Old 01-10-2015, 04:43 PM   #41
Originally Posted by davidshelton View Post
Bought 3/4" thick rubber horse stall mats from Tractor Supply and fit them to the floor. Sure quieted things down a lot. Also added more insulation to the engine cover. Converted both A/C units to run on the same compressor and the side mounted condensing unit. Bought a junk yard cruise control module so that is fixed. Installed a huge trans cooler from a 6.0 liter Ford Super Duty. Things are working out pretty well
I've got a 96 E 350 with a 7.3 Powerstroke that is really noisy. Could you tell me what kind of insulation you added to the engine cover and was it added to the engine side or the cab side.
Mines not a skoolie but I've been lurking around here trying to get ideas.
Thanks
Tom
TOMMAY is offline   Reply With Quote
Old 01-11-2015, 09:04 PM   #42
Coachwork: MertoTrans
Chassis: Ford E-SuperDuty
Engine: 460 Ford
Rated Cap: 4
Inside the engine cover I used a Thermotec heat barrier. Pretty easy since it had an adhesive on it.
On the floor, I removed the rubber floor covering and insulated the floor with a sound/heat barrier about 3/8" or 1/2" thick that was a jute-like material with foil on both sides and then re-installed the rubber mat. Don't have the brand name for it since it was leftover from something I bought years ago. I think I bought it from Summit Racing.
davidshelton is offline   Reply With Quote
Old 01-11-2015, 10:19 PM   #43
Thanks a lot.
Old 06-30-2015, 03:13 PM   #44
Engine: 460 Ford
Rated Cap: 4
Update: Just returned from another 2,000 mile Colorado trip about a week ago and love the bus even more. Floor sound deadening was very successful. No real problems except for the A/C has a small leak so I had to add a couple of cans of R-134 during the trip. Drove 62-65 mph and averaged 7.75 mpg. Not great, but not terrible.
Since I got back, I scored a great looking and comfortable set of 4 Captain's chairs (2-front and 2-quick release 2nd row seats) at the local U-Pull-It parts yard.
Also decided that it's time to do the Cummins diesel/ Ford 5 speed automatic swap so I am gathering the rest of the parts to get started on that.
Old 07-12-2015, 08:45 PM   #45
Engine: 460 Ford
Rated Cap: 4
Trying to take care of some of the changes to support the Cummins swap. Mounted the dual battery setup on the framerail. Removed the 4.63 rear gears and installed 3.73 rear gears yesterday. I like driving it better with the new gears. This gear set is much quieter.
Old 07-12-2015, 09:59 PM   #46
Engine: 190hp 5.9 Cummins
Great news.
You will love the mechanical Cummins.
Old 08-23-2015, 06:34 AM   #47
Engine: 460 Ford
Rated Cap: 4
I still haven't started the Cummins conversion yet as I am waiting for cooler weather. Been working on the A/C system. Replaced O-Rings, Drier, Sightglass, Accumulator, and orifice tube. Then evacuated the systom for 5 1/2 hours, checked for leaks for 2 hours and re-charged. It now blows pretty cold!! I still think I need a little more compressor capacity, so I am going with a larger size compressor when I do the Cummins swap, but it's pretty darn good for now. Yesterday I took all of the family on a little 200+ mile trip in the bus to see how all of my little changes worked out.
Let me start by saying that the rear gear change is the best thing I have done! Yes, it is a very little down on power, but not enough to really matter. Fuel mileage at 65mph went from about 8 to a little over 10mpg (25% improvement!!!!) Also the engine is a bit quieter turning the slower rpms. Also the A/C works well. All in all a good day with good results. I'm liking this bus more and more!!!!
Old 08-23-2015, 06:40 AM   #48
Engine: 460 Ford
Rated Cap: 4
Thought I would try and add a picture
Old 08-23-2015, 09:56 AM   #49
Nice package! --- Is that a rotary pump model? And I see the tranny came with the driveline brake. Sweet. I'm guessing you might be able to double your mpg with that set up.
Old 08-23-2015, 05:02 PM   #50
Engine: 460 Ford
Rated Cap: 4
Yes, the Cummins engine is from an low mileage Intercooled 91.5 Dodge. I turned the pump up a touch, replaced the fuel pin, governor spring, installed a larger turbo, and changed valve springs for a little more power. The 5R110 trans is from a 2006 6.0 diesel Ford. I had to add the driveline brake. It just so happens that it bolts right on to a 4WD transmission after you unbolt and remove the transfer case.
YAMBT - Yet Another Metrotrans Bus Thread thetootall Short-Bus Conversion Projects 3 10-21-2014 11:49 AM
police heavy duty battery pack proconsul100 Electrical, Charging and Solar 3 10-10-2012 10:48 AM
Super Bummed...about towing jkindt On the Road | Travel, Trips, Camp Sites, Tailgates 10 06-16-2010 11:01 PM
Santa Fe Super Chief Steve Skoolie Conversion Projects 5 06-16-2010 03:41 PM
Super fuel efficient car lapeer20m Everything Else | General Skoolie Discussions 31 09-14-2008 06:03 PM
