Old 06-15-2010, 08:49 PM   #31
jkindt's Avatar
Year: 1981
Chassis: Ford B-600
Engine: Ford 370 Propane
Rated Cap: 48
Re: New shorty conversion! Road trip anyone?
Originally Posted by crazycal
You're right, but can you set timing on electronic ignition?
It's a 1982, should have a standard GM HEI distributor in it.
Old 06-22-2010, 06:10 PM   #32
Year: 1982
Coachwork: Chevy
Chassis: P30
Engine: 350
Rated Cap: 21
Thanks for the advice. I will try to find a timing light. It has gas and I don't think it has anything to do with getting fuel through the engine.
Another question. The ignition that we rewired has an issue. I'm not able to turn the bus off with the key. I have to take out the wire the provides power to cut it. What's the possible problems here? All the ignition cluster wires are connected to all available terminals. Ideas?
And one more thing...exhaust issue that I found while under the bus. Look at the photo below and tell me if this is really an issue. There's a pipe segment just sitting in the muffler. I don't know what happened here. It had to have been like that before I bought it.
-Drew
"Believe you can and you're halfway there."
SeatTaken is offline   Reply With Quote
Old 06-22-2010, 08:12 PM   #33
crazycal's Avatar
This isn't a problem at all if you don't care about dying from CO poisoning. I would get that muffler replaced pretty quick. It can't cost that much.
I'm hungry!
You Gotta Let Me Fly
Old 06-22-2010, 11:43 PM   #34
Year: 1982
Coachwork: Chevy
Chassis: P30
Engine: 350
Rated Cap: 21
It's very close to the back left of the bus so I can't see much gas getting through the flooring and into the interior. But I will get to it eventually.
Any advice on the ignition?
-Drew
Old 06-23-2010, 09:55 AM   #35
Stuff's Avatar
Coachwork: Goshen
Engine: 7.3
Rated Cap: 25
a backfire could have caused that. have a 73 ford that i put a new muffler on and went to get gas. started truck and KA-POW and i blew the new muffler to pieces....
Old 06-24-2010, 10:21 PM   #36
Year: 1982
Coachwork: Chevy
Chassis: P30
Engine: 350
Rated Cap: 21
Originally Posted by Smitty
You said you re-wired it...but it's not killing the power to the ignition once the key is switched to the off position. Re-check your work.
Smitty
I only rewired it to where the wires were before I bought the bus. It has never been able to turn-off with a turn of the key. Is there a standard diagram that I could go off of? I can't find anything.
-Drew
Old 06-26-2010, 11:32 PM   #37
Year: 1982
Coachwork: Chevy
Chassis: P30
Engine: 350
Rated Cap: 21
Thanks for sending the manual.
Would anyone perhaps know where to find a gauge unit for my P30? I have all the panels and mounts for the gauges and the gauge wires are getting power, but I just don't have any gauges. I don't have my hopes up for finding one, and I don't really need all the gauges except for the fuel level gauge...I would like to know my fuel level instead of carrying around a gas can everywhere we go. Are there universal gauges that would work on my bus?
-Drew
Road trip travel ADVICE NEEDED! Loubnat Titles, Insurance, Registration and Money Matters 1 09-25-2014 10:43 AM
New Member, New Tour Bus and First 2000+ mile road trip... EinHack Short-Bus Conversion Projects 2 01-08-2010 03:49 PM
Road trip from hell... Russell Everything Else | General Skoolie Discussions 1 09-13-2009 01:34 PM
Bus road trip Xtevan Conversion General Discussions 5 12-11-2007 01:47 PM
how about a travel, road trip section. wmah Forum Admin | Account Help | Suggestion Box 1 09-06-2007 09:16 AM
