Old 05-17-2010, 02:51 PM   #21
Year: 1982
Coachwork: Chevy
Chassis: P30
Engine: 350
Rated Cap: 21
Re: New shorty conversion! Road trip anyone?
Originally Posted by DarrenDriven
That is awesome... great blank canvas! Or is it a "black" canvas? Take photos as you convert it... its fun to watch these things progress from empty shells.
We got lucky with the basically primed paint job. Today, we will start painting it a silver aluminum with a compressed air spray gun. Later, I'm thinking of painting the stars and stripes on the roof. It's exciting!
-Drew
"Believe you can and you're halfway there."
SeatTaken is offline   Reply With Quote
Old 05-17-2010, 03:20 PM   #22
Year: 1982
Coachwork: Chevy
Chassis: P30
Engine: 350
Rated Cap: 21
Originally Posted by cincinnati_kid
Looks like a pretty nice neighborhood .............. So how do the neighbors like it haha
They actually love it. Many of my neighbors are defense department engineers and aircraft aircrew and many came out to take a look. They thought it was the coolest thing.
-Drew
Old 06-09-2010, 06:42 PM   #23
Year: 1982
Coachwork: Chevy
Chassis: P30
Engine: 350
Rated Cap: 21
It's been a while and we've been pretty busy with a 3-day pirate festival we had this past weekend called "Billy Bowlegs." It's a annual event where "pirates" "raid" the city on a pirate ship and come on shore and "take over the city" for a weekend. It involves plenty of rum, beads and "booty!" We Pirate themed the bus and it turned out awesome! Photos are below:
Since my last posting, I have painted the exterior Rustoleum aluminum silver, painted the bumpers gloss black, replaced the oil/oil filter, installed all new fuses and some wiring, installed a new 12v accessory socket in the dash for low power use, and some other little things. We just installed solar rope lighting on the inside also which is too neat. This week we are building the bench seats that convert into a 3-man bed behind both wheel wells in the rear.
I will try to keep you updated with new additions and photos! Virtually everyone in this town now knows the bus either from word-of-mouth or seeing us on the streets or at events. I don't think I've ever made a better decision in my life than to buy this bus!
More photos next post...
-Drew
Old 06-09-2010, 06:44 PM   #24
Year: 1982
Coachwork: Chevy
Chassis: P30
Engine: 350
Rated Cap: 21
-Drew
Old 06-10-2010, 10:44 AM   #25
Year: 1982
Coachwork: Chevy
Chassis: P30
Engine: 350
Rated Cap: 21
Originally Posted by Smitty
If you build it, they will come.................
Smitty
ETA: Close-up on the blonde next time please
Haha. Yeah, she's mine. I've made her the unofficial promoter of the bus.
-Drew
Old 06-10-2010, 11:19 AM   #26
sdwarf36's Avatar
Coachwork: Champion
Chassis: Ford e-450
Engine: 7.3 Powerstroke
I love the silver--make it look quite "industrial". If you ever have an airplane theme party-I'd decorate as a old Ford Tri-motor.
Old 06-15-2010, 03:07 PM   #27
Year: 1982
Coachwork: Chevy
Chassis: P30
Engine: 350
Rated Cap: 21
Bus seems to be running on 7 cylinders. There's always been a "knocking" present. How would I go about diagnosing the problem? Checking the compression of each cylinder, spark plugs? What else could be the problem?
Thanks!
-Drew
Old 06-15-2010, 08:02 PM   #28
Moderator
crazycal's Avatar
Engine: DT408, AT545
Rated Cap: 23 500 gvw
Is it gas. How long s ince a tune up. If you don't know, it's time. Start with plugs and wires. Might as well replace cap, rotor, fuel filter and air filter. If it still misses, then do a compression check. I've only rebuilt two engines, both were small block chevys. One had a cam lobe that was toast. I was surprised it still ran OK.
I'm hungry!
You Gotta Let Me Fly
Old 06-15-2010, 08:14 PM   #29
jkindt's Avatar
Year: 1981
Chassis: Ford B-600
Engine: Ford 370 Propane
Rated Cap: 48
Don't forget the ignition timing! If you don't have a timing light, beg, steal, borrow, or rent one. Your engine won't run efficiently with the timing set wrong.
Old 06-15-2010, 08:30 PM   #30
Moderator
crazycal's Avatar
You're right, but can you set timing on electronic ignition?
I'm hungry!
Old 06-15-2010, 08:49 PM   #31
jkindt's Avatar
Year: 1981
Chassis: Ford B-600
Rated Cap: 48
It's a 1982, should have a standard GM HEI distributor in it.
Old 06-22-2010, 06:10 PM   #32
Year: 1982
Coachwork: Chevy
Chassis: P30
Engine: 350
Rated Cap: 21
Thanks for the advice. I will try to find a timing light. It has gas and I don't think it has anything to do with getting fuel through the engine.
Another question. The ignition that we rewired has an issue. I'm not able to turn the bus off with the key. I have to take out the wire the provides power to cut it. What's the possible problems here? All the ignition cluster wires are connected to all available terminals. Ideas?
And one more thing...exhaust issue that I found while under the bus. Look at the photo below and tell me if this is really an issue. There's a pipe segment just sitting in the muffler. I don't know what happened here. It had to have been like that before I bought it.
-Drew
Old 06-22-2010, 08:12 PM   #33
Moderator
crazycal's Avatar
This isn't a problem at all if you don't care about dying from CO poisoning. I would get that muffler replaced pretty quick. It can't cost that much.
I'm hungry!
Old 06-22-2010, 11:43 PM   #34
Year: 1982
Coachwork: Chevy
Chassis: P30
Engine: 350
Rated Cap: 21
It's very close to the back left of the bus so I can't see much gas getting through the flooring and into the interior. But I will get to it eventually.
Any advice on the ignition?
-Drew
Old 06-23-2010, 09:55 AM   #35
Stuff's Avatar
a backfire could have caused that. have a 73 ford that i put a new muffler on and went to get gas. started truck and KA-POW and i blew the new muffler to pieces....
Old 06-24-2010, 10:21 PM   #36
Year: 1982
Coachwork: Chevy
Chassis: P30
Engine: 350
Rated Cap: 21
You said you re-wired it...but it's not killing the power to the ignition once the key is switched to the off position. Re-check your work.
Smitty
I only rewired it to where the wires were before I bought the bus. It has never been able to turn-off with a turn of the key. Is there a standard diagram that I could go off of? I can't find anything.
-Drew
Old 06-26-2010, 11:32 PM   #37
Year: 1982
Coachwork: Chevy
Chassis: P30
Engine: 350
Rated Cap: 21
Thanks for sending the manual.
Would anyone perhaps know where to find a gauge unit for my P30? I have all the panels and mounts for the gauges and the gauge wires are getting power, but I just don't have any gauges. I don't have my hopes up for finding one, and I don't really need all the gauges except for the fuel level gauge...I would like to know my fuel level instead of carrying around a gas can everywhere we go. Are there universal gauges that would work on my bus?
-Drew
Road trip travel ADVICE NEEDED! Loubnat Titles, Insurance, Registration and Money Matters 1 09-25-2014 10:43 AM
New Member, New Tour Bus and First 2000+ mile road trip... EinHack Short-Bus Conversion Projects 2 01-08-2010 03:49 PM
Road trip from hell... Russell Everything Else | General Skoolie Discussions 1 09-13-2009 01:34 PM
Bus road trip Xtevan Conversion General Discussions 5 12-11-2007 01:47 PM
how about a travel, road trip section. wmah Forum Admin | Account Help | Suggestion Box 1 09-06-2007 09:16 AM
