Old 07-17-2011, 06:13 PM   #21
Chassis: Chevy Van G30
Engine: 6.2L
Re: Green Energy Project
Moshart: Here is a detail of the dead bolt. Originally I wanted the bus door to still fold in but lock with a dead bolt. So I welded a strip from a metal door onto the edge of the bus door then drilled a hole for the dead bolt in that strip. Unfortunately the angle of the fold made the latch pop out and didn't work at all. So I flipped the hinge strip so it swung out, welded the pins shut in the middle, and now have a regular swing door from the original bus door. Still needs some cosmetic touches tho. Like I said before, if I could do it again I would use a vertical garage door latch and then it could still fold in. If you look at Lillie's page on her thread Leap of Faith you can see pictures: viewtopic.php?f=36&t=5919&start=75
RJZ5400: If we are still in town (richmond) then it would be great to meet up. Do you always plan ahead and find where your going to get your veg oil when traveling? We haven't settled on a route yet but I was hoping it wouldn't be that hard to find sources... I'm trading some mural work for help installing my kit at this nonprofit mechanic shop in town, should be starting on it this week or next. My hope is to put the 40gal tank under the bus just behind the driver seat, but we'll see. I'm going to try to film the process so if everything works out there will be a time lapse video of the process.
In other news... I was hoping some fuel treatment would clean out the fuel line and carbs on the scooter, but it was getting worse and worse. I found a new carb on ebay for $35 and installed it today. Purrs great now!
dangie is offline   Reply With Quote
Old 07-17-2011, 10:13 PM   #22
rjz5400's Avatar
Chassis: Thomas? Safe-t-liner
Engine: 6bta5.9
My guess would be that what you cleaned out of the fuel system slowly clogged the jet and or the fuel inlet needle.
well now that you have two carbs might i suggest taking the "bad" one apart and finding the jet. it should be a small brass screw in thing inside the bowl where the fuel is. these get changed according to the fuel air needs of the motor. some reasons these needs change are elevation, temperature, and humidity. forgive me if this is elementary but not to many people understand what i think you have there, a single cylinder two stroke. it would be good to know all the parts and how to check/clean/swap out otherwise you will have more problems. check out the "moped army" for tips and more info on two stroke tuning and whatnot and
yes i do try to plan out at least one or more yegg stops on a trip especially one that requires probably 200+ gallons of fuel. 1800 miles at 9 ish miles per gallon plus detours. i usually find people on "Fill up for Free"
rjz5400 is offline   Reply With Quote
Old 07-21-2011, 05:28 PM   #23
Engine: 6.2L
Trailer progress... I swapped the spool on the welder for a lighter weight spool and finished the rest of the welding with much better success. Started putting up the paneling and ran into a snag thanks to the not so friendly staff at Lowes who can't seem to cut a precise measurement to save their life.. 3" full inches off what I asked! Now i'll have to run a strip in the middle to make up the difference. Should have it done tomorrow if i can handle the heat for another day...
Old 07-21-2011, 06:53 PM   #24
lornaschinske's Avatar
Rated Cap: 89
Originally Posted by dangie
... the not so friendly staff at Lowes who can't seem to cut a precise measurement to save their life.. 3" full inches off what I asked! ...
Question #1: Why would you think they could cut it right?
Question #2: Why would you let them cut a precise cut?
We have had the nuts at Home Depot cut a sheet of plywood in half so that we could get it in the Jeep but we would never expect a precise cut. I would love to have their panel saw though. No more panel saws, table saws, planers, drill presses, etc in my future. At some point I will even sell off my router table.
Fulltime since 2006
Old 07-27-2011, 05:45 PM   #25
Engine: 6.2L
I've finished enclosing the trailer! Now I can figure out what exactly I'm bringing with me and build shelves. The 50gal drums will need an access panel on the outside as well as a box for the filtering setup. We also decided to get kayaks to bring with us and mount them on top of the trailer. I bought a Dagger Redline off craigslist but its a little too whitewater for Angie and too small for me, so the hunt continues..
In other news, I started the mural for DLW last night and today we started hooking up the greasecar kit. Unfortunately, due to the dimensions and location of the fill hole on the fuel tank, I don't have the clearance to put it under the bus as I had hoped. Its now all going where the metal cabinet was between the couch and driver seat. I mounted the filter and valves to the metal lip that already runs around the base. Tomorrow we'll tee the coolant lines from under the bus, drill holes and run them up through the floor to the tank. If I remember my camera I'll take a progress shot tomorrow. Once its done I'll have to make an access panel on the side of the bus if I want to fill up from outside. Then I'll build a cabinet or counter space around the whole thing. I think it's actually going to be better this way because the fridge was a tight fit on the other side, now I can built it into this new cabinet and everything should fit nicer.
Old 07-28-2011, 10:41 PM   #26
Engine: 6.2L
Progress shots of the veg. oil system..
Inside the veg. tank. Coolant runs through the copper tubes to preheat the oil in the tank, the orange stub sticking out is the supply for the veg. oil
Coolant in and out from veg. tank. Hose in hose from the tank to the filter (meaning the fuel line coming out of the tank to the filter is inside the larger red coolant hose that is coming from the heat exchange [copper around the filter] into the tank)
These are the fittings I bought to tee in the coolant lines, $15 for two sets. I'm a little concerned about whether they will hold up to the heat. There wasn't anything on the package that indicated a temp. limit, pleasants hardware employees couldn't tell me, no number to call... the mechanic helping me said it should be fine but couldn't say for sure. The alternative brass option was going to be $60 and heavy.. I guess if it starts leaking I'll have my answer.
Shot of the coolant lines teed in.
Lots of hoses... Labels should give you the idea where its all going.
Solenoid Valves. Tomorrow im going to tee in the fuel lines and run them to the valves.
Old 07-29-2011, 09:44 AM   #27
Diesel Dan's Avatar
Engine: DT466/AT545
Since you're putting your WVO tank and filter inside the bus, I recommend you put some sort of pan to catch veggie oil in case of accidental spillage. I've been using the Greasecar system in my Mercedes for several years now and I can tell you, changing filters is a messy operation, and then inevitably you will have to remove a hose or one will leak at a fitting, etc. In other words, I can almost guarantee you will have veggie oil spills, leaks and messes in the area of your filter and tank. Pretty soon the inside of your bus is going to smell like used vegetable oil. So I would again recommend some sort of containment strategy. You might also consider insulating the tank for more efficient heating of the oil. If I had mine inside the bus, I'd build a cabinet (with doors for accessibility) of some sort around it to contain the inevitable mess, smell and heat. Also, if you are looping your return back to supply, you will find that any air that gets caught in the system will be difficult to purge. I put a valve-controlled optional WVO tank return line on mine for this reason. You simply "T" into the WVO return loop and have two needle valves that control how much WVO is sent back to supply, and how much is returned to the tank. You "T" it off the top so that if you open the tank return a little bit, any air bubbles back to the tank whereas most fuel is sent back to the injection pump. Every time you change your WVO filter air will get into the system.
Gallery:
Conversion Thread:
viewtopic.php?t=4959
Old 07-29-2011, 11:19 AM   #28
sdwarf36's Avatar
Coachwork: Champion
Chassis: Ford e-450
Engine: 7.3 Powerstroke
Greasecar makes a remote fill kit you may be able to use to get things underneath. What I did was take a Jeep CJ filler neck +surround ( made for a flat surface) and have a rad hose going to the top of the tank- it comes in from the side of the bus-the tube is inside one of the bench/storage compartments+ goes thru the floor. I agree on some form of drip pan under at least the filter-you are alway gonna get some spillage from a filter change.
Old 07-29-2011, 07:32 PM   #29
Engine: 6.2L
Yea I was definitely planning on enclosing it in a cabinet with doors of some kind. The drip pan sounds like a must, I had not thought of that. Thanks guys!!!
Diesel Dan> Do you have a picture of your two needle valves somewhere I can look at? Having a way to bleed the air out sounds like a smart move but this whole process is WAY over my head, I'm struggling just to follow the diagram it came with much less "T" in more valves. I'll do some more research on that but if I can see it somewhere I think it'll help me understand.
Sdwarf36> The remote fill kit sounds like it may have worked, but unfortunately with timing and the whole barter mechanic "help" situation I didn't have a chance to look into other options. Now that its all pretty much set and done inside I think I'm gonna make due for this project.. Thanks tho I figured there was a way to keep it underneath. Maybe next time.
Todays progress...
Fuel lines tapped to veg. system
Fuel lines into valves.
Tomorrow I'm going to have the mechanic look over everything with me before I test it all out... VERY anxious to see if I did it all right.. I reeeeally hope I don't blow something up before I even get to drive it. Wish me luck!
Old 07-29-2011, 08:54 PM   #30
Hex
Hex's Avatar
Coachwork: Bluebird, Model 3800
Rated Cap: 42
Good luck!
And really nice job on labeling. If anything goes wrong, you won't need to be tracing back lines to see what goes where ...
Hex is offline   Reply With Quote
Energy crisis is postponed Nachtwulf Everything Else | General Skoolie Discussions 1 10-16-2009 06:34 PM
Energy Efficiency Sojakai Conversion General Discussions 0 07-31-2009 11:12 PM
Alternative Energy paul iossi Conversion General Discussions 6 04-11-2008 02:27 PM
Cool energy devices soused moose Classifieds | Buy, Sell, Swap 3 04-09-2007 11:31 AM
Using Altrnative Energy to Create a Far More efficient RV Free Energy Conversion General Discussions 4 11-22-2005 08:24 AM
