Old 04-12-2016, 01:56 PM   #61
Coachwork: MertoTrans
Chassis: Ford E-SuperDuty
Engine: 460 Ford
Rated Cap: 4
The swap was pretty time consuming. Everything fit tight and there was little room for error.
davidshelton is offline   Reply With Quote
Old 04-12-2016, 02:35 PM   #62
Engine: 460 Ford
Rated Cap: 4
Here's a couple more
Old 04-12-2016, 05:50 PM   #63
sdwarf36's Avatar
Coachwork: Champion
Chassis: Ford e-450
Engine: 7.3 Powerstroke
WOW!!!! As someone whose has r+r'd a 7.3 out of my bus, I know all about tight conditions under there. Is that a 4BT? How is it for noise? Shaking? Cooling?
Nice work!
Old 04-12-2016, 08:35 PM   #64
Engine: 460 Ford
Rated Cap: 4
It is a 5.9 from a 1991.5 Dodge truck. I have done about everything I can to reduce the noise so it's really not bad at all. Cooling is no problem at all since I used the radiator and intercooler from a 2006 6.0 diesel Econoline. Runs at 195 with a 195 thermostat. Maintenance access is probably better than a stock Ford diesel van.
Just started doing the paintwork on the bus. A picture is attached.
Old 04-12-2016, 09:07 PM   #65
Robin97396's Avatar
Like your bus really needed to be painted dude.
Looks great.
Old 04-12-2016, 10:09 PM   #66
Engine: 460 Ford
Rated Cap: 4
Looks great.
It was just "Too Much White".
Really, the paint was in pretty bad shape. Looked OK at 50' but closer, it was pretty rough.
This weekend I'll try to paint the rear Gray. It may also need a red stripe or????? I may wait a bit to paint the frontend.
Old 04-12-2016, 10:25 PM   #67
Robin97396's Avatar
Maybe get one of those graphic wraps?
I think the white buses are nearly as invisible as the yellow school buses. You know how everyone ignores and tolerates school buses. Generic white buses are the next best thing.
Old 04-12-2016, 10:45 PM   #68
sdwarf36's Avatar
Coachwork: Champion
Chassis: Ford e-450
I know its a common swap in a pick up-did you use any kit stuff or did you built it yourself? Its been asked in the past if this was possible - thumbs up for for all the test fitting it must have taken. I can't believe it clears the bottom of the dash. I wanna see how you hooked it up to the cherry picker. I had to make a engine lift plate to get right into the vee of the 7.3 to get enough room to get between the dash bottom + the crossmember.
Old 04-13-2016, 07:15 AM   #69
Engine: 460 Ford
Rated Cap: 4
The engine/trans adapter is from Diesel Conversion Specialists. I had to build everything else.
Lift setup picture attached
Old 04-13-2016, 09:58 AM   #70
skoolie_n00bie's Avatar
Coachwork: Ward
Engine: Navistar 5.9 Diesel
Rated Cap: A butt-load...
what about an A-Team style paint?
I know it was a different van, but wouldn't that be cool?
n00b build > http://www.skoolie.net/forums/f27/th...ily-10122.html
Not my fault if anything I post results in someone losing a finger...
Errare humanum est, perseverare diabolicum
skoolie_n00bie is offline   Reply With Quote
YAMBT - Yet Another Metrotrans Bus Thread thetootall Short-Bus Conversion Projects 3 10-21-2014 11:49 AM
police heavy duty battery pack proconsul100 Electrical, Charging and Solar 3 10-10-2012 10:48 AM
Super Bummed...about towing jkindt On the Road | Travel, Trips, Camp Sites, Tailgates 10 06-16-2010 11:01 PM
Santa Fe Super Chief Steve Skoolie Conversion Projects 5 06-16-2010 03:41 PM
Super fuel efficient car lapeer20m Everything Else | General Skoolie Discussions 31 09-14-2008 06:03 PM
