07-23-2016, 07:12 PM
Coachwork: Mid Bus, Inc Ohio
Chassis: GMC Savanna 3500
Engine: 5.7 Vortec, GMC
Rated Cap: 22
Lock security for the bus doors?
What are folks using to lock the rear "emergency" exit door and the front 2-part doors?
I'll have lots of expensive tools in mine and want to keep them!
Thanks!
07-23-2016, 07:42 PM
As my grandfather used to tell me, locks are only for honest people. If they want to get in, they'll break a window. Close the front door tight. It's almost impossible to open from the outside. Exit the rear door and lock it with a padlock. I'd do omething more permanent after conversion.
Good luck!
07-23-2016, 07:49 PM
Rated Cap: 22
Good luck!
I may be more concerned than I need to be. I've been working out of a van for years and never had a break-in. I'm thinking I'd use this for the rear door: Master Lock Magnum Security Lock and Guarded Hasp-M736XKADCCSEN - The Home Depot
Did I mention the shortie is going to become a work truck for my carpentry business?
07-23-2016, 08:11 PM
Originally Posted by Hammerhead
Nice. That shorty should make for a great carpentry truck! The Master Magnum is probably as secure as they come. They're used on the rear doors of contractors' vans in NYC. You earn your living with your tools. I understand why you're concerned.
Good luck!
07-23-2016, 08:50 PM
Here's an idea... Simple enough
07-23-2016, 08:53 PM
My door glass & frame strongly prohibit me from using the door lock system I want to use... But, I'm still looking.
07-23-2016, 09:04 PM
Coachwork: Thomsass
Chassis: FreightShaker
Engine: 5.9 Cummins 5 speed
Rated Cap: 2 ATV's and friends
Looked good so I checked out the link, read some of the reviews....there's a demo of a guy picking it in about ten seconds, hmmm not that secure ...my $.02
07-23-2016, 10:22 PM
Rated Cap: 22
If that's the case any lock is obsolete. Most run of the mill thieves aren't professional locksmiths though!
Maybe I could wire the doors to explosives! Just gotta remember to disarm when I open it!
07-23-2016, 11:44 PM
Since I made my door solid, I will need to go with setup like this
But, I am going to the Truck Supply soon to see what they have for narrow stile doors
07-24-2016, 03:52 AM
I ordered these two RV door latches about 6 months ago when I bought my skoolie. They only work with doors up to 1 1/4" thick or so. I had to make a recessed pocket. As such, I just got the first one on my rear door mounted today. They work beautifully though, and the fact that one key works for both is great. When I get around to rebuilding my front door, it'll be awesome.
07-24-2016, 07:08 AM
Rated Cap: 22
I've looked at those online. Why do they have 2 key slots on the outside (no experience with RVs)
Do you have a photo of your rear door install?
07-24-2016, 07:19 AM
Rated Cap: 22
I was thinking of welding the 2 front doors together and use the existing top and bottom post as the hinge -or- get some 1" square tubing and make a whole new door....
07-24-2016, 07:24 AM
for the rear and side doors a house lock works just fine... though I dont yet have any experience with what will happen when winter comes along if i'll have a bunch of water in it and end up with frozen locks..
I just close my skoolie door and jump out of the side door if I want it closed..
sure like any vehicle someone can break in.. I have a Tuffy Jeep safe mounted on the one wall that I can put a couple laptops in. since my bus is internet connected I may get a Simplisafe alarm for it that could alert my cell phone if a break in occurs ...
the batteries and inverter are probably my most vulnerable bits someone would steal.. they have to have tools to get either..
I supoose if someone really wants office Telephones they can get those.. but ive left those on the floor of my Jeep with the top down and doors off... never got botthered...
07-24-2016, 11:43 AM
Found an idea on Lea's bus...
07-24-2016, 01:43 PM
The two key slots are because those locks are both a regular latch and a deadbolt. The regular latch can be locked from the outside and still open from the inside while being locked from the outside. It can't be locked or unlocked from inside. The deadbolt can be locked or unlocked inside with a little toggle and requires a key to lock or unlock from outside. They are really well built and work well. I don't have a picture of my rear door yet. I just mounted it this weekend. When I get one, I'll post it.
07-24-2016, 03:18 PM
Rated Cap: 22
That's a good idea. Looks nice and clean on the outside too!
07-24-2016, 07:34 PM
But...........
An $8.15 RV Master Key will get you in, in 2 seconds
AP Products 015-85001-00 Master Key Red RV Parts
07-24-2016, 07:46 PM
Chassis: HDX
Engine: Cat C7
Rated Cap: 84 passenger
On my side E-door, I drilled a hole through the handle and the safety shield. Then, I inserted a snap-link (cheap carabiner) through the holes. Voila! Instant security. Yes, Virginia, someone tried to enter through that door after I put in that highly effective lock in place. No, they didn't succeed.
For the front doors, I have a length of chain, two keyed-alike padlocks and two eye-bolts.
07-24-2016, 09:37 PM
I used two of the guarded hasp locks for the front and rear doors. They work well enough to slow someone down and keep out curious folk, and i installed a 4 camera surveilance system from nightowl. Again it's good enough to slow someone down.
Will try to remember to post pictures tomorrow.
07-26-2016, 11:56 AM
Here are the door latch pictures I promised.
