07-29-2019, 09:40 AM
#21
Chassis: Ford E450
Yah, they wanted to send out the big tow truck but when I told them it was the equivilant of a E450 RV they sent out the normal truck. Driver told me that he's even put shorties on a bed and towed em that way no problem. The best part of the tow was that it was covered through our AMA membership which covers towing for our entire family.
I'm still working on the plans for electrical. Right now just been running generators with an extension cord. I'm not very good at the whole electrical thing so will need to do more research and figure out exactly what to put in. I've seen some good threads on here, but any advice is welcome. I was pretty proud of myself for installing these LED markers over the weekend:
07-30-2019, 12:15 AM
#22
So cool ... you have an indoor work area!
Congratulations on getting the LED marker lights in place and working.
09-01-2019, 12:50 PM
#23
Chassis: Ford E450
Made some progress this weekend, got all the overhead lights removed and patched up all the holes in the fiberglass. Was definately a bit nervous, but in the end it was pretty easy. Lots of good videos on youtube about fiberglass repair/hole patching. Basic process was to remove lights and eye lids, sand off glue.
Then for the small screw holes I used a Dremel to chamfer the edges, mixed up some epoxy with lots of filler to a peanut butter consistency so it wouldn't run and puttied up the holes.
For the bigger holes, I sanded an oval around them approximately half the thickness of original fiberglass and 12 times the diameter. Then used 4-5 layers of chopped fiberglass mat in shrinking size to build the patch. Waiting for it to dry then I can sand it smooth.
Getting closer to paint!
I have a couple of screw holes in the metal body panels any advice on the best way to fill them?
10-08-2019, 08:24 PM
#24
Chassis: Ford E450
Prepping the bus for paint is quite a bit of work. Didn't help that I had a little get off on the dirt bike ended up busting my wrist and tearing a muscle in my side . Anyways, now that the cast is off and I can move a bit better I've been back to making some progress, currently in sanding hell:
I'm thinking about using the Majik cammo paint anyone on here have any experience with using it on their bus? Never painted a bus (or a car) before, so should be interesting. I've got a line on a 30g compressor and guns so plan to spray it. Hoping to get it to look good from about 20 feet. Any tips, advice welcome.
10-08-2019, 08:46 PM
#25
Good on you for having AAA.
I learned the importance of roadside assistance recently. I broke down seven miles out of Yakima. I got towed back to Yakima for the bargain price of $541.
It was Friday afternoon and after numerous calls to find a shop to work on it we got towed back to town and got a motel room.
Towing, parts, labor and lodging cost totaled around $2500...... Because of a failed wheel bearing.
10-10-2019, 06:22 PM
#26
Chassis: Ford E450
10-13-2019, 09:08 PM
#27
Chassis: Collins
Engine: 6.6L LMM Duramax
Wow I really like the build! I bookmarked your LED headlights you installed... I might have to out those in mine. What led marker lights are you using?
2007 Collins (Chevy Express 3500)
LMM Duramax Diesel with newly rebuilt 4L85E Transmission!
11-05-2019, 10:02 PM
#28
Chassis: Ford E450
Sorry for the delayed response, somehow I unsubscribed to my own build thread. Got the LEDs at Super Bright LED
Product code for Reds:
RMPC-R-LP: Red Pigtail
link to website
11-21-2019, 12:46 AM
#29
Chassis: Ford E450
Painting is complete
This was a much bigger job than I had expected, probably 100 hours. I'll try to outline the steps I took incase anyone cares. In the end I ended up going with a sprayable bed liner from Raptor for a few reasons. I liked the idea of the texture as I didn't have to worry about runs, drips etc. It's has some UV protection and acts like a sealer too so hopefully will last and keep roof leak free. Anyways here are the steps I took:
- Remove decals
- Remove top flashers and eyelids
- Patch fiberglass holes
- Sand fiberglass patches smooth
- Remove front mirror holders
- Patch holes in fender from mirror holders
- Patch holes in body from stop sign
- Sand entire surface of bus to scratch surface
- Wash bus really well
- Clean bus with wax and grease remover
- Mask off windows, doors, lights, etc
- Prime bare metal
- 3 coats of base color (light tan)
- Allow to dry for 5 days
- Sand bumpers
- Scuff lower surface for two tone
- Clean bumpers
- Tape and mask off upper section and etc
- Prime bumpers
- 2 coats of black for lower section
I think that covers it. Now I can say I have painted a bus and I don't wish to paint another. However I am very happy with the result, think it looks great, hope it holds up.
11-21-2019, 02:42 AM
#30
It does look great!
You missed a bit of tape ... on the driver side bumper.
11-21-2019, 06:21 AM
#31
Coachwork: Startrans
Engine: 5.4 litre
Rated Cap: 12
I love raptor liner. Your bus looks great. I just spent 20 hours waxing my bus, should have went with raptor.
02-02-2020, 11:16 AM
#32
greenhorn to forum. just digging thru forum and gathering. your bus is whats lurking in my mind, except not gas motos for me, im thinking ebikes, same idea. great find on bus, love the idea, love to see it unfold, best wishes, best of luck, happy building.
02-03-2020, 10:02 AM
#33
Chassis: Ford E450
Thanks, the garage is great cause you can throw anything in there. Took the family camping last summer and fit 4 regular bikes in there and all our camping gear.
I've not had any time or $ lately to continue the build. But need to get a heat source in it before the middle of March, so will be diving back in here soon. Think I've decided to go with a propex propane heater and 29gal tank mounted under the rear. In order to complete the heater install I will also need to get my battery setup dialed in.
02-05-2020, 04:59 AM
#34
Coachwork: Thor
Chassis: E450
Engine: Ford 7.3L
Awesome build so far.
I'm picking up a bus today if all goes well. It's a 2003 E450 7.3L but not a School bus :-/. Its a paratransit. I've been looking off and on for years and just can't get a good deal on the right school bus at the right time so I'm kind of settling. It has every feature I wanted though.
Sorry for the mini thread jack but I'll be using mine for street bikes, vacations and track days etc. I won't be planning anything quite as nice as yours at first but def love the ideas your giving me.
08-31-2020, 08:33 PM
#35
Engine: 7.3 PowerStroke With 5 speed Transmission
I know this doesnt have to do with your build, but I read somewhere that you ran into Brake light issues, how did you resolve that? New, here and just bought a 2003 7.3 e350 shorty.
Thanks for your help!
09-01-2020, 08:57 AM
#36
Chassis: Ford E450
Welcome! I did have some issues, had a brake light that went out, but it was just the bulb, easy fix just removed the round lens (4 screws) and replaced. I also tripped the main circuit breaker once which killed all auxiliary lights including brake lights. It's easy to reset here is a good pic of it from the manual
09-23-2020, 07:16 PM
#37
Chassis: Ford E450
Scavenged about 30' of large gauge wire from the lift power supply today. Hopefully can reuse for some of my battery bank. Anyone know how I can determine the gauge?
Gonna dive into the electric system soon. I have very little knowledge in this area but trying to educate myself.
09-23-2020, 10:20 PM
#38
Rated Cap: 81
If you measure the diameter this link can show you the diameter of each gauge of wire. The groups of zero’s are 0000 000 00 0 are called aught. So 0000 is also 4/0 or pronounced 4 aught, 000 can be written 3/0, 00 is 2/0 and 0 is 1/0. That was all new to me when I started my electrical system. 4/0 is the biggest, I have some running to my inverter. And my bus battery cables are 3/0 I think.
https://www.rapidtables.com/calc/wir...uge-chart.html
Aught sounds like ott.
09-30-2020, 06:15 AM
#39
Chassis: Ford E450
Originally Posted by Bon Voyage
If you measure the diameter this link can show you the diameter of each gauge of wire. The groups of zeros are 0000 000 00 0 are called aught. So 0000 is also 4/0 or pronounced 4 aught, 000 can be written 3/0, 00 is 2/0 and 0 is 1/0. That was all new to me when I started my electrical system. 4/0 is the biggest, I have some running to my inverter. And my bus battery cables are 3/0 I think.
Looks like its 1/0 or 2/0 best I can tell
09-30-2020, 06:21 AM
#40
Chassis: Ford E450
After lots of reading and learning here's my proposed electric rough in and wiring diagram:
