Old 10-22-2011, 11:36 PM   #1
Chassis: Ford e-450
Engine: 7.3L turbo diesel
Rated Cap: 16
how to jack up a shorty
what kind of jack should I use to be able to change the oil, etc. I have a 99 ford e450 24ft shuttle bus. diesel, dually. theres not enough room under it for me
mcmasterp is offline   Reply With Quote
Old 10-23-2011, 12:27 AM   #2
Stuff's Avatar
Coachwork: Goshen
Engine: 7.3
Rated Cap: 25
Re: how to jack up a shorty
something rated 3-4 ton or more.
Old 10-23-2011, 07:30 AM   #3
Chassis: Ford e-450
Rated Cap: 16
ok thanks!
Old 10-23-2011, 09:37 AM   #4
Personally, I wouldn't crawl under a jacked up bus until it was sitting on one or two solid jack-stands. Don't have that much faith in Chinese hydraulics.
Old 10-23-2011, 11:00 AM   #5
Stuff's Avatar
Coachwork: Goshen
Engine: 7.3
Rated Cap: 25
that is very true! so a good equally rated jack stand and a plank for footing would be recommended to
Old 10-23-2011, 09:15 PM   #6
Chassis: Ford e-450
Rated Cap: 16
oh yeah, I should have said that I have a pair of 6 ton jack stands. I would NEVER get under any vehicle without using them.
Old 10-24-2011, 01:37 PM   #7
Engine: DTA360
Rated Cap: 16
A bottle jack will do what you need... The guys that change tires on fleets usually carry a bottle jack that is air over hydraulic and plug it into their on-board air... I plan on getting a nice one for the bus and carry a unmounted tire or two... I've mounted and dismounted hundreds of tires... It may take a little bit of time, but I'll be back on the road anywhere I happen to be...
dirtygoat is offline   Reply With Quote
Old 10-26-2011, 11:52 AM   #8
Stuff's Avatar
Coachwork: Goshen
Engine: 7.3
Rated Cap: 25
that would be very sweet to have. My grandpa used to carry a floor car jack. sure they dont roll worth a darn on the ground but thats the point!
Old 10-29-2011, 11:00 AM   #9
Engine: 7.3 diesel
I have me a 20 ton bottle jack in the bus. In the truck I have a 10 ton bottle jack since it's original didn't hold real good and bent it self to the scrap yard. At the house a big 5 ton floor jack that can not just be picked up by one person. I have loaded it up however up a ramp or chair lift.
When using a bottle jack it is a good idea to have some 4x4 to block other wheels.
Old 10-29-2011, 11:54 PM   #10
Chassis: Ford e-450
Rated Cap: 16
My bus is at the shop being inspected at the moment so I can't go check but I thought bottle jacks would be to tall to fit under my bus. I found most 10-20 ton bottle jacks to be around 8.5" tall minimum.
I found a 10 ton bottle for $27 and a 4 ton floor jack for $110. I'm lazy AND cheap so it's hard to decide.
The Gypsy Jack Conversion - Take 2 mosdottir Skoolie Conversion Projects 6 01-21-2014 06:11 PM
changing tires w/o a jack tylermag Conversion Tutorials and How-to's 6 08-04-2013 08:05 PM
What type of jack/method do you use? heathnlaura Conversion General Discussions 9 06-26-2013 03:04 PM
How to Jack up front of bus? jaredg Mechanical and Drivetrains 1 09-24-2010 10:46 AM
What size bottle jack for bus? bdavis441 Everything Else | General Skoolie Discussions 5 10-17-2007 10:05 PM
