Old 02-26-2016, 09:36 PM   #31
Year: 1987
Engine: 6.9L Diesel
Originally Posted by cowlitzcoach View Post
The bolt you were trying to remove is a mounting bolt for the radiator. You really don't want to take it off unless you need to remove the radiator for some reason.
The butterfly's are coolant shut off valves. Since there are two they most likely shut off both directions. But double check it isn't a shut off going to a different set of heaters and not part of the same loop.
There is no need to replace all of your heater hoses unless they are rotten and sweating coolant out of them. Even if you have to cut your hoses off too short you can always splice in a piece with a double ended hose barb connector.
I noticed one thing that should be on your to do list is the air intake hose. The hose goes forward to get cooler air from outside rather than from inside the engine compartment. It will give you better HP if all of the air is coming from a cooler source--the more dense the intake air is the more air the engine will have to use. The more air the engine has to use the more efficient the burn will be. The more efficient the burn the less fuel you will need to do the same work. In other words, a very cheap HP increase.
More good stuff, thank you again! Since my bus lacks HP that will be the first thing on my todo list after re-bolting the drivers seat. The bus goes max's about 10-15mph when going up the hill to my house. On the highway hills it usually doesn't go below 35.
Man, I don't want to sound like a suck up but you guys are like gaurdian angels. I hope I can deliver good pictures and more exciting progress for you guys in the future.
Old 02-27-2016, 09:21 AM   #32
I purchased an IHC/Thomas bus with the T444 engine without the turbo in Grand Rapids, MI to move "treasures" from MI to WA after my mother-in-law passed away.
All the way across the country the bus cruised very easily at 65 MPH with my foot flat on the floor. Even going through the mountains in WY, UT, ID, and OR I was able to maintain speeds of 35-40 MPH. But when I got home to WA and had to go up the last hill before I got to my house I was wondering if it would make it up the hill or not. That hill really slowed me down.
For most purposes I think the gearing of that bus is about as good as it is going to get--enough speed to be reasonable out on the highway while leaving enough hill climbing ability for all but the steepest of hills.
At the end of the day, unless you are willing to spend a lot of $$$ on HP upgrades and all of the other upgrades the higher HP requires it is probably best to leave things as they are.
Old 02-27-2016, 01:46 PM   #33
Minor tweaking will produce a fair amount of extra HP on most diesels without much negative impact on MPG or reliability. Check the various maker forums and you'll find that a couple of turns on most fuel screws can net anywhere from 10 to 30 HP. Bumping up the injectors and turbo will add still more without getting into the crazy zone. Just be sure not to exceed whatever your tranny & brakes can handle
Old 02-27-2016, 03:59 PM   #34
Year: 1987
Engine: 6.9L Diesel
cowlitzcouch: Thank you for your anecdote, it certainly reassures my confidence in the bus.
Tango: I may look tweaks for HP with company of someone who knows what they're doing/or after I put it on after insulation/electricity. For now it's been added to my todo list, and thank you for your advice!
Yesterday, I successfully removed the front plywood flooring and did a little cleaning. I also removed the rear wall that I've been procrastinating along with some disgusting black and yellow wet insulation that was lurking in the walls - this brings attention to the fact I have done very little to water seal the back of the bus.
Anyway no pictures from last night since I felt stagnant progress, tonight I have a few panels to remove in front of the bus, and then some cleaning.
My plan/objectives for the next week (my weeks start on friday and end on Thursday) may go as follows.
1. Empty bus, clean (tonight)
2. Mop rusty floor with apple cider vinegar (tonight/sunday)
3. Scrub rust with metal brush scrubber attachment on angle grinder, maybe scrub walls and ceiling too (sunday/monday)
4. Sweep out rust(monday/tuesday)
5. Mop floors with soap and water (tuesday/Wednesday)
6. Patch holes with rubber flashing tape
7. Paint over floors with rustoleum paint. (unless you guys insist I should use a different coating)
8. Procure insulation flooring Leaning towards (this),R-Matte Rmax Plus-3 1/2 in. x 4 ft. x 8 ft. R-3.2 Polyisocyanurate Rigid Foam Insulation Board-754404 - The Home Depot
9. Procure 1/2 inch plywood flooring.
Your opinions are always appreciated. I'm going to measure the the space between my head and the ceiling later (I'm 6'3"), but I'm thinking 1/2 inch rigid foam insullation for the floor (R value 3.2) with 1/2 inch plywood and liquid nails between the cracks and 1 inch insulation ceiling (less certain on ceiling insulation). The walls will probably get 1-2 inch of insulation.
Old 02-27-2016, 09:14 PM   #35
Year: 1987
Engine: 6.9L Diesel
This just in. I just impulse bought 5 gallons worth of insulating beads from hy-tech. I see what you guys mean about that pricey shipping.
Old 02-29-2016, 05:49 PM   #36
Year: 1987
Engine: 6.9L Diesel
Starting yesterday I have begun a new ritual on my way to work, in my car I yell as loudly as I can "I AM RELENTLESS" "I WILL NOT GIVE UP", I do this to congratulate myself on my continuous progress and remind myself that it will not stop.
Progress updates for the past few days.
Saturday night was a bit rough, our restaurant drains clogged so I had to stay later than usual learning just how slow a rooter does it's job. Anyway luckily I came home to my enthusiastic Nana ready to clear the bus for the rust mopping. To my amazement, we cleaned the bus and mopped her with vinegar and were done by 2am. Last night, I brushed the mop with my metal brush attachment via angle grinder. This was a first for me, the post scrub metal floors resembled my skin after picking off acne: I decided that this is a sign of successfully removing rust.
Afterward I decided to give my ceiling a brief scrubbing because there are black dots which resemble black mold on the ceiling, I really didn't want to do this so I took a beer hiatus so I could talk myself into getting back in the bus, once there I proceeded to yell "make it rain" between each panel. I didn't do a great job at this but I got most of the black spots off the ceiling.
Before
After
The post scrubbing rust spots, not quite as pretty and shiny as I had imagined it would be.
The rust pile
I get off early on Mondays, my goal today is to prep the bus, and maybe go shopping for some metal primer, and give the bus a good clean. I may brush the walls a bit beforehand.
it's a bit of a gamble, but I'm hoping I'll receive my insulating beads on Tuesday. If so I'll be able to give the floors a coat before work on Wednesday, then maybe another on Wednesday night, and then I can begin insulating on Thursday!
So questions as follows, (mostly paint related)
1. Do you have any paint recommendations to mix the insulating beads into or does it not matter? My default plan is to just get some rustoleum primer of something else for steel and mix it into that.
2. Will I benefit with insulating if I coat all the bus with paint mixed with insulating beads? (walls and ceiling)
3. How many layers would you recommend painting? Is it okay to keep using primer for the next layers?
4. Lastly: This seems like a silly question, but would I benefit from painting a layers any time that seems opportune with the paint? such as the on the plywood flooring over the insulation?
If all goes perfectly, the Bus will be insulated and re ply-wooded by Friday morning. Realistically though, I will probably reach this objective sometime between Sunday and next Thursday.
Thanks again everyone!
Also local PSA'S:
If anyone in Washington would like my rear heater, you are welcome to have it, it is currently somewhat weatherproof under the awning of my open garage (it's more of a car shed then a garage).
I am also exchanging sailing lessons, beer, cooked food, and uncooked rice for bus help if anyone is interested. Unfortunately Thursday is the only day I have consistently off.
Old 02-29-2016, 06:31 PM   #37
Robin97396's Avatar
Oh, so you got something against Oregon residents huh?
I've got to admit, my rear heater doesn't really work very well. I'm still not getting rid of it, at least not at this point. Those heater cores could heat a tank of fry oil enough to liquefy it.
I can see your commitment towards your project and I wish I was still that energetic. I can't believe you covered up that uber cheap patriotic original paint job. It does look really nice now. I'm so tempted to put eyelashes on my bus but I'll resist that urge.
I didn't realize you were that close. There is no info available on your profile.
Old 02-29-2016, 07:49 PM   #38
Year: 1987
Engine: 6.9L Diesel
Hey Robin,
First off: I am born and raised in Oregon, and I actually have the highest hopes to move back sometime this summer (it's actually a strong driver behind my motivation). Maybe the rear heater cores could be used for a WVO conversion? Maybe I should keep my rear heater core? I have too much junk for someone with no land.
My commitment towards my project is as questionable as my motivation, I just feel I need to publicly display my "ambition" so I'll feel like a total loser if I flake out or spend an evening without accomplishing. It's a fake it till I make it sort of situation, drinking beer really helps give me a second wind after work though. It absorbs my self pity and turns me into a careless productive machine.
I'll update my profile sometime, I didn't even think about it. Definitely something easy to do while at work.
Old 02-29-2016, 10:08 PM   #39
Robin97396's Avatar
These buses are going to be a work in progress for as long as we have them.
Yeah, I have a tiny problem with trying to keep everything. It took me two weeks to set this bus up the way I wanted it, then I've spent the past three weeks slowly removing many things that aren't necessary. It's a painful process.
As if you're not busy enough already you sound like you'd make a good home brewer. I took it up as a hobby but I've never been a drinker. Luckily there are enough neighbors to help drain my kegs before it gets stale. It doesn't really get stale, it just looses the hop flavor by about 5 years. There's nothing like a good hefe with a jacked alcohol content.
Old 03-02-2016, 10:54 PM   #40
Year: 1987
Engine: 6.9L Diesel
Robin, that sounds like a good hobby to pickup if I can make the space, but first I gotta figure out how to downsize enough to move into my bus some day!
Progress for the past few days has been slow and counter productive. Hindsight 20/20 I would not recommend "the rust soak" that I performed a few days ago, it just made a huge mess. The water scrub also didn't go as well as it did in my mind, but it was nice seeing the bus not covered in brown rusty vinegar mud last night.
I found a few leftover rust spots that I brushed off last night, tonight will be another cleaning night and tomorrow will be some shopping/painting the inside assuming I get my insulating beads by then.
After some brief delayed research, I've concluded that my insulating will be delayed a week due to the uncalculated drying time of oil based paint.
Question: Is it within my best interest to drill holes before insulating the floors or will I be fine drilling holes for my battery bank/water tanks after insulating the floors? I ask because I struggle with making measurement related decisions ahead of time.
