Old 05-14-2015, 09:51 PM   #21
crazycal's Avatar
Originally Posted by cowlitzcoach View Post
When you say open the whole rear of the bus do you mean the full width and height or...?
If you don't need full width or full height, why not use the side lift door in place of the current rear emergency door? Most lift doors are about 30%-50% larger than rear emergency doors. And then just skin over the lift door hole.
As far as manual transmissions are concerned, they have amounted to less than 1% of all bus production over the last 20-years. So they are out there but they are extremely few and far between.
Using two of the lift doors like barn doors is not a bad idea. I did want full width and as close to full height. I know the curve will be a problem.
I'm hungry!
You Gotta Let Me Fly
