Old 05-08-2019, 07:12 PM   #1
I pulled the trigger on my shortie today
After much research, being outbid, having a bus sold out from under me etc etc I got one today. It’s a 2001 GMC 3500 gas with 5 windows and about 58k miles.
The current problem is that it is dripping brake fluid from one line. I can add fluid and drive it for awhile. However there’s three hours of hills between where it is and my house. Does anyone know of a “flex seal” or “jb weld” that will hold the leak for a ride home.
The man I bought it from is going to try and plug it this weekend. I hope to go out next weekend and bring it back.
Also anyone know about how much it would be to have all the brake lines swapped out?
Outlawfarmer is offline   Reply With Quote
Old 05-08-2019, 07:21 PM   #2
Chassis: G30~Chevy cutaway
Engine: 5.7/350 Chevy Vortec
A temporary roadside breakdown fix could involve pinching off the offending brakeline with vicegrips to stop a leak.
This type of fix disables the braking to whichever wheel it goes to.
I would try to fix it if it were on a front wheel rather than pinch it off, but it could also be done in front to get home.
No adhesive or epoxy chemical fix would work reliably on a leaking brakeline.
Good luck and drive carefully if you go that route...
Old 05-08-2019, 07:23 PM   #3
Thanks I was just watching people do that on YouTube. It one of the back wheels.
Old 05-08-2019, 07:35 PM   #4
HazMatt's Avatar
Chassis: IH 3800, 8 window
I suspect, if 1outta 4 is gonna fail, better it isn't a steer tire, and the wonky handling that could result.
Cute bus, kudos!
Can the offending line be isolated and plugged at the brake manifold? Prolly not worth the effort, since it sounds like a seam is splitting, and'll need replaced any way.
Might consider doing 'em all, unless there's evidence of a trauma to the bad line, only.
My dos centavos...
Old 05-09-2019, 12:59 AM   #5
As haz.matt.1960 said, you have a really cute bus!
Old 05-09-2019, 05:57 AM   #6
HazMatt's Avatar
With that short body, the rear looks disproportionately large.
Then again, I am an aficionado of big butts...
Old 05-09-2019, 09:14 AM   #7
weboughtabus's Avatar
Coachwork: Corbeil
Engine: Ford PowerStroke Diesel 6.0
Rated Cap: GVWR 11,500
I have a younger Ford cousin to this bus - 2004 Ford/Corbeil. Mine has a wheelchair lift and side door, too, but otherwise I'd imagine there are a ton of similarities. Major pros for Corbeil buses are the extensive use of screws, as opposed to rivets, and ALUMINUM! Aluminum body panels, ceiling skins and floor pans mean you have significantly less to worry about with regards to rust.
I obtained the a set of (nearly complete) wiring diagrams from Collins (purchased Corbeil a few years back) that are shared here:
Corbeil Electrical Schematic
Corbeil Multiplex Schematic
Best of luck with your build! I'm no expert, but I may have answers if you have questions about your new rig!
charlotte_thebus on Instagram
weboughtabus is offline   Reply With Quote
