Old 09-23-2012, 08:05 PM   #1
Coachwork: Corbeil
Engine: T444e
Re: My 1998 E-350 shortie
The way to figure out which kit you need is to follow the fuel line from the tank to the engine. If you find an electric fuel pump on the frame then you have the later version. The earlier version has a cam driven fuel pump that is located in the engine valley.
I personally will be going with this system.
http://www.wvodesigns.com/blog/wvo-info ... onversion/
It is not a kit but I believe wvo is something you really need to understand if you are going to use it and not ruin your engine.
Alex and Angie is offline   Reply With Quote
Old 09-23-2012, 08:43 PM   #2
sdwarf36's Avatar
Coachwork: Champion
Chassis: Ford e-450
Engine: 7.3 Powerstroke
I found a great size + shape plastic tank from an old boat. The less metal you have in the system-the better.
BTW-do you have any oil saved up?
Old 09-23-2012, 11:38 PM   #3
sdwarf36's Avatar
Coachwork: Champion
Chassis: Ford e-450
Not to discourage you, but the days of free oil all over the place are long gone. The $1500? you spend on the conversion would buy (apx) 375 gallons of fuel. Also the space needed for collection + filtering onboard is substatial for a short bus.
Old 09-24-2012, 10:32 PM   #4
sdwarf36's Avatar
Coachwork: Champion
Chassis: Ford e-450
Guess your in luck then!
1st thing you need to do is start doing a bunch of math-and figuring what your plans are. Miles per trip-how many gallons can i hold-how long will it be to process the next batch to use-etc. See if your plans can equal your capacity.
I could set up a shortie to process 300 gal-there just wouldn't be any room for anything else!
Old 10-02-2012, 11:20 AM   #5
Diesel Dan's Avatar
Engine: DT466/AT545
Hey sdwarf36, do you process WVO on the road? If so, how do you dry it (get the water out, that is)?
Thanks,
Dan
Gallery:
Conversion Thread:
viewtopic.php?t=4959
Old 10-02-2012, 08:31 PM   #6
sdwarf36's Avatar
Coachwork: Champion
Chassis: Ford e-450
Thanks,
Dan
No I do not. My normal trip is 300-500 miles. Easy enuff to do with the 52 gal veggie tank. And since its main use is in summer, if I need to go further, I can dump some veg in the(55 gal) main tank. My longest trip, (1600 miles) I filled both-and brought like 12 cubies with me.
My bus is a weekender-not a full timer.
cheap shortie in Ct. sdwarf36 Classifieds | Buy, Sell, Swap 0 04-23-2011 09:40 PM
1998 Am Tran with 210 hp 5.9 and 643 TAB Classifieds | Buy, Sell, Swap 5 06-30-2009 08:21 PM
New Skoolie with a shortie (HELP!) hazelhermit Short-Bus Conversion Projects 3 06-18-2009 08:40 PM
shortie bus? jarly Everything Else | General Skoolie Discussions 4 01-25-2009 10:20 PM
1990 Shortie Dan-O Skoolie Conversion Projects 23 09-16-2005 12:26 PM
