Old 04-12-2010, 03:32 PM   #31
Year: 89
Coachwork: thomas
Engine: 7.3 diesel
Re: Introducing my first bus
I just pressure washed mine, let it dry out, plywooded the floors and have put down laminate flooring.
after it dried it was good to go.
hit walls,windows and ceilings.
how much room do you have behind the drivers seat, just wondering?
see my conversion at http://www.skoolie.net/gallery/v/Skoolies/Putters+Bus/
putterspitt is offline   Reply With Quote
Old 04-12-2010, 06:33 PM   #32
Stopbit's Avatar
Chassis: Chevrolet B7T042
Engine: 6.6L Turbo CAT 3116
Rated Cap: 24
I have 15 feet behind the driver and of course the standard of a little over 7.5 feet width. Not alot of room but should work fine for my plans of a weekend camper.
Follow my conversion at http://stopbit.blogspot.com/
Picture Album http://www.facebook.com/album.php?aid=2 ... d5dc5db538
Stopbit is offline   Reply With Quote
Old 04-13-2010, 03:00 AM   #33
Year: 89
Coachwork: thomas
Engine: 7.3 diesel
then our buses are the same size.
I am gonna go with the Cockabus layout.
no water or sewer or toilet. just a little party bus.
Old 04-13-2010, 08:48 AM   #34
Stopbit's Avatar
Rated Cap: 24
I was planing on using a shower/toilet combo but may just go with a porta potty, small fresh and grey water tanks and outside shower.
Old 04-13-2010, 09:13 AM   #35
busdriver_phil's Avatar
Coachwork: AmTran RE
Originally Posted by emberglow
Originally Posted by Stopbit
Thought about taking the lock off the fuel door which I don't have a key for either. It has "025" stamped on the face of the lock.
Figured it would be too easy for you and I to have the same key code. Guess only the S&S RVs are all keyed alike then..
Let me guess...CH545? That's what most Thomas bodies use. Blue Birds usually use the LL25. I'm not positive, but you should be able to use the key from any newer Blue Bird on those. Try a dealer, or even try asking a school district or bus company that has some Blue Birds, they might have some extras laying around.
The conversion of Miss Euphegenia, a 1999 AmTran RE: http://www.skoolie.net/forum/viewtopic.php?f=9&t=5704
Old 04-18-2010, 07:01 PM   #36
Stopbit's Avatar
Rated Cap: 24
Had to order a new lock($102) for entrance door from http://www.kansastruck.net since the old one come to find out had super glue in it. Used my angle grider with wire brush to break off the loose rust and then power washed the inside. Some guy showed up and asked to take all the metal from my dumpster which made my mother happy because that meant there was more room for her to get rid of more junk. Started to try and get those reflective strips off but the heat gun didn't seem to help much. Really glad most of the dirty work is done. Also posted a few more pics on my blog.
Old 04-18-2010, 10:53 PM   #37
Stopbit's Avatar
Rated Cap: 24
Even if I could get the super glue out still wouldn't have a key and locksmith was not much help. I'm guessing the lock was super glued a long time ago before I got the bus. Next weekend plan to paint the floor with rusty metal primer and if it dries by Sunday seal all the holes with silicone caulk , lay down red rosin paper,1x3 framing with 3/4"rigid foam insulation, and 3/4" plywood. I do have one question should I thin out the Rustoleum rusty metal primer for the metal floor or just use it full strength?
Old 04-18-2010, 11:17 PM   #38
Stopbit's Avatar
Rated Cap: 24
Thanks for the answer Smitty and plan on rolling and/or brushing it on. Don't have a paint sprayer or air compressor big enough anyway
Old 04-24-2010, 12:50 PM   #39
Stopbit's Avatar
Rated Cap: 24
Got the floor painted with rusty metal primer but it started raining so couldn't work on those stupid reflective tape/stickers today like I had hoped, maybe tomorrow.
Old 04-24-2010, 02:33 PM   #40
jkindt's Avatar
Year: 1981
Chassis: Ford B-600
Engine: Ford 370 Propane
Rated Cap: 48
Looks great. That should help seal up the floor and keep the rust away.
introducing REX. seeking suggestion on roof platform Diesel Dan Short-Bus Conversion Projects 2 07-07-2011 10:00 PM
Introducing the Bolide Bus Bolide-Bus Short-Bus Conversion Projects 5 04-08-2010 11:35 AM
Introducing Locutus. Locutus Everything Else | General Skoolie Discussions 1 02-09-2010 09:42 PM
Introducing myself, and a link to a new Wikipedia article. phillbus914 Everything Else | General Skoolie Discussions 5 02-13-2006 08:58 AM
