Old 02-22-2017, 07:28 AM   #71
Year: 2005
Coachwork: BLUE BIRD
Engine: FORD 6.0l
Rated Cap: 29
[/URL][/IMG]
Thurm2590 is offline   Reply With Quote
Old 02-22-2017, 07:47 AM   #72
Dang, nice man!
I like that welder/trailer!
Roll Your Own Build Thread
Old 02-22-2017, 09:18 AM   #73
awesome use of space!!! just be cvareful about airflow on that A/C.. those things need all the help they can get to not run up the head pressure and shorten the compressor life.
definitely liking this build!
Old 02-22-2017, 05:58 PM   #74
sdwarf36's Avatar
Coachwork: Champion
Chassis: Ford e-450
Engine: 7.3 Powerstroke
Nice MG-A . (I've restored a few of them.)
Old 02-22-2017, 08:11 PM   #75
Year: 2005
Engine: FORD 6.0l
Rated Cap: 29
[/URL][/IMG]
Old 02-22-2017, 08:11 PM   #76
Year: 2005
Engine: FORD 6.0l
Rated Cap: 29
[/URL][/IMG]
Old 02-22-2017, 08:13 PM   #77
that looks like a great NASCAR bus!!!
Old 02-22-2017, 08:16 PM   #78
Year: 2005
Engine: FORD 6.0l
Rated Cap: 29
Yea I'm hoping the air has plenty of flow the only possible restriction could be the 2in height of the deck boards, other than that it should have plenty of flow. I'm hopefully nearing the end, although I know it will never be done 100%. There will always be something to do. I have to finish up some electrical work, run the fuel lines for the generator, get the airflow correct for keeping the generator cool, and then move on the the paint. I'm going to attempt it my self as I have a few friends that are good with body work. As of now I'm planning on going all black with black rims.
Old 02-22-2017, 08:18 PM   #79
Year: 2005
Engine: FORD 6.0l
Rated Cap: 29
Oh yea that's what it will be used for mainly, going to the races.
Old 03-17-2017, 10:03 PM   #80
Year: 2006
Coachwork: Starcraft
Chassis: E350
Rated Cap: 12 Pas; 1 W/C
dimensions
Just curious on what the dimensions of the interior is on a 5 window Minibus.
I read somewhere that its 2.5' feet per window for a standard bus, but I wasn't sure if it is the same for a minibus. If it is the same then it would be about 12.5' feet. I am itching to do a project but under 12 feet would be too small. ideally 15' would be perfect. That would be a 6 window mini if they make one that size.
Thanks
the bus looks good, did you finish or stop for the winter
bry899 is offline   Reply With Quote
