand miles.
