Old 06-04-2012, 04:25 PM   #21
Coachwork: collins
Chassis: ford e350
Engine: 7.3 ford
Re: My New Project!
Originally Posted by chev49
i have an air stop sign....well, its in one of the scrap piles...
thanks but i need a 12 volt
james843 is offline   Reply With Quote
Old 06-26-2012, 08:25 PM   #22
Coachwork: midbus
Chassis: chevy
Rated Cap: 29
Re: My New Project!
well once again i have tried to add more pictures to the posting but it now says quota met on board and wont let me. this is getting frustrating! i sent a message to steve about it, hopefully soon i will be able to get them up. we have been making alot of progress on the bus and would love to share it all.
hordechick is offline   Reply With Quote
Old 06-26-2012, 08:38 PM   #23
Re: My New Project!
H, You need to set up a photo bucket account. This bipasses the attachment issue and allows you to post lots of pics. After you have an acct, PM me and I'll show you how to post pics. Jack
Old 06-26-2012, 09:18 PM   #24
Coachwork: midbus
Chassis: chevy
Rated Cap: 29
Re: My New Project!
ok here are alot of pictures of progress so far
this is the countertop almost finished i just need to put in the faucet
framing in the bathroom and for the counter
the inverters before i mounted them and the water pump
plumbing going in
the fridge in its place
bathroom framing sorry the pic is turned
the sink i made from a stainless steel mixing bowl
the tv finally mounted
the cb radio mounted and i have added and rewired a few switches to the control box
Old 06-26-2012, 09:38 PM   #25
Coachwork: midbus
Chassis: chevy
Rated Cap: 29
Re: My New Project!
here are some more pics of progress thats been happening
the air conditioner i just put in today i built an insulated box inside the bus above the master bed area to house it. i used vent tape to seal the seams but it is definitely mounted well. the box is siliconed up and sealed really well. i built it this way so as to pull it out and upgrade or clean it whenever i want. also since it is just inside the window opening i am making a stainless steel cover to mount outside when it is stored to keep out those dang wasps and daubers. i have a small set of 12v fans i am mounting inside the box to circulate air so it doesnt overheat. i ran it all day today sitting in the sun and it worked great. now i just need to build a handler box and run some venting to make it function as a central air type system. i actually got a nice rooftop unit from the trailer i cannabilized but i didnt want to add more height to the bus and we needed central air in our home so i recharged and cleaned the rooftop unit and installed it in our house. it is working great by the way
the electrical access panel i finally got cut into the bus. i havent sealed it yet, but it works great. i put it up so high so i can also use it as an access panel for mounting and unmounting the fridge and also to use the fridge on my inverter. we had to go cheap on most of the things we are doing and instead of buying a big expensive fancy items. so i wired the 1000w inverter to a remote switch next to the breaker box and ran and extension power outlet to the power outlet on the inverter. so all i have to do is plug the main shore cable into the remote outlet box switch on the inverter and turn on the fridge breaker. then i can power the fridge on the inverter while boondocking or traveling. i will add pictures of the setup and diagrams later in case anyone is interested.
these are the kids bunks made from foam and vinyl salvaged from the seats that came in the bus. the part that hase the framing wrapped is the only part that will be exposed the other half will be walled in. my other half did an awesome job covering the beds!
Old 06-26-2012, 09:42 PM   #26
Coachwork: midbus
Chassis: chevy
Rated Cap: 29
Re: My New Project!
we have gotten alot done now i would say about 75% there! we have been working hard on it and cant wait for it to be finished! thank you to everyone who posts on here i greatly appreciate all of the ideas tips tricks and suggestions i have come across on here. now that i have the photobucket up and going i will be posting more pics. if there is anything that anyone wants to see more of or know more about please just ask.
Old 06-27-2012, 11:23 AM   #27
Re: My New Project!
H, I've created a picture monster--I'm going to be late to work for looking at all of them! JUST KIDDING the pics are great thanks for sharing them and yes, I'd like to see how you hooked everything up. Jack
Old 06-27-2012, 11:47 AM   #28
Re: My New Project!
Neat stove!Where did you get it?
Old 06-27-2012, 12:00 PM   #29
Coachwork: midbus
Chassis: chevy
Rated Cap: 29
Re: My New Project!
i got it at harbour freight i think it is perfect for us in the tiny bus. here is a link to it
http://www.harborfreight.com/stainless- ... 99861.html
New Bus with No Name Project Redbear Skoolie Conversion Projects 3 04-24-2010 09:55 PM
First Project salee05 Skoolie Conversion Projects 0 09-02-2009 10:25 PM
My bus Project With a new name.... Kirbystud Skoolie Conversion Projects 12 08-20-2009 10:55 AM
My new project...maybe lapeer20m Everything Else | General Skoolie Discussions 9 04-17-2006 08:03 PM
Trade 1970 VW Karmann Ghia project for skoolie project bus? shortwaverunner Classifieds | Buy, Sell, Swap 3 02-03-2006 09:56 AM
