Old 04-14-2015, 12:54 PM   #21
Hank's P-O-S's Avatar
Coachwork: Tomas
Engine: T444e
Rated Cap: 54
On my international 1995 3800 the flange width is 3 inches wide and the frame is 34 inches outside to outside.
It is defenatly thicker than 1/4 inch but I'm not sure that it's quite 3/8.
Hank's P-O-S is offline   Reply With Quote
Old 04-15-2015, 03:40 AM   #22
Moderator
crazycal's Avatar
Engine: DT408, AT545
Rated Cap: 23 500 gvw
Thanks to the others also for providing the measurements but no Sainthood cuz you didn't post a pretty picture.
I'm hungry!
You Gotta Let Me Fly
Old 04-27-2015, 06:13 PM   #23
Moderator
crazycal's Avatar
Are those bumper brackets bolted or welded to the frame rails?
I'm hungry!
Old 04-27-2015, 10:01 PM   #24
Engine: 190hp 5.9 Cummins
Bolted most of the time.
Old 04-28-2015, 08:05 AM   #25
Chassis: B3800 Short bus
If your bus is anything like mine (and I expect it will be), the bumper brackets are welded to the outside of the frame rails, then the bumper is bolted to the brackets.
You can see the bumper bracket in this picture. The label, "Frame rail" got cut off, but if you look closely you can find Waldo.
Old 04-28-2015, 08:19 AM   #26
Coachwork: Tomas
Engine: T444e
Rated Cap: 54
That's the first I've seen like that. It dident look like there were tow hooks there?!
All the busses I've seen the bumper brackets bolt to the frame and drop down for tow hooks.
Old 04-28-2015, 10:57 AM   #27
Moderator
crazycal's Avatar
This is bad news. I am waiting for pictures from the school district. If the brackets are welded, I will need to change my hitch design. It was going to have channel on the outside of the frame rails.
I'm hungry!
Old 04-28-2015, 11:58 AM   #28
mine had those brackets, but were bolted (nut/bolt) and not welded
Old 04-29-2015, 08:35 AM   #29
Moderator
crazycal's Avatar
I got the pictures. I need to change the design. The brackets are welded to the frame.
I'm hungry!
Old 04-29-2015, 09:01 AM   #30
Here's a better picture of how I made mine.
It slid right between the frame rails and required 6 holes to be drilled for bolts and a hole cut through the bumper. I used a cut-off saw for that.
Best part (in my opinion) is that it doesn't hang lower than the rear bumper and is boxed in between the frame and bumper in case a weld breaks. Also, it was made with **** I had lying around behind the shed
Old 04-29-2015, 12:58 PM   #31
Moderator
crazycal's Avatar
Thanks. Going to pick up a hitch off CL right now. You been a big help. Thanks.
I accidentally edited your post instead of posting my own.
I'm hungry!
Old 04-29-2015, 10:27 PM   #32
Moderator
crazycal's Avatar
Here is the hitch I picked up for $125. I know I could have gotten cheaper but this one was there and the most heavy duty. It is 3 inches wider than the bus frame but my friend will take care of that. The 2 1/2" to 2" adapter was $12.40 from wallyworld.
I'm hungry!
Old 04-29-2015, 10:30 PM   #33
Moderator
crazycal's Avatar
I looked at a similar sized Blue Bird and the brackets were bolted. Why is my stuff always more difficult?
I'm hungry!
Old 05-09-2015, 09:31 PM   #34
Moderator
crazycal's Avatar
Thanks for the help with measurements. This is the hitch I had put together.
http://www.skoolie.net/forums/member...albums693.html
I'm hungry!
Old 05-10-2015, 07:10 AM   #35
Because you live in Cali'
You planning to have TX....ready this summer?
Old 05-10-2015, 04:24 PM   #36
Moderator
crazycal's Avatar
I hope so.
I'm hungry!
