Old 04-12-2015, 03:45 AM   #1
Moderator
crazycal's Avatar
Engine: DT408, AT545
Rated Cap: 23 500 gvw
Frame measurements please 1994 Thomas International 3800
I need help with frame measurements. I am looking at a 1994 International Thomas 3800 (very) short bus. If anyone has a similar bus, I hope you can help me with frame measurements. I want to build a hitch setup before I go pick up the bus. I plan on using it to tow back the vehicle I used to go get the bus. The measurements I need are frame width outside to outside. Inside to inside. How tall are the frame rails? Is the back bumper welded or bolted on?
I'm hungry!
You Gotta Let Me Fly
Old 04-13-2015, 03:57 PM   #2
Moderator
crazycal's Avatar
Nothing???
I'm hungry!
Old 04-13-2015, 06:27 PM   #3
Chassis: B3800 Short bus
Oh, hey.. I can probably help. Does the 1994 version look anything like mine (signature link points to build thread)?
Old 04-13-2015, 08:08 PM   #4
Moderator
crazycal's Avatar
Yes, I think so, but I am confused. Bus in the beginning has a lowered roof and later has a raised roof. Also, my bus doesn't have cool babes in it.
I'm hungry!
Old 04-13-2015, 08:17 PM   #5
Moderator
crazycal's Avatar
I have one picture of my bus.
I'm hungry!
Old 04-13-2015, 08:36 PM   #6
Mine goes low to high now, too!
Are you sure? Have you inspected the interior yet?
I'll measure the frame rails tomorrow.
In the meantime, here's a picture showing what the frame rails look like back there:
Old 04-13-2015, 08:38 PM   #7
Actually, this is a better picture:
Old 04-13-2015, 08:41 PM   #8
Out of curiosity, is this another schoolie project for yourself? Looking for something more "sporty" than a full-size?
Old 04-13-2015, 09:22 PM   #9
Moderator
crazycal's Avatar
Absolutely, unless I find something like this.
I'm hungry!
Old 04-13-2015, 09:28 PM   #10
Haha.. Funny thing; just last week I saw that bus. It makes a cameo appearance in the movie, "you, me and Dupree" which happened to be on in the background on Easter Sunday.
Old 04-13-2015, 09:29 PM   #11
Moderator
crazycal's Avatar
If you are able to, I would like measurements from inside to inside of the frame rails. Outside also. I want to prebuild a hitch setup when I go to pick up the bus.
I'm hungry!
Old 04-13-2015, 09:32 PM   #12
Moderator
crazycal's Avatar
Do you think my bus is shorter than yours?
I'm hungry!
Old 04-13-2015, 10:05 PM   #13
It's hard to tell comparing from two different angles. I'll measure bumper to bumper tomorrow as well.
Old 04-14-2015, 09:13 AM   #14
Engine: 190hp 5.9 Cummins
Sorry I missed this thread.
Most MDT frame rails are 34 inches outside to outside.
Frame rail height ranges a bit. Ford B700's use 10 inch tall frame.
My mid 90's TC2000's (freightliner) chassis are 9 3/4 inches tall
Old 04-14-2015, 09:22 AM   #15
mine was 34 in and had 2 brackets bolted on bumper
Old 04-14-2015, 10:09 AM   #16
Alright, here it is.
I'm not entirely sure if the frame rail thickness is 1/4" or 5/16" thick. I used 1/4" in the drawing.
As you can see, there is about 2 1/4" of flat metal on the flange before hitting the curve.
Old 04-14-2015, 10:13 AM   #17
And here is a picture of the main bolts holding the bumper on. The nuts are a pain in the ass to reach. I think I cut the old ones off and replaced with fresh ones after getting fed up with it.
There are 6 bolts in total. 4 connect the bumper directly to the frame rails. There will also be one on each end of the bumper that connect it to stabilizer arms.
Old 04-14-2015, 10:17 AM   #18
Are you bringing a friend? If you plan on removing the bumper to install your hitch receiver you will quickly realize it's a two person job. I managed by myself by lifting it onto blocks and supporting it with every available limb while I bolted it back on, but it took 4 times as long as it could have..
Old 04-14-2015, 11:17 AM   #19
Moderator
crazycal's Avatar
I nominate Jazty for Sainthood. Thank you.
I'm hungry!
Old 04-14-2015, 11:27 AM   #20
haha.. No problem.
I'd like to mention that I was being conservative about the 2 1/4" flat flange face. It's hard to measure where the inside curve starts with a measuring tape, so I rounded down to the nearest quarter inch.
