Old 03-05-2013, 03:07 PM   #1
Chassis: E350
Engine: 7.3l Powerstroke Diesel
Mystery Switch
Anybody know what this switch might be to? It's near the driver seat. It's says "Cole Hersee co." on it, also "Boston U.S.A.". No model number. My bus is a '96 Ford e350 shorty with a 7.3l powerstroke. Manufacturar is Thor; brand is Eldorado.
Cheers,
Tim
timmygyu is offline   Reply With Quote
Old 03-05-2013, 03:17 PM   #2
Re: Mystery Switch
It is a disconnect switch between the battery and something
Since it has yellow plastic crimp covers I will go with 12 ga wire good for say 20 amps.
It is not factory installed
Either trace wires to find out where it goes
or turn it off and see what doesn't work.
It was probably installed because something was draining the battery down.
Good luck
Old 03-05-2013, 03:53 PM   #3
the_experience03's Avatar
Re: Mystery Switch
Seeing stuff like that makes me so glad I'm no longer in service engineering at Ford Motor Company. The technicians would contact us about stuff like that ALL the time and we had absolutely no reference because it was added to a cutaway chassis by the bodybuilder. The tech was kind of stuck because he was supposed to fix it (and sometimes even tried to claim warranty time ) but had nothing to go on.
Upfitters are really good at doing things like using black wire...and only black wire...for EVERYTHING. Oh the fuming customers...the A/C wouldn't work (performance is lackluster on a stock E-series due to airflow restrictions)...come to find out that the aftermarket upfitter installed a second evaporator unit and tied it into the stock system without upgrading the compressor or condenser. Upfitters would by an E-250 to upfit because it was cheaper and the customer would get upset when Ford wouldn't warranty the broken suspension springs because it was 50% over the GAWR before the customer even added their own junk to it.
Speaking of Ford...there is some information out there that may be of some use to you and it is absolutely free. There is some good stuff at https://www.fleet.ford.com/truckbbas/ though a lot of it applies to newer models only. Of course, the E-series really hasn't changed all that much...
Old 03-05-2013, 10:21 PM   #4
roach711's Avatar
Rated Cap: 19
Re: Mystery Switch
My rig came with that same switch. I believe it disconnects the battery ground and kills power to the bus. I figure it will come in handy as an anti-theft device.
The Roach Motel
Old 03-05-2013, 11:12 PM   #5
91 Bus Guy's Avatar
Chassis: Chevy G30
Engine: 5.7 V8 TBI GM
Rated Cap: 10
Send a message via MSN to 91 Bus Guy
Re: Mystery Switch
My bus didn't have one but I think it would be a good mod to add.
Keith
91 BG
91 Bus Guy is offline   Reply With Quote
Old 03-06-2013, 02:35 AM   #6
Chassis: E350
Re: Mystery Switch
Thanks for the replies everybody!
bansil:
I figured it probably wasn't stock. I guess I'll trace it at some point.
the_experience03:
Yeah, all the aftermarket stuff is a PITA to figure out. I'll check out the link. Cheers...
roach711:
Thanks for the input, but it definitely doesn't do that; I turned it off and turned the bus over without trouble; everything seemed to work.
91 Bus Guy:
Every bus needs a magical mystery switch...
Old 03-06-2013, 08:31 AM   #7
Re: Mystery Switch
Is there an "extra" battery somewhere? I've seen similar switches used to toggle between two batteries (?). Tracking down the wiring may be the only answer though. Let us know what you find at the end of it.
Old 03-07-2013, 10:03 PM   #8
roach711's Avatar
Rated Cap: 19
Re: Mystery Switch
Mine definitely disconnects the battery. Here's a link to the same switch on the Cole Hersee site:
http://www.ase-supply.com/Cole_Hersee_p/ch-2484-a.htm
The Roach Motel
Switch Question davidshelton Short-Bus Conversion Projects 5 05-09-2014 06:04 AM
Mystery button and "batteries" toggle switch GameRV Electrical, Charging and Solar 4 12-05-2010 12:48 PM
Transfer switch reprobate Conversion Tutorials and How-to's 5 12-11-2007 11:27 PM
mystery plug? The Wanderer Conversion General Discussions 5 04-30-2007 01:20 PM
mystery switch westport_wayne Everything Else | General Skoolie Discussions 4 08-12-2006 11:23 PM
