08-20-2018, 11:23 PM
#21
theres a lot of everything still ouit on the road.. like ive said earlier.. theres good ones and bad ones of everything...
some say the old gas 392's are worthless.. i just drove a 40 year old across the country and its original from all i can tell..
theres 7.3's that have flown apart in pieces.. and 6.0s with over 300,000..
maintenance to crucial to any.. its tough to know what may have happened to a bus before you get it... service records help nad being dilligent about fully checking it out before paying the money is often more helpful///
and of course if there are Preventative issues you can do, do them.. ie EGR and oil Coolers on a 6.0 go a long way.. if a full chassis with a 545, a trans cooler..
7.3's fix the oil / fuel leaks and if high mileage pre-99.5 make sure the injectors and glowplugs are good...
08-21-2018, 05:11 AM
#22
Engine: 345 international V-8
hmmm I have an old gas 392. Got to be careful not to spread bad juju about them.....
08-21-2018, 07:00 AM
#23
I just drove a 40 Year 392 Superior Across the country...(2500 miles) , many people here say gasser busses are worthless... (that full size bus climbed hills faster than my shortie 444E until I started heating up the Transmission and had to back it down)..
my point is that mine has lasted 40 years and looking at it, appears the heads have never been pulled off the engine.. or if they were then someone was OCD careful about not nicking the head bolts up with a socket when they put it back together...
theres a lot of people that spread rumors about engines that are good and bad.. people need to assess their own needs / wants and do their own research rather than rely on people on one forum saying "yeaay or nay"..
08-21-2018, 07:32 AM
#24
I can't recall anyone ever losing their business over the 392 gas engine. Those old engines were built to last.
The 6.0, well they will always be a black eye on the manufacturer and its deserved. Navistar really dropped the quality in the early 2000's.
08-21-2018, 11:09 AM
#25
This is my first 392, although I have had the 304 and 345 both of which did great for me. I expect to have mine ready to start by the end of the week. Putting finishing touches on the fuel injection, and some other odds and ends.
I have to say the forum is a good place to do research, we get to find out what has worked for people and what has not. Sure there are a lot of opinions, and some not based on first hand knowledge at that. But all and all a good place to start.
Must say for Madhat, going from a bus that overheats to "maybe" buying another that has overheated enough to blow the head gasket does not seem like a good idea.
08-22-2018, 12:10 PM
#26
I found this GMC 4 window 1999 with the 6.5l turbodiesel. Seems like most people prefer the 7.3s on the ford. Does the 6.5 have a good reputation like the powerstroke?
08-22-2018, 12:54 PM
#27
No, it doesn't quite have the reputation the 7.3 has. But its a good engine.
08-22-2018, 12:58 PM
#28
I am asking because the bus is relatively inexpensive, under my budget so I could get more fancy things...haha..
It just came out of service and has a new injection pump. 280k miles on it.
08-22-2018, 12:59 PM
#29
Man, just on the info provided I'd imagine its cheap because its had a long life already. 280k on a weighed-down van is a lot of miles. Even for a diesel.
08-22-2018, 02:17 PM
#30
I talked to the owner. He runs the school bus fleet and the bus has been maintained on schedule. He said the bus has had 2 turbos and the injection pump replaced. Good tires and brakes all things work. They never drove it hard, kept it in the speed limit and said it goes up the 5% hill without slowing down much even loaded. No overheating issues.
08-22-2018, 02:56 PM
#31
If its cheap enough and you want to roll the dice go for it.
If I had a bus like you're describing and it had 280k with no issues I'd be looking to get rid of it too. Harder to get rid of once a problem pops up.
Not trying to discourage you. But at that mileage the engine has to be getting a bit tired. And in a van its a PITA to work on engines! I drive a van.
08-22-2018, 03:07 PM
#32
Never drove it hard, but replaced 2 turbos, makes you wonder?
08-22-2018, 03:12 PM
#33
Yeah, why to me it seems like a good case for "lets get rid of it before it breaks again".
But this is just a guess from me, a random guy on the internet.
08-22-2018, 03:43 PM
#34
My self I have always felt the cutaway van chassis vehicles have compromising seating position. It’s not the seats that are the problem it’s the engine next to you puts feet in a very small area.
I just do not understand why people want these cutaway vans (especially gas ones) over a slightly bigger busses.
The chassis design makes engine work very difficult. Gas versions get worse MPH than full size bus with a deisel engine.
08-22-2018, 04:05 PM
#35
I have a 97 e350 short bus with a 7.3 and before i got my hands into it it ran great on the highways and buzzed along the back roads with plenty of pep. I've had it for 2 years and I assure you it been through more then any street driven bus will ever do. Motors been purring good and only issues I've had is from me going a little too extreme offroading. Mileage and such i can't really say is the best now since its running 38.5 tall tires and has 10in of lift. I still drive it everywhere and have taken it on 3 hour road trips its just not what most people would consider a "comfy" ride anymore.
https://imgur.com/gallery/zJcHm
08-23-2018, 07:06 AM
#36
Coachwork: Startrans
Engine: 5.4 litre
Rated Cap: 12
That bus is extremely cool...
08-26-2018, 11:43 PM
#37
Did you buy it with 4WD, or did you add it?
I dont think i have ever seen a 4WD school bus, so i assume you added it.
08-27-2018, 05:41 AM
#38
me and my buddy built it 2 years ago. was just a normal church bus when i got it
08-27-2018, 05:42 PM
#39
Year: 2006
Coachwork: Collins
Chassis: Chevrolet Express 3500
Engine: Duramax
Just scanned your build thread and looked fun.
For those without BoogerBus's skills and resources, 4x4 Van Conversion kits makes a kit that works as seen here
