Old 02-16-2012, 06:37 AM   #21
Re: Merlin
scott being stupid with the air hose lol.. soo glamorous
we threw the padded plywood in there to get the feel for a little bit. looks legit!!
i know odd size sheets for "RV bunks" can be a PAIN and EXPENSIVE!!! we tried dying some hospital
mattress fitted sheets but it was an epic fail. didn't soak up the dye very well and are VERY thick.
Then had a brainstorm to take a TWIN flat sheet and sew it together to make like a BIG pillow case for the
memory foam we bought. WORKS PERFECT!!
back view. there are not very many pics of us carpeting the walls inside cause IT SUCKS!!! we found it easiest to glue,
staple it, and then press around on it. otherwise you have to hold it and smooth it around. afterwards jus pop the staples out.
"Merlin" our short bus you wanna check out!
levitayelor is offline   Reply With Quote
