Old 08-28-2012, 03:46 PM   #161
Stuff's Avatar
Coachwork: Goshen
Engine: 7.3
Rated Cap: 25
Re: My 1990 Ford E-350 Goshen Bus
Put in handle to pull the top corner of the door in far enough to latch it good and easy.
Bit of driving
[flash=1280,720:2dpvvf7v]http://www.youtube.com/v/bN8J2nv9hxA?version=3&hl=en_US&rel=0[/flash:2dpvvf7v]
Also got my stickers today. guess they were done last week but nobody told me...
rear
passenger side
video in the works, just editing still.
Old 08-28-2012, 04:36 PM   #162
Why the Private Motor Home stickers, so the law overlooks you for wt and such?or is it required?
Old 08-31-2012, 02:22 PM   #163
Stuff's Avatar
Coachwork: Goshen
Engine: 7.3
Rated Cap: 25
more of im leaving Tuesday for a cross Canada trip and don't want trouble from the OPP and QPP for looking like a commercial vehicle. Our province's plates dont have designations on them like "commercial truck" or "bus" etc. just the sticker says PV which is Private Vehicle but i dont want to gamble on an officer from another province not knowing that.
Old 09-02-2012, 12:18 PM   #164
Stuff's Avatar
Coachwork: Goshen
Engine: 7.3
Rated Cap: 25
bit of update. the seats are in, and the inverter is mounted.
Seats -
power - Its mounted but im still working on the wiring of the inverter. lucky for me i found out NOT the hard way that both those solenoids above the drive in the bus are positive power. I guess the smaller one must be for the AC stuff. I thought being black wires it was negative but NOPE! So I took some old 1 gauge amp wire from a stereo and have wired for the inverter so it also goes through a 150 amp fuse (car stereo stuff again) and that way it will be FUSED... We played around with it last night and it tells me what volts are currently and then there is 3 sets of plugs that have their own fuses as pictured. With the bus sitting for a week now and using some lights etc the batteries are sitting a 12.2 volts which isnt bad for the amount they were sitting!
Also not shown because im too rushed and forgot to take pictures is that I have removed my front bus heater. I decided that where it is is where i want the fridge so it will go there. Lost about a gallon of coolant because it didnt work out how i wanted it to when cutting lines and putting the loop back fitting in... oh well .. partial coolant flush lol. I will have a nice fridge and possibly an AC unit for the drive! yeah!
Old 09-02-2012, 02:29 PM   #165
There is a thread I saw,were they used the black drain hookups with a flexabile hose between them to make the connections on a teardrop that the ac wasn't used all the time.
When needed the unscrewd (1/4 turn)the black caps off both ends.
And inserted hose between them and each end 1/4 turned on them very neat will try to find pictures
Old 09-02-2012, 02:31 PM   #166
Old 09-04-2012, 09:55 PM   #167
Stuff's Avatar
Coachwork: Goshen
Engine: 7.3
Rated Cap: 25
sound interesting!!
Also departure date is delayed a day.. if it dont happen it most likely will never happen..
Old 09-05-2012, 07:04 AM   #168
http://www.expeditionportal.com/foru...er-Build/page6
Check it out
Old 09-08-2012, 01:56 AM   #169
Stuff's Avatar
Coachwork: Goshen
Engine: 7.3
Rated Cap: 25
very cool!
Also trip got canned.. ready to roll out and nope.. next day ready to roll out and nope.. now i dont have the time to go.. sigh..
On a better note I got my own inverter. 2000watt was on sale at canadian tire for $180 with remote on/off.
Also GPS units were on sale for $22-$54 depending on model. got the $54 one for the handsfree built in.
Old 09-23-2012, 12:35 PM   #170
Stuff's Avatar
Coachwork: Goshen
Engine: 7.3
Rated Cap: 25
So I got the hitch put on the other day.
Buddy's rig. hasnt moved cause he got a job with a big company
Then it got dark out! dang winter coming..
And its on!
sits lower then what i expected but its better then nothing!
My 1996 Ford E350 Goshen Coach Conversion Project Drgnnite Short-Bus Conversion Projects 54 11-17-2014 03:16 PM
My 1996 Ford E350 Goshen Coach Conversion Project Drgnnite Skoolie Conversion Projects 4 10-07-2013 11:43 PM
2000 Ford E-350 Goshen Coach W/ Handicap Lift Wheelchairdude94 Short-Bus Conversion Projects 16 01-08-2012 03:24 PM
Early 1990's Ford Bus somewhereinusa Skoolie Conversion Projects 9 07-12-2011 10:59 AM
1990 FORD Shorty Duffman Conversion General Discussions 0 10-10-2010 03:53 PM
