Old 09-07-2011, 10:47 AM   #101
Stuff's Avatar
Coachwork: Goshen
Engine: 7.3
Rated Cap: 25
Re: My 1990 Ford E-350 Goshen Bus
so another "not makes me happy" thing is the steering column.. when i had it to crappy tire (Canadian tire) i had the alt and starter replaced (which work wonderful now) and after that was all done now when i turn the key on everything is fine, but when i turn to the start position there is just nothing there. no spring load or stopping till its really gone far past. I've gotten past this by jumping the starter solenoid under the hood but its annoying. the bus oddly enough did have a command start installed and it kinda works but not really. it turns on, waits for plugs then crank and done. no crank crank crank vroom...
so the great debate.. do i pull the column that is in it, try to find another one with a still working cruise control and tilt steering or do i just put in a bypass starter button?
i had a dodge mini van back in the day that the fusible link had died and i had to bypass the whole ignition then used an old time starter push button like the had on the old tractors. i know that is the easiest because when the command start was unplugged all the wires are right there and would just need to put a couple wires with a spade crimp end on them and plug them in to that old wiring harness...
Old 09-10-2011, 05:35 PM   #102
Stuff's Avatar
Coachwork: Goshen
Engine: 7.3
Rated Cap: 25
just a little update that its being cleaned out! yay! organization and sorting! plan is to head to NS in october. should be cool enough by then. had it out and about today but i dont think the AC was working very well.. might need a recharge..
Old 09-12-2011, 02:28 PM   #103
Stuff's Avatar
Coachwork: Goshen
Engine: 7.3
Rated Cap: 25
yup, im thinking thats what ill do.
also went to put a hitch on yesterday.. dang spare tire holder is in the way... grrr
Old 09-14-2011, 02:56 PM   #104
Stuff's Avatar
Coachwork: Goshen
Engine: 7.3
Rated Cap: 25
I found this tidbit of information in the Sask laws today
“motor home” means a motor vehicle that is registered with the
administrator as a private passenger vehicle, an integral section of which is
designed for personal habitation, and is equipped with one or more permanently
attached beds together with one or more of:
(i) a permanently attached refrigerator;
(ii) a permanently attached stove; or
(iii) permanently attached washing and toilet facilities;
and includes a bus or a truck that has been so converted and is so registered
Old 01-27-2012, 02:10 PM   #105
Stuff's Avatar
Coachwork: Goshen
Engine: 7.3
Rated Cap: 25
I forgot to put this video on here from the last cold start! I really gotta get a better way to start the bus lol. hope spring comes soon!!
Old 03-03-2012, 08:39 AM   #106
Heh so heres your thread on the old bus eh Dean? Figured i would finally sign up since i am giving more and more thought towards the idea of getting a bus for summer use. More then likely will go with something like yours or an actual short van based bus that i could drive daily if i so chose lol.
Darkrider is offline   Reply With Quote
Old 03-07-2012, 04:13 PM   #107
Stuff's Avatar
Coachwork: Goshen
Engine: 7.3
Rated Cap: 25
LOL i knew you would get the bug Chris!!
Old 03-10-2012, 09:07 PM   #108
Stuff's Avatar
Coachwork: Goshen
Engine: 7.3
Rated Cap: 25
Got a grimy cold start video today!
Old 03-18-2012, 11:57 PM   #109
Stuff's Avatar
Coachwork: Goshen
Engine: 7.3
Rated Cap: 25
Shuffled the cars and the bus around today. I miss that roaring diesel!
Old 03-19-2012, 10:51 PM   #110
Stuff's Avatar
Coachwork: Goshen
Engine: 7.3
Rated Cap: 25
old video was here
My 1996 Ford E350 Goshen Coach Conversion Project Drgnnite Short-Bus Conversion Projects 54 11-17-2014 02:16 PM
My 1996 Ford E350 Goshen Coach Conversion Project Drgnnite Skoolie Conversion Projects 4 10-07-2013 10:43 PM
2000 Ford E-350 Goshen Coach W/ Handicap Lift Wheelchairdude94 Short-Bus Conversion Projects 16 01-08-2012 02:24 PM
Early 1990's Ford Bus somewhereinusa Skoolie Conversion Projects 9 07-12-2011 09:59 AM
1990 FORD Shorty Duffman Conversion General Discussions 0 10-10-2010 02:53 PM
