Old 03-17-2018, 08:08 PM   #1
Rivetboy's Avatar
Moving the fuel tank to the drivers side 1991 tc 2000
This is a 91 handicap bus with the wheelchair lift and a rear emergency and drivers side emergency doors. The tank was on the passenger side and it was moved to the drivers side
The 60 gallon tank fit perfectly between the battery box and the rear spring shackle I did not replace the 500 lb tank guard. . Holes were drilled with 1/8 pilots with final 1/2 holes using a 110 volt 1/2 chuck 6.4 amp 110 volt drillmotor. Not a great task for a cordless. Also, had a cup of oil to dip the bits in. Lubrication makes all the difference. Replaced hose with the same pricey oem hose for the push lock fittings. $200
The silver check valve at the fuel / water seperator was leaking through was also leaking so I replaced it also. Fast $ 66 there. Moved the water/fuel separator forward a foot so as no to kink the supply line like it did when it was bolted right next to the crossmember.
Put 2 each 6 inch long pieces of 1/2" allthread in one of the bottom holes in the fuel tank to frame rail bracket on each side and it worked like a hinge to lower and raise it many times while fitting and notching the floor stiffener.
The 2 stainless pipe fittings were about $25 and the shiny door was $35.
Now the bay on the other side is huge with room for a relocated door and storage.
Fitted the turbo today and new flowmaster muffler.
Just short a couple clamps and a hangar.
Trans cooler is next then wiring and put the radiator in, fill it with fluids and spin it!
20180316_152114_Burst01.jpg   20180316_152128.jpg   20180316_152421.jpg   20180316_152156.jpg   20180316_130809.jpg
Rivetboy is offline   Reply With Quote
Old 03-17-2018, 11:59 PM   #2
Engine: CAT 3208
Rated Cap: 84 pass 36200 gvw
So where did you find that really good looking door?
snonut is offline   Reply With Quote
Old 03-18-2018, 12:04 AM   #3
Rivetboy's Avatar
That door is from e trailer online
Old 03-18-2018, 12:13 AM   #4
Engine: CAT 3208
Thank you.
Old 03-18-2018, 02:42 AM   #5
Jdawgsfanasty's Avatar
Awesome looking job
Jdawgsfanasty is offline   Reply With Quote
Old 03-18-2018, 02:43 AM   #6
I prefer this one though
Old 03-18-2018, 05:58 AM   #7
ComfortEagle's Avatar
Coachwork: Gillig
Chassis: Phantom
Engine: CAT 3208
Rated Cap: 87, says Gillig...
This is a 91 handicap bus with the wheelchair lift and a rear emergency and drivers side emergency doors. The tank was on the passenger side and it was moved to the drivers side...
Lubrication makes all the difference...
Well done.
ComfortEagle is offline   Reply With Quote
Old 03-18-2018, 07:47 AM   #8
nice!!! havin the tank on the left side would sure make it nicer at truck stops too!!
Old 03-18-2018, 08:24 AM   #9
jonb8's Avatar
Engine: 466
I have to move my fuel tank also, so I can relocate the door. Did you have to move the air tank and lines?
jonb8 is offline   Reply With Quote
Old 03-18-2018, 12:06 PM   #10
Rivetboy's Avatar
Hi Christopher,
That was the main reason for me to move it my wife wanted the majority of storage on the curb side.
So it was win win.
Old 03-18-2018, 12:07 PM   #11
Rivetboy's Avatar
No, the air tanks are forward of the left front wheel on this bus.
Old 03-18-2018, 03:41 PM   #12
jonb8's Avatar
Engine: 466
Ok thanks mines directly across from fuel tank... I think I'm still going to move it, just more time.....
