Old 05-18-2011, 06:17 PM   #71
sdwarf36's Avatar
Coachwork: Champion
Chassis: Ford e-450
Engine: 7.3 Powerstroke
Re: My 1990 Ford E-350 Goshen Bus
Well--you could do that-but sometimes (more often than not) it is more work retro-fitting something rather than starting from scratch. What I did (twice actually-once on my bus+ once on my cube van.) is have a metal shop bend you up some diamond plate. For about $100, you can make things to how you want. On both rigs, my intent was having a step to get in+ out of the back (frequently) and having a 2" reciever hitch. You have the 2 frame rails +some other cross-bracing back there-so you have plenty to attach to. Folded 1/8" plate is plenty strong-the thing weighs maybe 80 lbs. My hitch + whole bumper are all welded together as 1 unit--and i also put in 2 pieces of 1"x 2" tube under there for sliding in a motorcycle carrier.
Old 05-18-2011, 10:38 PM   #72
Stuff's Avatar
Coachwork: Goshen
Engine: 7.3
Rated Cap: 25
my father says he has a hitch for a full size ford van in the back of one of his vans.. so i might try that to. was thinking that bumper would just look better behind the bus lol.
tomorrow is a day off so lets see what i can wreck lol
Old 05-19-2011, 04:47 PM   #73
lapeer20m's Avatar
In the future, if plasma cutter is not handy, You can cut some substantial pieces of metal using a 110 volt circular saw like carpenters use. Replace saw blade with an abrasive metal cutting blade/disk.
Wear eye ear and lung protection.
Angle grinders with skinny blades work well also, but lack the power of a circular saw.
Old 05-19-2011, 07:06 PM   #74
Stuff's Avatar
Coachwork: Goshen
Engine: 7.3
Rated Cap: 25
look what i found in the back of one of dad's van! BRAND NEW! "i dont have a use for it, just take it" its a class 4 hitch to!
Old 05-19-2011, 11:12 PM   #75
Stuff's Avatar
Coachwork: Goshen
Engine: 7.3
Rated Cap: 25
And i took a night shot cause i could. Fired on the 2nd try after sitting all month.
Old 06-19-2011, 01:12 PM   #76
Stuff's Avatar
Coachwork: Goshen
Engine: 7.3
Rated Cap: 25
they opened the dams and I had to move. unfortunately no hitch on the bus yet... had to use fathers super duty to get out. if he would have spun or sunk it would have taken a few trucks to get him out!
File Type: jpg 251360_10150282813085155_712620154_9448520_7571029_n.jpg (99.3 KB, 1366 views)
Old 06-20-2011, 12:23 PM   #77
Stuff's Avatar
Coachwork: Goshen
Engine: 7.3
Rated Cap: 25
well 11:30 last night they sounded the alarm and got everyone out! they opened the dams to 650 m3/s (23,000cubicft/s) and it began to flood the trailer park. 400 more people out of a home and now there is bridge failures and they are trying to save the park but no guarantees yet..
suddenly everyone is thinking my mobile home is a very good idea!
Old 07-05-2011, 01:09 PM   #78
Stuff's Avatar
Coachwork: Goshen
Engine: 7.3
Rated Cap: 25
well we are back home, trailer is in and blocked and leveled again, but the bus aint...
the starter gave up the ghost on the street in the picture... put booster cables on it and charged up the batteries good and it just wont crank fast enough. then the cables got hot so we know it was drawing way too many amps. tried it again and nothing and nothing then a grr as it tried again.. so i assume its done. probably the brushes in it or something.. bah..
so now i gotta see what a rebuilt starter for it will cost... its full of skirting junk from the trailer and other crap i need to get out of it.. and 12 days of plates left on it..
and now i find out there is an option to have gear reduction or no gear reduction... grr..
Old 07-05-2011, 07:41 PM   #79
Stuff's Avatar
Coachwork: Goshen
Engine: 7.3
Rated Cap: 25
so tow truck boosted the bus to get it to start. guy is trying to claim its my batteries.. they were new last fall, they have been topped up and maintained... why is it that as soon as you boost it from another diesel that it will spin to life i wonder?
I for one still believe it is the starter that is shot and is drawing way too many amps!
Old 07-05-2011, 10:21 PM   #80
sdwarf36's Avatar
Coachwork: Champion
Chassis: Ford e-450
I thought the same thing of my Vw diesel. found various tricks -plug it in longer-new battery-run longer on diesel after shutting off the veg system. Finally changed the starter-but it still wasnt always quick enough. it turned out the end of the pos cable to the starter had a crappy connection inside the terminal. A new cable + some sanding + cleaning made the thing crank over MUCH better.
My 1996 Ford E350 Goshen Coach Conversion Project Drgnnite Short-Bus Conversion Projects 54 11-17-2014 02:16 PM
My 1996 Ford E350 Goshen Coach Conversion Project Drgnnite Skoolie Conversion Projects 4 10-07-2013 10:43 PM
2000 Ford E-350 Goshen Coach W/ Handicap Lift Wheelchairdude94 Short-Bus Conversion Projects 16 01-08-2012 02:24 PM
Early 1990's Ford Bus somewhereinusa Skoolie Conversion Projects 9 07-12-2011 09:59 AM
1990 FORD Shorty Duffman Conversion General Discussions 0 10-10-2010 02:53 PM
