Old 06-23-2010, 09:31 AM   #51
Stuff's Avatar
Coachwork: Goshen
Engine: 7.3
Rated Cap: 25
Re: My 1990 Ford E-350 Goshen Bus
A very HAPPY update!!!
nothing serious at all!! it was a faulty throttle position sensor! they scanned it and it threw that code right away. So I got it changed out, then hit the highway for a quick test. I was INSTANTLY amazed at the difference in ride! It is 100% smooth from stop to 110km/hr on the highway. no shimmy or shake or vibration or humming or anything other then wind noise obviously lol!
The hunt is still on for replacement door parts though... this 32" door header is an elusive SOB lol!
oh and the camper has begun being torn apart. so far i got one wall demolished. just time consuming!
Old 06-26-2010, 11:58 AM   #52
Stuff's Avatar
Coachwork: Goshen
Engine: 7.3
Rated Cap: 25
well tore the donor camper half apart. got some good parts out of it but most of it was too rotten to save... also i CURSE the people that thought that stapling wood together multiple times is better then a couple screws!! ARG!!!!
so got the stove/sink mostly out
and now its out. along with the breaker box, power cable and DC fuse box. and of course its all Blue Line breakers...
tried to get the over the counter cupboards out of it but the back wall and the roof was the back and top of the cupboards and they are well.. rotted out so bad and staples EVERYWHERE >.<
On a good note i found my water pump! I thought it was under the sink but i guess that was the lines cut off for the non existent bathroom.
and i dont know why i didnt take a picture once it was out but this is now free standing. will require some 1x2 and 1x1's to restructure it a bit but its the most solid part so far.
I also took the table out but i said to heck with the chairs... its all stapled rotten badness.. so the table is out and just gotta make new mount for it between the seats in the bus
Old 06-26-2010, 11:31 PM   #53
Stuff's Avatar
Coachwork: Goshen
Engine: 7.3
Rated Cap: 25
Lily - yup. white, grey and black tanks are all there. Just debating on using them or not. I dont have a toilet but i could probably use the white and grey tanks. Also heard to mount them on the drivers side for rv dumps.
did more tearing apart today. found this part to be very rotten. there was even a 110 outlet there!!
we got the kitchen table and chairs out. not sure if we want to rebuild it or not. dont want to spend a billion dollars to rebuild one man.. err camper
then with the help of the reciprocating saw buddy Troy and I got the roof going down
then got the front down
then the back
and loaded it into my LiteAce
Clear deck
then working on the carriage bolts
and now i got a trailer
so bottom line... next guy that gets a camper for the appliances, tear out the appliances and THROW THE REST AWAY!!!! so many staples... ugh..
Old 07-16-2010, 02:59 PM   #54
Stuff's Avatar
Coachwork: Goshen
Engine: 7.3
Rated Cap: 25
well some updates. I had to fight but the bus doors are out! the back half's bottom bolt would not budge so out came the cutting torch and she is done! took all the molding off the sides. the top part was the real pain! the metal was tig or plasma welded in 6 spots along the top. had to drill and pry and bend the metal to get it to come loose! what a job!
then after getting that out i noticed the bottom step was kinda buckling. so i got a screw driver under the rubber flooring stuff and pried it up. well it was one big rust fest under there. metal stairs and the bottom step was metal. In the previous pictures of the bus door you see a metal bar along the bottom. well it looks nice and protects etc but it was right full of rust to! the bolts holding it on were about half rusted apart to! so I got that off, pried up the rest of the step covering. I hosed it down and took the wire wheel brush to it, got as much rust as i could off of it. Now i have blasted it with some tremclad rust primer, and since its so beat up I am going to use some construction adhesive to mount a new board down on the old step. Just need to find a 32" piece of wood the right width
oh and sorry but no pictures... somehow I lost the battery out of my cell phone so i am stuck on an old candy bar cell with no camera for now
Old 08-27-2010, 11:24 PM   #55
Stuff's Avatar
Coachwork: Goshen
Engine: 7.3
Rated Cap: 25
well mini update. have a guy coming tomorrow to put the door in the bus. been in the shop since july and my father is yelling at me to "get that piece of #$%@%@#%@#%@$%@# outta my shop!" So I hope to get it done this weekend, get foam insulation inbehind the drivers side where it goes from van to bus body. make it warmer in the winter i hope!!
And I can take pictures now! I got a black berry (ya evil corporation and stuff)
Old 08-28-2010, 08:32 PM   #56
Stuff's Avatar
Coachwork: Goshen
Engine: 7.3
Rated Cap: 25
well its hung. not pretty yet but its on there! gotta do some shimming and put some more hard ware on then take it for a test drive.
Old 08-28-2010, 09:12 PM   #57
Year: 1978
Coachwork: thomas
Chassis: ford
Engine: 406 Ford
Rated Cap: 25
Alright! Looks homey. The evil blackberry takes pretty good pics- nothing looked distorted.
Is it me, or is the handle placed higher than usual?
bus-ted is offline   Reply With Quote
Old 08-29-2010, 12:11 AM   #58
Stuff's Avatar
Coachwork: Goshen
Engine: 7.3
Rated Cap: 25
yup we put the handle up high. that way from the inside you dont have to reach down to the floor to unlock the door lol. I am going to get a second latch for lower down that can be "kicked" open by a foot or something. Right now i gotta finish around the door and seal it all up. Also i gotta do the step floor. I got some stuff that i will put down that will level out nicely and then i can put the bottom sweep in.
yea im surprised as how well the pictures are even though they were re sized and sent through facebook (yay free image hosting lol) seems good to me.
Also going to see if i can find a locking latch for it. the little clip latch doesnt seem to be good enough for me lol.
Old 09-04-2010, 11:08 AM   #59
Stuff's Avatar
Coachwork: Goshen
Engine: 7.3
Rated Cap: 25
so tried sealing around the inside of the door with silicone... didnt work well
so tried foam. that worked better and easier!
just gotta work on the step at the bottom still and all should be good.
Old 10-28-2010, 10:02 PM   #60
Stuff's Avatar
Coachwork: Goshen
Engine: 7.3
Rated Cap: 25
Well i never got it done this year... new place, winterizing, work, not enough funds or time
had to pack her up today. went from and empty shell to packed full
My 1996 Ford E350 Goshen Coach Conversion Project Drgnnite Short-Bus Conversion Projects 54 11-17-2014 02:16 PM
My 1996 Ford E350 Goshen Coach Conversion Project Drgnnite Skoolie Conversion Projects 4 10-07-2013 10:43 PM
2000 Ford E-350 Goshen Coach W/ Handicap Lift Wheelchairdude94 Short-Bus Conversion Projects 16 01-08-2012 02:24 PM
Early 1990's Ford Bus somewhereinusa Skoolie Conversion Projects 9 07-12-2011 09:59 AM
1990 FORD Shorty Duffman Conversion General Discussions 0 10-10-2010 02:53 PM
