Old 01-26-2017, 01:31 PM   #1
Phatman's Avatar
Heat Reflective Roof Paint
Has anyone nailed down a roof paint that seems to be the best ?
Old 01-26-2017, 01:33 PM   #2
Plain old flat white paint is the most reflective.
Roll Your Own Build Thread
Old 01-26-2017, 01:37 PM   #3
Phatman's Avatar
So it doesn't have to be any kind of special UV reflective of some special coating. Just a good flat white?
Old 01-26-2017, 01:59 PM   #4
All white paint is basically 90% reflective. Flat white has less chance of hot spots because it reflects it more uniformly.
https://www.thcfarmer.com/community/...ve-paint.4901/
96% Reflective Paint $32/ Gal. At Home Depot - General Growing Information - Michigan Medical Marijuana Association
Old 01-26-2017, 02:59 PM   #5
Those reflectivity numbers (given with paint codes usually and named LRV) are architechtural guide lines and are used to measure how bright surfaces will be once illuminated by a light source.
It doesn't pass judgement on the radiant heat being reflected which is what is interesting for roofing materials.
Just my 2 cents... ;)
mrblah is offline   Reply With Quote
Old 01-26-2017, 03:08 PM   #6
Coachwork: integral
Rated Cap: 37,400 lbs GVWR
I used Rustoleum Professional 242256 gloss white oil-based enamel with Hy-Tech Thermacels ceramic insulation powder mixed into it, rolled on with a 4" short-nap roller. So far, so good. I don't know how much difference the pixie dust makes, but it can't hurt it, and any slight benefit is worthwhile.
Old 01-26-2017, 03:42 PM   #7
There's a reason that southern regions have buses with white roofs and most of the ones from cold areas don't.
This is a pretty basic question/subject. It isn't rocket science.
https://www.scientificamerican.com/a...se-color-heat/
Old 01-26-2017, 03:48 PM   #8
oricha1984's Avatar
Engine: gasser probably
Someone did an experiment on it. There is a thread somewhere.
Basically "white elasomatric white roof sealant paint" from Lowes or home depot was the best result for the money.
Search my profile, I can't get link from phone.
Sent from my BLU LIFE ONE X using Tapatalk
oricha1984 is offline   Reply With Quote
Old 01-26-2017, 03:50 PM   #9
Right. White elastomeric roof paint. Kool Seal is one brand but there are a ton of different brands. All pretty much the same.
Old 01-26-2017, 05:38 PM   #10
Smile Nice!
Nice Information
pepe is offline   Reply With Quote
