Old 10-11-2009, 04:53 PM   #11
Hearse Driver's Avatar
Chassis: Ford B700
Engine: 5.9L Cummins
Re: Hello-new short bus owner here
Originally Posted by sdwarf36
The door is now opened + closed with a linear accuator working directly on the bar that connects the 2 doors together. Speed-wise it isn't too bad-it takes about 5 seconds to open or close. And seals tight too.
This is one thing I was trying to figure out myself. I'd like to keep my double doors (with a little modifying) and not mess with framing in some other kind of door. Where did you get this actuator? Do you have some kind of key switch on the outside of the bus for entry?
What doesn't kill you only makes you... stranger.
http://i746.photobucket.com/albums/x...G_0164link.jpg
Hearse Driver is offline   Reply With Quote
Old 10-11-2009, 08:27 PM   #12
sdwarf36's Avatar
Coachwork: Champion
Chassis: Ford e-450
Engine: 7.3 Powerstroke
http://cgi.ebay.com/ebaymotors/HEAVY-DU ... ccessories
You probably only need a 6 " stroke-I bought the long one 1st thinking I was gonig to the door direct with it. mocked up it would have taken 20 seconds for the door to open!
Outside the door I have a 2 panel 110v plug with waterproof covers-under one of the covers is a a dpdt toggle switch. they also sell remotes you use to acctivate it. Careful how sturdy you built things -this thing has enuff power to bent things. Notice the low tech piece of metal I had to weld to the door frame to cut down on flex.
New bus owner in Alaska needs help syke Titles, Insurance, Registration and Money Matters 3 06-10-2013 07:03 PM
New bus owner - what can you tell me about my bus BelltownBikes Conversion General Discussions 12 03-03-2013 08:49 AM
Newb Short bus owner:).. willz0072002 Short-Bus Conversion Projects 15 07-20-2011 01:17 AM
Soon-to-be Short-Bus Owner In Need Of Suggestions! sdwarf36 Short-Bus Conversion Projects 6 01-15-2010 03:05 AM
Newbie bus owner hugum Conversion General Discussions 1 06-07-2006 03:45 PM
