Old 11-29-2014, 06:59 PM   #1
Year: 1985
Engine: 350
Rated Cap: 21
Need advice on brake repair
Hello fellow skoolies. I recently purchased a 1985 Microbird, runs great only problem is a rusted brake line that runs front to back on the drivers side has a leak. I do most of my vehicle repairs myself, but when it comes to brakes the only repairs I have done are shoes. I have called around on having the line replaced, and no one seems willing to fix it. Why? Also no repair books online that I could find. My question is how hard is this going to be to fix, what is the best way and how much am I looking at spending?
Millectric1 is offline   Reply With Quote
Old 11-30-2014, 01:07 PM   #2
Re: Need advice on brake repair
Welcome,
Way too many variables
Dealer parts or buy tubing and bend cut etc and then flare
My advice is this
Replace all lines if one is rusted....you will never have to do this again....for at least 15years
Is it gm or ford?
Easiest route is to get all the lines clips and hoses (be prepared just in case with about $300 for calipers and wheel cylinders) get a mechanic friend and a 12 pack of a good IPA...don't pop first top until lines are replaced
Your looking at $350 worth of lines(prevent etc) plus add in crap that doesn't come loose
Good luck and ask more ?
Hardest part will be taking crap apart, then cleaning, next reassymble, then bleeding....brakes not you
Old 11-30-2014, 06:22 PM   #3
Coachwork: ward
Chassis: international
Engine: dt360a
come on man, bleeding is part of the deal. you gotta bleed to get her fixed.
Old 11-30-2014, 09:19 PM   #4
What Bansil suggests is true. If you have one brake line leaking, the rest won't be far behind. You need to use either galvanized or stainless steel tubing if you can. It is possible to paint steel tubing to ward off rust, but, not advisable. Also, be SURE to use a double flare tool when you make up new tubing. Single flare (like Harbor Freight tool makes) usually splits the flare at the weld and leaks almost immediately. The double flare tool folds the tube back inside itself and then flares the tube thus avoiding the split. You cab buy the tubing fairly cheaply at a business who deals in hydraulic equipment--about a buck a foot for mild (needs paint) steel. Head Bansil"s advice---my life may depend on it! Hope this helps. Jack
Old 12-01-2014, 08:06 AM   #5
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
I agree with Jack and Bansil. Get a made up brake line and study how the double flare is made. Then make a few practice ones and study them with a magnifying glass. ANY crack is unacceptable. It takes a little practice to get them right.
Old 12-01-2014, 11:28 AM   #6
Ditto all the above --- Perfect double flares are critical on brake lines. And just because a flaring tool came from an Auto Supply, doesn't mean it's right for brakes. Half the counter guys don't have a clue about anything auto related.
Brake repair for DIYer, winter driving suggestions? tomas_maly Conversion General Discussions 8 03-01-2014 10:11 PM
1997 Ford B-800 brake line repair tomas_maly Conversion General Discussions 18 09-24-2013 05:21 AM
air brake 101...or how to fix/diagnois a stuck brake issue bansil Conversion General Discussions 16 06-28-2012 02:28 PM
Floor repair cschlessman Skoolie Conversion Projects 2 05-15-2012 12:15 PM
Emergency repair kit w1bmw Conversion General Discussions 11 08-02-2006 10:03 PM
