Old 02-17-2018, 09:58 AM   #1
International Thomas Vista 3600?
Calling all short skoolie experts! We've decided to convert a short bus for road trips up to nine months per year. The Thomas Vista 3600 seems to be just the right size for our needs. As luck would have it, a nearby school district has several being auctioned on publicsurplus.com.
They are all 1998 with T444E diesel engines and Allison transmissions. They all have mileage of 200K or less.
We would love some feedback on the suitability of this bus platform, the longevity of the drivetrain, and a reasonable price to pay. Any comments would be appreciated. Hope to see you all out on the road someday soon. Thanks!
pborowski is offline   Reply With Quote
Old 02-17-2018, 10:01 AM   #2
Check out Brokedown's build/travel thread.
Josh and Hillary have been all over the country in a Vista with the T444e and 545.
Good luck!!
Old 02-17-2018, 11:43 AM   #3
jjhwick119's Avatar
Engine: Dt466e
Rated Cap: 71
i was looking at those too. noticed they are all hydraulic brakes though instead of air, fyi. not sure if all are made that way
jjhwick119 is offline   Reply With Quote
Old 02-17-2018, 05:51 PM   #4
jjhwick119's Avatar
Engine: Dt466e
Rated Cap: 71
Did they disappear? Can't find em looking on my phone, but I know I saw em last night
Old 02-17-2018, 06:58 PM   #5
brokedown's Avatar
My Vista is hydraulic but I've seen ads for full size ones with air. I assume air was available for short versions as well.
The T444E and AT545 are very common and well known. AT545 is the "baseline" transmission that people hope to do better than but often settle for anyway. It's a reliable platform, just don't overheat them.
Old 02-17-2018, 06:59 PM   #6
simonsteve's Avatar
Chassis: International 3600
My bus is a vista shorty. No wheel wells made things easy for interior design, and gives lots of space for tanks underneath. The ride is a little rough though. Driving is pretty easy, being right over the front axle and having a short nose makes it very maneuverable.
Sent from my SM-G892U using Tapatalk
simonsteve is offline   Reply With Quote
Old 02-17-2018, 07:57 PM   #7
I can still see them from here jjhwick119. All 4 expire in about 12 days.
Old 02-17-2018, 08:03 PM   #8
Thanks everyone for your comments. Does anyone have an idea what a 1998 Thomas Vista 3600 with 200K miles should be worth?
Old 02-17-2018, 09:41 PM   #9
Robin97396's Avatar
Not enough information without making a lot of assumptions.
Depending on condition, I'd be in at about $2,500 if it all looked good. I'm assuming it's got a small enngine and a 545. Decent enough tires that you don't have to visit the tire shop to feel safe taking the bus out for a stretch. Hydraulic brakes are a no go for me, but we all have our preferences. So, it depends.
Robin
Nobody's Business
Old 02-17-2018, 10:34 PM   #10
A Vista is a an odd sort of a duck of a bus. It is technically a Type 'B' but it is usually classed in with Type 'C' buses and was originally sold as a sort of poor man's Type 'D'.
The big advantage for the operators when the bus was sold as new was you could get more seating positions in a given length of bus compared to a Type 'C' at a reduced cost to what the same number of seating positions would be in a Type 'D'.
Fast forward many years, most of the Vista buses I have seen were spe'c'ed as special needs buses so they were generally shorter buses, many of which had lifts.
While I am not a big fan of hydraulic brakes in a bus for a lot of reasons, the hydroboosted four wheel disc brakes used in the IHC bus chassis are some of the best brakes ever used in a medium duty truck or bus. By the late '80's all of the bugs had been worked out and operators were getting 2x to 4x as many miles out of a set of pads and rotors as they ever got out of the hydravac boosted four wheel drum brakes as found on Loadstars and early S-series chassis. In the near models the brakes came with ABS which is even better (I doubt the Vista buses at which you are looking would have ABS).
The T444E and AT545, which is the most probable power package, is a very serviceable and reliable power package good for close to 300K miles in school bus use--if the bus has seen reasonable preventative maintenance. The good thing about the IHC chassis is reasonable can be a pretty low bar since the chassis were so simple and very forgiving. Since it is a 1998 it just might have the MD1000 or MD2000 series transmission which will have at least one OD gear. If it has a touch screen gear selector is won't be an AT545. If it has a 'T'-handle with RND321 it is an AT545. If it has a 'T'-handle PRNOD32 or some other variation that has a Park position and/or more than D321 then it has the MD transmission. The MD transmissions are preferred but the AT545 in such a small bus would not be a that bad.
The Vista most probably does NOT have 12" windows. I don't ever recall seeing a Vista with the high headroom options. That is not to say they didn't come with that option.
Most of the lift equipped Vista buses I have seen had the flat floor option which makes building out your "house" much easier as you have a completely flat floor from the standee line to the back of the bus.
At the right price it could be a very good choice for you. Good price in this instance would be under $4K if the tires are newer with good tread. Good price with older tires with less than 40% tread would be $3K.
And of course if it has any rust that has flakes coming off the frame rails, or floor stringers, or any body rust that has a hole through any panel is most probably a no sale.
Good luck and keep us posted as to your progress.
Old 02-18-2018, 01:51 PM   #11
brokedown's Avatar
I bought mine for 4200 from a bus company. It's a 5 window with dual air, was driving kids to school on Friday and I drove it home on Saturday. No real rust problems, runs very well.
The hydraulic brakes on this bus are awesome. They feel great and have incredible power. My new bus has air brakes and I much prefer the brakes on my Vista.
Overall the bus is really easy to live with. No worries about getting in and out of parking lots (drive-thrus are still out of the question though!) and it's a serious solid platform.
Tha AT545 is the least good part of it. I still put 30k on it last year doing a lap around the country.
Old 02-19-2018, 09:17 AM   #12
simonsteve's Avatar
I bought mine off of Craigslist for $2500. 105000 miles, well maintened and good tires, but there was some body rust that needed repair.
Old 02-19-2018, 09:27 AM   #13
jjhwick119's Avatar
Engine: Dt466e
Rated Cap: 71
I'm also considering a lap around the lower 48, had been looking at bigger buses but have been thinking about going smaller now instead (5-8 window). Do you think this bus would be cramped with a shower / toilet / bedroom / kitchen / pull out couch ? Itll be just me, maybe a dog. I know it depends on the person as far as whats considered cramped, just wondering about your exp. Still considering going without the bathroom stuff, but having it would be really nice
Old 02-19-2018, 11:45 AM   #14
Thanks everyone for the 'street value' feedback. It's been really helpful! This community is awesome! I'll be bidding on some buses this week!
Old 01-06-2021, 07:20 AM   #15
Year: 1974
Chassis: "Atomic"
Engine: DD 8V71
Instead of starting a new thread, it made more sense (in my addled brain!) to add to this one...so anyone searching for Vista info might find it more easily.
I looked at a Thomas Vista yesterday and checked it to see what engine and transmission it had. The Vistas are damned cute buses!
Name:	photo_2021-01-06 06.08.00.jpeg
As mentioned in the earlier posts, there were several possible combinations of engine and tranny. The only two tranny options I know of are the AT545 and the MT643, with the MT643 being the "more desirable" option. How do you tell what it's got? There's a good thread here on Skoolie.net about "how to tell a 545 from a 643" and good info above, too. And here's what I found on this particular bus, in case it adds some helpful detail.
First, the transmission - that's the easiest to tell, just by looking. The MT643 has a flange at the back where the case is bolted together...the 545 is "slick." Here's the manual page that shows them:
Name:	Screen Shot 2021-01-06 at 5.44.24 AM.png
And here are the shifter options, which may also help in identifying it. But, really, looking under the bus it's pretty easy to distinguish between the two transmissions.
Name:	photo_2021-01-06 05.43.37.jpeg
The hardest part may be identifying the engine. I can't tell, just by looking at the front of the engine, what it is. The hood on these is short and you only get to see the front few inches of the engine. The engine identification sticker is on the passenger side and is most likely covered in grime. Reach in and wipe, vigorously, on top of the valve cover and you may be rewarded with this.
Name:	photo_2021-01-06 06.08.13.jpeg
So, in this particular case, it's a 175hp 444E engine with an AT545 transmission (it had the slick case, not the 643's rear bolted case flange).
rossvtaylor is online now   Reply With Quote
Old 02-11-2021, 01:15 PM   #16
Need Vista transmission advice!
Hi everyone! I’m so glad I found this thread because I’ve been killing myself with research about the Vista I’m getting ready to buy next week, and so many of my questions have been answered here already!
It’s kinda a rare bus I guess (like someone else said above) and I haven’t been able to find a ton of info about them online. Anyhow, thank you all so much for all the input so far!
The bus I’m looking at is a 36 ft. 1995 Thomas International Vista, 3600 with the T444E. It has about 175k miles, but that’s an estimate. It’s already built and has just about everything we’ve been searching for and it’s only slightly over budget so we are really excited! We have already purchased flight tickets to go pick it up next week! However, I still have just a few concerns, mainly about the transmission.
The long and the short of it is that based on my research I assumed this bus would have the Allison AT545 or the MT643, and I hoped for the MT643. I had a dealer run the vin for me and I was surprised when they said it was born with an MD3060. I then researched the MD3060 and got pumped because it seemed like a superior transmission over both the AT545 & MT643, especially if we could get the 6th gear unlocked and have it recalibrated to increase speed and horsepower. I read that the MD3060 has 275 HP and that if unlocked it could be increased to 300 which would be awesome compared to 175. The specs on the MD3060 also say that the rated input speed is 2,000-2,800 rpms.
The problem is that I continued digging around....
I got in touch with two other sources who ran the vin for me and both of them told me the bus was born with an AT545. Bummer! Now I don’t know which information is correct & the bus is currently parked over 1,000 miles away. It seemed unusual to me that it would have an MD3060 when the dealer told me that. The dealer who told me that is not the seller or related to the seller in anyway, by the way. Does anyone have any input on the MD3060 in this specific bus or how to really confirm exactly what’s in it? I don’t want to ask the seller to drive to where the bus is parked and crawl underneath to look for a serial # on the transmission if I can help it. I guess I could ask him about the type of shifter it has.
Another thing... The bus I’m looking at it tops out at 55 mph I’m told. The seller said he thought there was a governor on it. He also said cruising on the highway it’s like 55mph-57mph max, downhill it will increase to maybe 65 and uphill it’s more like 45mph. So now I’m not sure if maybe it’s got the MD3060 with a locked overdrive or 6th gear or if it’s got the AT545 and that’s just all that the bus has got.
Lastly, it seems like most of the Vistas were shorter buses, this one as I said is 36 feet long, bumper to bumper. I’m not sure which class this puts it in? It has 11 windows, I guess 12 if you count the drivers window and front door. I was told that the Vistas are a really rough ride with a real rattly dash, that the shorter ones weren’t bad but that the longer ones like this were. Anyone have any input on this?
Sorry for the super long post but I just really need all the guidance I can get. This is our very first bus and a huge investment for us. Thanks so much CNN in advance and we are so excited to be a part of the skoolie community! ♥️ 🚌
FBCD7E3E-5D77-43DB-9475-C92590976CB6.jpeg   DCD6B84D-D9CD-49BC-90C7-6D8408A0A604.jpeg   097274C9-517D-426E-821A-CE707417872C.jpeg
Let’sGO! is offline   Reply With Quote
Old 02-11-2021, 04:47 PM   #17
Unless someone went WAY out of their way and swapped a 3060 into it I'd say there's no chance in hell otherwise.
Its almost surely a 545. Dealers have been inundated by prospective skoolie noobs asking lots of questions and they've discovered the 545 is a no sale for a lot of people.
I think they're just telling you what you want to hear to sell a bus.
People will disagree with me on this- But the vista is THE worst "modern" bus to buy. The jarring ride, engine noise, engine heat, leaks, etc.... They were the bottom of the barrel. And still are.
Old 02-11-2021, 04:47 PM   #18
Mountain Gnome's Avatar
Chassis: TC1000 HandyBus
Rated Cap: 26 foot
Transmissions do not create HO (horsepower), they handle it. Your motor creates the HP, and it may be upped via a computer software upgrade, to some extent. At some HP level (others can tell you more about what that level is), you have to upgrade the fuel injectors to deliver more fuel and sometimes other internal motor parts to handle the greater power. If the tranny has a rated HP that may be "upgraded", I am guessing that max number is the HP rating that the tranny computer will either unlock the torque converter, or de-couple the motor from the drivetrain to prevent the tranny from excessive premature wear or blowing up
I think you are not understanding the rated input speed for the MD3060. I don't even know what to say about that. I am guessing that is the input speed needed to keep the tranny happy when the motor is making maximum HP. I have also heard that 2800 RPM will be the maximum speed it is safe to spin (but 2000 RPM ain't gonna be close to that, so I think the rating you refer to has more to do with HP).
Yes, the shifter will tell you. The 545 and 643 have T-shifters (don't remember the difference between those two offhand), and the 3060 has a pushbutton panel.
I also heard (on this site) the Vistas ride rough. Maybe what you heard is exactly correct for that model bus, but in general, longer vehicles ride smoother, shorter ones bounce a lot (like mine).
Old 02-11-2021, 04:53 PM   #19
Ask the seller for clear pictures of the transmission and tell him to show the data plate if he wants you to believe him.
Also- thats a low headroom bus. That's a big points deduction for me. Go for the high headroom models.
Old 05-05-2022, 08:50 PM   #20
Wiring the exterior lights on this big girl
Hi, if anyone here would be awesomely kind in taking a look at their exterior lights wiring with me I would really appreciate it.
I’m currently in the process of get the rear lights and running lights operational before inspection.
I have a 1998 Thomas Vista 3600 T444E.
Please halp!
Busventure is offline   Reply With Quote
short bus conversion, thomas vista 3600
