Old 08-08-2014, 03:32 PM   #1
Drgnnite's Avatar
Coachwork: Metrotrans
Chassis: Ford E350 Cutaway
Engine: 7.3L Diesel
Rated Cap: 25
New Project 1996 Ford E-350 7.3L Shuttle Bus
So my buddies confirmed...I own a new bus...we'll call this one Drgn Slayer...since my other bus Haus of Drgn died(transmission) and was sacrificed in trade and extra cash for this new project. Once they make it down from the Midwest this weekend I will get to physically see it and have an idea as to my next move. Here's a few pics. It's bigger, has a better engine. Here's some pics I was sent.
File Type: jpg 10595863_10152382992476647_451351002_n.jpg (104.6 KB, 1178 views)
File Type: jpg 10584504_10152382995101647_301534742_n.jpg (68.0 KB, 1165 views)
File Type: jpg 10590009_10152382995141647_474532051_n.jpg (58.5 KB, 1163 views)
"You're only given a little spark of madness. You mustn't lose it."
-Robin Williams
Drgnnite is offline   Reply With Quote
Old 08-08-2014, 03:44 PM   #2
Drgnnite's Avatar
Engine: 7.3L Diesel
Rated Cap: 25
Re: New Project 1996 Ford E-350 7.3L Shuttle Bus
And a couple more pics I was sent. And a shameless plug...If you would like to take a listen to my friends band here's a great link to GEARS http://www.reverbnation.com/gearsofficial
Feel free to take a listen.
-Robin Williams
Old 08-08-2014, 07:30 PM   #3
sdwarf36's Avatar
Coachwork: Champion
Chassis: Ford e-450
Engine: 7.3 Powerstroke
Wow! Such a big shortie! I'm jelous.
Old 08-08-2014, 10:54 PM   #4
Drgnnite's Avatar
Engine: 7.3L Diesel
Rated Cap: 25
Yah, at least they are very comfortable. I can't wait until it's in my side-yard and I can inspect it.
-Robin Williams
Old 08-11-2014, 09:24 PM   #5
Drgnnite's Avatar
Engine: 7.3L Diesel
Rated Cap: 25
Welp...my new to me bus arrived today from the long a$% trip back from Lexington, KY. Just some slight details to iron out, the front a/c needs to be recharged, the overhead cab a/c is not working( anyone have a wiring diagram for a 1996 Metrotrans w/ Trans Air control?). the wiring panel looks immaculate, found the relay, just need time to test it more...The roof a/c Coleman kept shutting off, easy fix, the extension cord it had wired in, was missing the ground portion of the prongs. So I replaced the cord, worked like a charm. Then I noticed someone had the brilliant idea of wiring in a HUGE inverter(5000W- 10,000Wmax) to the existing onboard batteries...in other words the main starting battery, and the little accessory one...Umm...that will have to be remedied, with at least 2 marine batteries. I also did a once over w/ the silicon to seal up most of the joints. And another funny thing the guys noticed was that there is a passenger seat, but no seat belt...at all. no hole to pass it through either, I'm assuming that the anchor points are still there, so I guess tomorrow we will take a trip to the junkyard. That's about it for now, will take some pictures in the AM, i had like 2 feet to spare in my side-yard...fit like a glove.
-Robin Williams
Old 08-11-2014, 09:40 PM   #6
sdwarf36's Avatar
Coachwork: Champion
Chassis: Ford e-450
If yours is like mine, the AC from the box mfg. is tapped into the stock Ford AC + run in series. There is a sticker on my dash stating the rear AC must be on for the front to work.
Old 08-11-2014, 11:25 PM   #7
Drgnnite's Avatar
Engine: 7.3L Diesel
Rated Cap: 25
Yeah, sorta like my last one, but this looks so much cleaner. I plan to play around w/ it tomorrow, didn't run for them at all, I got the outside fans run on the intercooler briefly when I trip the relay, so we'll see what happens.
-Robin Williams
Old 08-14-2014, 03:40 AM   #8
Drgnnite's Avatar
Engine: 7.3L Diesel
Rated Cap: 25
Yesterday I figured out the problem w/ the rear facing a/c. I noticed the overhead control panel was getting no power, so I followed in back under the hood, and the solenoid looked bad. So I jumped the solenoid and the power came back tot he panel, and the a/c kicked on. So after we dropped two cans of refrigerant into the system, it all began cooling( probably needs 1 more). The boys came by and changed the oil on it...crazy how much oil is used in diesel engines. Started adding some door speakers, and it started to rain. Hopefully I should be able to wrap up the other door then wire in a speaker selector switch for the outside and front speakers. Let's see what else...I have a lead on a decent dresser on Craigslist, it's in the area and free(best kind). I will follow up with some more pictures later in the morning after I get home from work. Night all.
-Robin Williams
Old 08-15-2014, 07:22 AM   #9
Coachwork: MertoTrans
Chassis: Ford E-SuperDuty
Engine: 460 Ford
Rated Cap: 4
Wow, another Metrotrans! I have a thread down the page. I have been fighting A/C problems and finally converted it to 1 compressor. How is yours set up? I bought a replacement solenoid on Amazon pretty cheap.
davidshelton is offline   Reply With Quote
Old 08-15-2014, 03:08 PM   #10
Drgnnite's Avatar
Engine: 7.3L Diesel
Rated Cap: 25
it was already a 1 compressor set up... phew! yah I got my solenoid locally at Advance Auto Parts... like $20. After I changed it , it started to working again.
-Robin Williams
My 1996 Ford E350 Goshen Coach Conversion Project Drgnnite Short-Bus Conversion Projects 54 11-17-2014 03:16 PM
My 1996 Ford E350 Goshen Coach Conversion Project Drgnnite Skoolie Conversion Projects 4 10-07-2013 11:43 PM
Ford E350 Shuttle Bus? GoldenGate Short-Bus Conversion Projects 8 04-05-2013 09:58 PM
New Project - 95 Shuttle Bus Robeebus Short-Bus Conversion Projects 16 05-06-2012 11:42 PM
93 E350 Shuttle Bus Project For sale in WI JonCBrand Classifieds | Buy, Sell, Swap 0 03-15-2012 10:34 AM
