Old 11-16-2016, 06:15 PM   #31
I need to figure out how to make that work on double outswing doors.. my bluebird has a lock built into the school door on it so that one is easy..
Google images:
Old 11-16-2016, 07:26 PM   #32
what stops somebody from breaking the little windiw, reaching in with a wrench and just unscrewing the lock?
Old 11-16-2016, 07:39 PM   #33
Or slipping a padlock on the outside while you're inside...
I'd rather have something I can operate from both sides
Old 04-03-2017, 06:53 PM   #34
Newbies's Avatar
I drilled a small hole in the tongue of the existing latch for the rear and wheelchair doors and we simply insert a pin (actually a blunted nail) into the hole. Once you do that, no one can move the lever to open the door from the outside. You can't unlock them from the outside, but that is why you have the drivers side and righthand doors.
Newbies is offline   Reply With Quote
Old 01-10-2019, 02:26 AM   #35
geminusprime's Avatar
Chassis: Vista 3600
Engine: DT466E / AT545
Roof Hatches
geminusprime is online now   Reply With Quote
Old 01-29-2019, 05:22 AM   #36
You may have figured this out already but I saw a great idea on IG from OrgoTheBus https://www.instagram.com/p/BtFA-wHnnir/
thecatbus is offline   Reply With Quote
Old 02-02-2019, 11:31 PM   #37
I thought this was the only way to go once I saw this. I will utilize the raised box that houses the handle mechanism from my drivers rear door. It is already drilled for the tumbler. My deadbolt should be here Mon. and I'll weld everything in place.
Old 02-03-2019, 10:16 AM   #38
haz.matt.1960's Avatar
Chassis: IH 3800
Rated Cap: 32..?
I'm not a gadget guy, Low-Tech is my comfort Some!
For the front, I installed a hasp. Padlocked at all times: for obvious reasons when I'm away, and to not get locked in by a prankster when sleeping. Plus, it makes it harder for me to lose the lock...
The back door has a patio slider lock I already had. Not much good for locking the door from without, but that hasn't been an issue. The thumb screw blocks the lever, and lodges tightly onto the guard. Easy peasy!
haz.matt.1960 is offline   Reply With Quote
door locks, security
