Old 10-16-2011, 07:55 AM   #11
Engine: 350 CI
Re: Just getting started on short bus.
Originally Posted by Motobus
What kind of mileage do you guys get with these little chevy buses?
Not so good so far... 5 MPG. Probably will do a tune-up this winter and hope for better.
Han Solo is offline   Reply With Quote
Old 10-30-2011, 01:40 AM   #12
yugogypsy's Avatar
Year: 1965
Coachwork: Ford/Willock
Engine: Doesn't have one
Rated Cap: 16 passenger
Nice looking bus, I'm looking for a Dodge about the same size (I am a serious Mopar nut)
Okay, a Mopar nut who owns a Ford bus and a Mercedes Transporter van, but both were free so I can't argue price, every Dodge I look at has a serious $ price tag I can't afford just now.
Even my '87 Caravan needs $600 worth of front end and brake work--with no guarantee the valve guides are going to last.
Oh well, the smoke repelled the mosquitoes during the summer
Take Care
Lois
yugogypsy is offline   Reply With Quote
Old 11-07-2011, 12:24 PM   #13
Engine: 350 CI
I had a small 110V window air conditioner that I thought would be perfect for this bus. Yesterday I tried fitment in one of the side windows and it's good. I don't think I'll leave it in while rolling down the road but the window that it's going into has a cabinet below and I can strap the AC unit on top. When I arrive it will just be a matter of opening up the window, pushing the AC unit into place and firing up the portable generator. Should only take a few minutes.
Old 11-07-2011, 04:01 PM   #14
TheRainbowBoxer's Avatar
Engine: 5.9 Cummins 12v
Rated Cap: 78 Passenger
A friend of mine did that same type of setup in his S&S camper. He pulls the AC in and it rests on the countertop. When he gets where he is going he pops it out and fires it up. Works pretty good for him.
-Dan
"What's the matter Col Sanders? Chicken?" -Dark Helmet
lu·di·crous [loo-di-kruhs]
adjective
causing laughter because of absurdity; provoking or deserving derision; ridiculous; laughable
viewtopic.php?f=9&t=11840
TheRainbowBoxer is offline   Reply With Quote
Old 11-07-2011, 10:14 PM   #15
Year: 99
Coachwork: GMC
Engine: 350
Rated Cap: 21
I've got a 99 similar to that and I'm getting about 11-13 mpg.
It's not how you pick your nose - it's what you do with the boogers that counts.
A man with a gun is a citizen...A man without a gun is a subject.
68camaro is offline   Reply With Quote
Old 11-08-2011, 09:49 AM   #16
Stuff's Avatar
Coachwork: Goshen
Engine: 7.3
Rated Cap: 25
local guy has a similar bus that he sells mini donuts out of. guy has 2 ac's (cause of the fryer) and they are mounted on cabinet retracting rails and then he has a plywood cover the slides into the window when not in use from the inside.
Old 11-19-2011, 12:49 PM   #17
Engine: 350 CI
Had some time to do a little work this morning. Tune up parts coming tomorrow. Pulled air filter housing and guess what... no filter
Sprayed some Sea Foam into the carb to loosen the valves and tomorrow I'll shoot some carb cleaner. It appears the choke was sticking and that's getting better. The damn thing has got a four barrel Holley! Hopefully the fresh plugs, wires and distributor cap will smooth it out even more and help the fuel consumption. It also has some rust on the drivers floor pan near the edge of the engine compartment. I trimmed the hole and fabricated a sheet metal "band aid". I'll pop rivet that on with some silicon to seal out the elements. Not exactly the right way to fix a floor pan but it will do the job for now and I've already got all the materials so zero cost
Old 11-19-2011, 01:10 PM   #18
freakn's Avatar
If you can, find a rochester carb for your bus. They are a better choice for economy. Holleys are great for straight performance but use more fuel, also check your vacuum advance inside the distributorm make sur it holds vacuum and that it is plumbing right to constant vacuum on intake manifold. That will also help your mileage. Cheers
Living the dream in the Kootenays
freakn is offline   Reply With Quote
Old 11-19-2011, 05:23 PM   #19
sdwarf36's Avatar
Coachwork: Champion
Chassis: Ford e-450
Engine: 7.3 Powerstroke
I had a GMC cube van for many years as my race hauler. It had rot holes in the same place when I started with it. Its not structural in any way.
The average mileage I got was 8.5 (going to + from the hills of Vermont.-loaded to 10k lbs.) A bit better when i was racing down south + traveling on flatter terrain.
Make sure you keep your new plug wires clear of those headers-I've melted a few.
Old 11-21-2011, 03:18 PM   #20
Engine: 350 CI
Got the tune-up done and put on the floor pan band aid. I noted while I was working inside and it was raining outside, that there's small leaks coming down the inside of the side walls at the front of the drivers compartment. I've seen that before in older cars were the drain holes in the windshield wiper pan under the front windshield are clogged. So I'll assume there's some kind of drain tube on either side of that pan that terminate somewhere under the truck. If I can locate those, I'll force some compressed air up them and try to stop those leaks. That's what's coroding the floor pans with rain water pooling around the engine compartment and under the drivers seat. I'll probably also pull that drivers seat, clean, treat and paint that area before it corodes much more.
Getting Started mjh2901 Conversion General Discussions 5 06-27-2014 01:09 AM
Just getting started! Anthony Everything Else | General Skoolie Discussions 1 06-19-2012 10:06 AM
Getting Started kaelanda Everything Else | General Skoolie Discussions 7 01-06-2012 07:45 PM
maybe you folks can help me get started Captian Zack Conversion Tutorials and How-to's 1 06-09-2010 07:22 PM
Getting Started... Jody Titles, Insurance, Registration and Money Matters 10 04-24-2006 07:34 PM
