Old 01-27-2018, 11:56 AM   #1
Home Sweet Home
After 5 years of thinking about building a tiny home and 1 year of lurking this site I finally bought a shuttle bus Yesterday.
It's 1995 Ford E350 with a rebuilt Gas 5.8L 351 Windsor motor and an Eldorado shell with 221,334 miles.
It has a lot of miles! But really low rust. It has had an engine rebuild and regular maintenance as it has been a church bus in the south most of it's life.
I was wanting to get one with the 7.3l diesel as I understand it is the best but I found this around the corner for $2300 and I bit.
My question is how did I do!?
My plan is to live in it full time, I'm probably not going to be touring across the country but I would like it to be mobile so I can move around to wherever life takes me.
I tried searching the forum and could not find much on this engine so that worries me. I know it's not diesel but is this considered a good gas engine?
What should I look out for? As I live in Arkansas we do not have emission regulations so i was planning on removing some of that to let the engine breath a little more.
It has a slow engine oil leak and possibly transmission and it seems to have a high idle.
Also does anybody have an idea on expected MPG I was hoping for 10mpg not so sure anymore.
I'm a bit overwhelm and very excited.
Blue hole is offline   Reply With Quote
Old 01-27-2018, 12:28 PM   #2
Traveling
Engine: 5.9L Cummins
Rated Cap: '00
Congratulations !!!
I like your shuttle- it will be a great little home.
I think the biggest issue I see with that vehicle design is water getting in the gutter area. Seal that well before working on the interior.
Get planning !
Old 01-27-2018, 02:20 PM   #3
Defjr333's Avatar
Chassis: Shuttle or Shorty. Still hunting
Engine: Prefer Diesel
Rated Cap: 14 to 24 pref
Nice looking shuttle. Been looking for one but with both front doors in tact. That looks a little longer than some here. Any idea what the length from back of driver seat to rear wall on that one is?
Doug
Defjr333 is offline   Reply With Quote
Old 01-27-2018, 02:35 PM   #4
Jdawgsfanasty's Avatar
Once upon a time the 351 was the beast...they were in LTDs, cop cars, trucks,etc...if you have overheating issues change the water pump...great project vehicle
Jdawgsfanasty is offline   Reply With Quote
Old 01-27-2018, 04:37 PM   #5
Robin97396's Avatar
Welcome, and nice bus.
The 351 windsor is a workhorse. I have one in a ford pickup here. In pickups they usually come in the trucks that have dual fuel tanks. I don't mean two different types of fuel. I mean two large gas tanks, because the 351 windsor is a thirsty engine. That's likely why the church decided to get rid of it, not to mention being over 200k on a gas engine. It should work fine if you don't plan to drive great distances.
Considering how high prices are on shorty buses lately, you did well. It is quite likely we would have attempted to change your mind about going gas if you had come here earlier, but some people are simply more comfortable with gas engines for a number of reasons. We don't discriminate against gas engines. It is a workhorse.
Robin
Nobody's Business
Old 01-27-2018, 05:32 PM   #6
I believe it is 14.5" behind the seat and 7.5" wide.
Anybody have any recommendations on gutting this thing?
How much do I take it down to?
Any proper order of operations or just pretty much unscrew and pull.
It rained last night and I am noticing some damp areas and some water damage. Best way to repair the water damage?
I will upload photos later.
Thanks!
Old 01-27-2018, 06:17 PM   #7
CaptSquid's Avatar
Chassis: HDX
Engine: Cat C7
Rated Cap: 84 passenger
Nice score!
The first thing is to remove all the passenger seats. You really can't proceed until that's done.
Next, determine how many side windows you REALLY need. Once the excess windows are removed/covered up, proceed with wiring. After wires are routed, INSULATE heavily. It DOES get cold inside these beasts.
Then, and only then, will you work on the layout. Bed comes first, followed closely by water and sanitation. I recommend a composting toilet. That way, you'll only have to consider fresh and grey water tanks.
Old 01-27-2018, 06:26 PM   #8
Traveling
Rated Cap: '00
There is more damage than you can see. You will have to tear-out the affected areas- inner walls, usually. Where the fiberglass roof meets the sidewall is where you need to look closely.
I had a V-10 gas shuttle and was very happy with it (gas engine).
Old 01-27-2018, 11:38 PM   #9
Day One
Day One.
Got some progress today.
Not bad for a first day.
Here is some of the worst water damage I've uncovered so far.
How do I remove this heater and A/c unit in the back?
Felt less overwhelmed working on it, like yeah I can do this.
Old 01-28-2018, 12:32 AM   #10
Robin97396's Avatar
Yeah, you can do that. All you got to do is try, right? A couple hundred hours of practice would polish up these new bus skills, but you usually only have a day or two to get good at whatever is on the menu for the day. It's the oddest sense of accomplishment as you complete tasks.
I haven't found a piece of ancient gum for a long time now. I've gone below the level where sticky fingerprints could stick. No more errant rivet heads either.
Robin
Nobody's Business
