Old 03-25-2018, 03:27 PM   #41
Chassis: Saf-T-Liner MVP ER
Rustoleum primer and you can glue in 24 hours.
Steve Bracken
Build Thread
Old 03-27-2018, 07:02 PM   #42
Laid the subfloor today! The gaps around the walls are a bit bigger than I intended, but I am very happy with everything for the most part. The plywood did warp a bit so I'm tryna weigh it down with as much stuff as I could find (what's not included in the picture is the stove and fridge I added to the lot from my friend/roommates trailer they're renovating).
I really jacked my back up doing all this today though, so good thing I'm gunna give the glue two days to dry before I move any of that stuff. My body's gunna need the break as well.
homebus is offline   Reply With Quote
Old 07-02-2018, 05:03 PM   #43
Originally Posted by homebus View Post
I did it I did it I finally did it!
As some of you here may know, I been searching for a bus for months now. My lease is up at the end of April, and I'm sick of paying rent. I've traveled a whole lot in my life, spending years hitchhiking and living out of cars with friends, and I've been missing it. Last year I signed a lease for the first time ever (I'm 28 haha) and while it was nice having my own room and the stability that can afford, I'm over it. So I got to thinking, and realized that with a bus I get the best of both worlds! A little home on the go.
Fast forward to a checking out some buses that were NOT as advertised (and an immense restraint in compulsive buying on my part) to yesterday. I enlisted the help of a friend and we drove 4 hours away to check out a bus. And I loved it. And I bought it. The specs/important info/bonuses are as follows:
- 1997 International 3800 DT466E
- not sure what kind of transmission
- 253,000 miles
- working wheelchair lift
- already gutted!
- already painted flat black!
- governed at 55 mph
- mechanic at school said the bus had 253,000 miles one it, but it had the cluster replaced 39,000 miles ago so that's what it shows
Also, the incredible thing is, the folks who I bought it from got it from a school, so there are maintenance records. They records only go as far back as 2012 (not sure why) but I was told that since it was used to transport children, it had to go through some sort of inspection every 30 days. Not to mention that it was registered in North Carolina, which requires a top-to-bottom inspection annually. The couple purchased this beauty from the school in June of last year, and had it inspected when they registered it themselves in August. It passed everything except the wipes, which they replaced.
I. Am. So. Excited. Now, I know that there are plenty of folks who aren't into the DT466E's cause of all the electrical components. I weighed in everything I've heard about em, but I just couldn't pass this bad baby up. Oh, and I got it for $2,800.
The only down side I can see right now is the entrance door being electric. I'm trying to figure out a layout that would allow me to use the emergency exit or wheelchair lift door as my main entrance. The emergency exit would be unaccessable with the way I'd wanna build a bed, but if I put it off to the back right then I could feasibly use the wheelchair lift door, as long as I rig up a way to get in from the outside.
There are a million and one questions I'm sure I'm going to have, but as for now I've got a few things already I'd like to throw y'alls way.
First, with the governing: seeing as how if I went any faster the gas mileage would just get worse and worse anyway, I'm not tryna fly this thing. Doing 60 mph would be nice, but what I'm more concerned about is the gearing. The guy told me that he had talked to the schools mechanic, who said that technically the governor could be removed, but that the bus is geared for stop and go, so anything faster than 55 pretty much would overheat the engine. He didn't ask the mechanic what the gearing was, and I'm curious myself (although at this point with my knowledge the numbers themselves wouldn't mean anything to me). I noticed on my drive home that the temperature normally stayed at 180 degrees, but after driving up and around the mountains for a while the temp climbed to 210, and probably would have kept climbing had we not started to go down hill...er...mountain. At 55 mph the rpm's are 2,700. Does all this sound like to y'all that I should just avoid mountain driving at all costs?
Second: the wheelchair lift! What a cool invention (humans really are incredible inventors) however I don't need or want it. I've been told you could sell these things, but is there really a market for em? And what would I need to do when I remove it to make it more appeasing to the seller? Any specific ways I should remove the wiring?
Third: how'd I do!?
Y'all have been great so far, and I am forever indebted to this forum. I can't wait to learn as I go and to one day be able to pass the knowledge forward. I've already learned so much about buses (I even knew more than the men selling em at times, haha!). Anyway, that's all the info I can think to vomit up right now. Thanks for bearing with this long and excited intro. I know what y'all are waiting for anyway, so here's the pictures (let's hope I upload them right):
The coupled who sold it to me had used to to start their business - selling patches to mostly bikers. They eventually upgraded to a store and now the bus is mine! Just gotta paint over the stencils.
My favorite creature in the world checking things out
Thing works great
Not the best pictures of the chassis, but barely any rust (other than surface).
I wish he could drive...
I have a 1999 International DT466E, it's about 33 feet long, it has a Wheelchair Lift, I'm keeping the Lift. I have a Code SID0164 FM-4, from my research, that means something about the Injection Control Pressure or ICP. Does anyone know where the ICP is located? My RPMS and speedometer are not functioning properly, only intermittently. If someone can help, just let me know.
Back to your Bus, I like it, congratulations.
The Snowball Bus is offline   Reply With Quote
Old 07-02-2018, 05:14 PM   #44
that code is actually a J1939 code.. SPN 164 FMI 4. which is an ICP sensor out of range low.. it can be a wiring harness issue with the ICP shorting to ground or could be the sensor itself.. I would test the harness and look for chaffs or famages to the connector before replacing the sensor..
Old 07-02-2018, 07:02 PM   #45
I don't know where to look for a Harness or Chaff
Old 07-02-2018, 07:03 PM   #46
I'm been looking for a Service Manuel for the year 1999 DT466e
Old 07-02-2018, 07:39 PM   #47
I hasve the OnCommand windows based service manuals vut its 4+ gigs to download.. It has the 466E in it..
here is a diagram I found onli ne that might help you locate the ICP and inspect the connector and wires around it..
https://www.justanswer.com/heavy-equ...e-seconds.html
Old 07-02-2018, 08:01 PM   #48
Year: 1994
Engine: DT408 6.7L L6
You don't have the MT643. In the one pic of the drivetrain you posted there are 2 rings of bolts around the transmission housing. This means one set is the adapter to go from an SAE #2 to an SAE #3. You've got an AT545.
~Alf
My Build Thread!
djdalfaro is offline   Reply With Quote
Old 07-02-2018, 08:04 PM   #49
Year: 1994
PM me your email and I'll send you the tranny service manual in PDF if you want it.
~Alf
My Build Thread!
Old 07-07-2018, 08:37 PM   #50
Thank you, Christopher, I apologize for responding so late, so busy. I had already bought a Sensor, but I don't know where to put it.
Old 07-11-2018, 02:42 PM   #51
And....????
Has anyone heard from Homebus in the last couple of months? I just read the whole thread up to 3/37 and it just stops. Wondering how everything turned out. is he ok? Changed mind?
MoparJohn is offline   Reply With Quote
Old 05-13-2023, 06:29 AM   #52
Heya,
Do you have any pictures of the interior before you converted it? Thanks so much,Leo
Leowoodbus is offline   Reply With Quote
