Old 01-26-2017, 12:31 PM   #1
Phatman's Avatar
Heat Reflective Roof Paint
Has anyone nailed down a roof paint that seems to be the best ?
Old 01-26-2017, 12:33 PM   #2
Plain old flat white paint is the most reflective.
Old 01-26-2017, 12:37 PM   #3
Phatman's Avatar
So it doesn't have to be any kind of special UV reflective of some special coating. Just a good flat white?
Old 01-26-2017, 12:59 PM   #4
All white paint is basically 90% reflective. Flat white has less chance of hot spots because it reflects it more uniformly.
https://www.thcfarmer.com/community/...ve-paint.4901/
96% Reflective Paint $32/ Gal. At Home Depot - General Growing Information - Michigan Medical Marijuana Association
Old 01-26-2017, 01:59 PM   #5
Those reflectivity numbers (given with paint codes usually and named LRV) are architechtural guide lines and are used to measure how bright surfaces will be once illuminated by a light source.
It doesn't pass judgement on the radiant heat being reflected which is what is interesting for roofing materials.
Just my 2 cents... ;)
mrblah is offline   Reply With Quote
Old 01-26-2017, 02:08 PM   #6
Rated Cap: 37,400 lbs GVWR
I used Rustoleum Professional 242256 gloss white oil-based enamel with Hy-Tech Thermacels ceramic insulation powder mixed into it, rolled on with a 4" short-nap roller. So far, so good. I don't know how much difference the pixie dust makes, but it can't hurt it, and any slight benefit is worthwhile.
Old 01-26-2017, 02:42 PM   #7
There's a reason that southern regions have buses with white roofs and most of the ones from cold areas don't.
This is a pretty basic question/subject. It isn't rocket science.
https://www.scientificamerican.com/a...se-color-heat/
Old 01-26-2017, 02:48 PM   #8
oricha1984's Avatar
Engine: gasser probably
Someone did an experiment on it. There is a thread somewhere.
Basically "white elasomatric white roof sealant paint" from Lowes or home depot was the best result for the money.
Search my profile, I can't get link from phone.
Sent from my BLU LIFE ONE X using Tapatalk
oricha1984 is offline   Reply With Quote
Old 01-26-2017, 02:50 PM   #9
Right. White elastomeric roof paint. Kool Seal is one brand but there are a ton of different brands. All pretty much the same.
Old 01-26-2017, 04:38 PM   #10
Smile Nice!
Nice Information
pepe is offline   Reply With Quote
Old 01-26-2017, 05:10 PM   #11
Traveling
Engine: 5.9L Cummins
Rated Cap: '00
Interesting. fillite?
It's be east to do a study on a couple small identical metal boxes and a pair of thermometers.
FILLITE Hollow Ceramic Microspheres - The Cary Company
Microspheres, ceramic, fillite | eBay
Old 01-26-2017, 08:17 PM   #12
superdave's Avatar
Chassis: thomas
Engine: 8.3 cummins
Rated Cap: 11 window
only thing I don't like about the cool seal is it collects dirt. im going with the gloss oil base white.
my build pics
Old 01-26-2017, 08:25 PM   #13
I'll be using satin white rustoleum on the roof.
Old 01-26-2017, 09:19 PM   #14
Not to start another fire storm of controversy, but...my personal experience with the HyTech beads left me quite impressed. Applied to the inside of a rusty 1920's, industrial corrugated tin roof it felt almost cool on a 100+ degree Houston day in August. Nothing but two coats of the "pixie dust" mixed with Home Depot latex "mistakes". Also..they make a clear finish coating that purportedly makes it much easier to keep clean out in this dirty world, but that I cannot comment on.
I'm using it all over my shorty.
Old 01-26-2017, 10:42 PM   #15
oricha1984's Avatar
Check the links in this one. The experiment rocks.
http://www.skoolie.net/forums/showthread.php?t=15029
Old 01-26-2017, 11:07 PM   #16
Phatman's Avatar
Thanks guys. You gave me plenty of info to look at and decide.Mango is across town from me, so I totally understand the hot August days in Houston.
Old 01-27-2017, 12:11 AM   #17
I know it's not. But it still more complex than a simple reflective value given by the manufacturer. Yes southern region use white paint, but that doesn't tell us anything about the component in the paint.
All I'm saying is that the material of the dry paint (chemical composition) is as important as the color (which obviously should be white...).
Taking the value of the LRV at face value can be misleading since it doesn't measure heat, but luminance. Roofing compounds that offer up a r-value is more interesting since this means they tested the heat tranfert of the entire medium.
Old 01-27-2017, 05:57 AM   #18
Old 01-27-2017, 06:22 AM   #19
superdave's Avatar
Chassis: thomas
Engine: 8.3 cummins
on the underside of the roof? not on the outside?
my build pics
Old 01-27-2017, 07:11 AM   #20
Nice!
Thanks
