04-12-2015, 03:45 AM
Moderator
Engine: DT408, AT545
Rated Cap: 23 500 gvw
Frame measurements please 1994 Thomas International 3800
I need help with frame measurements. I am looking at a 1994 International Thomas 3800 (very) short bus. If anyone has a similar bus, I hope you can help me with frame measurements. I want to build a hitch setup before I go pick up the bus. I plan on using it to tow back the vehicle I used to go get the bus. The measurements I need are frame width outside to outside. Inside to inside. How tall are the frame rails? Is the back bumper welded or bolted on?
04-13-2015, 03:57 PM
Moderator
Nothing???
04-13-2015, 06:27 PM
Chassis: B3800 Short bus
Oh, hey.. I can probably help. Does the 1994 version look anything like mine (signature link points to build thread)?
04-13-2015, 08:08 PM
Moderator
Yes, I think so, but I am confused. Bus in the beginning has a lowered roof and later has a raised roof. Also, my bus doesn't have cool babes in it.
04-13-2015, 08:17 PM
Moderator
I have one picture of my bus.
04-13-2015, 08:36 PM
Mine goes low to high now, too!
Are you sure? Have you inspected the interior yet?
I'll measure the frame rails tomorrow.
In the meantime, here's a picture showing what the frame rails look like back there:
04-13-2015, 08:38 PM
Actually, this is a better picture:
04-13-2015, 08:41 PM
Out of curiosity, is this another schoolie project for yourself? Looking for something more "sporty" than a full-size?
04-13-2015, 09:22 PM
Moderator
Absolutely, unless I find something like this.
04-13-2015, 09:28 PM
Haha.. Funny thing; just last week I saw that bus. It makes a cameo appearance in the movie, "you, me and Dupree" which happened to be on in the background on Easter Sunday.
04-13-2015, 09:29 PM
Moderator
If you are able to, I would like measurements from inside to inside of the frame rails. Outside also. I want to prebuild a hitch setup when I go to pick up the bus.
04-13-2015, 09:32 PM
Moderator
Do you think my bus is shorter than yours?
04-13-2015, 10:05 PM
It's hard to tell comparing from two different angles. I'll measure bumper to bumper tomorrow as well.
04-14-2015, 09:13 AM
Engine: 190hp 5.9 Cummins
Sorry I missed this thread.
Most MDT frame rails are 34 inches outside to outside.
Frame rail height ranges a bit. Ford B700's use 10 inch tall frame.
My mid 90's TC2000's (freightliner) chassis are 9 3/4 inches tall
04-14-2015, 09:22 AM
mine was 34 in and had 2 brackets bolted on bumper
04-14-2015, 10:09 AM
Alright, here it is.
I'm not entirely sure if the frame rail thickness is 1/4" or 5/16" thick. I used 1/4" in the drawing.
As you can see, there is about 2 1/4" of flat metal on the flange before hitting the curve.
04-14-2015, 10:13 AM
And here is a picture of the main bolts holding the bumper on. The nuts are a pain in the ass to reach. I think I cut the old ones off and replaced with fresh ones after getting fed up with it.
There are 6 bolts in total. 4 connect the bumper directly to the frame rails. There will also be one on each end of the bumper that connect it to stabilizer arms.
04-14-2015, 10:17 AM
Are you bringing a friend? If you plan on removing the bumper to install your hitch receiver you will quickly realize it's a two person job. I managed by myself by lifting it onto blocks and supporting it with every available limb while I bolted it back on, but it took 4 times as long as it could have..
04-14-2015, 11:17 AM
Moderator
I nominate Jazty for Sainthood. Thank you.
04-14-2015, 11:27 AM
haha.. No problem.
I'd like to mention that I was being conservative about the 2 1/4" flat flange face. It's hard to measure where the inside curve starts with a measuring tape, so I rounded down to the nearest quarter inch.
