Old 06-02-2018, 01:41 PM   #1
Newbie Here Questions on Cutaways
I stepped inside two 4 window short buses that were built for small churches. Both buses were single rear wheel. I found that my head brushed the roof. I am only 5'4" tall. Is the shorter height due to these buses being single rear wheel, or a cutaway, or the manufacturer. One bus was about 1" taller inside. This type of bus would not leave any room to install a wood ceiling.
So, do I need to look for dual wheeled cutaway buses to find that heigth inside? I want a 5-6 window bus.
Thanks for any info
Karen
KarenSkeet73 is offline   Reply With Quote
Old 06-02-2018, 02:01 PM   #2
What kind of buses were they? I don't know any that have a shorter than 6'3" ceiling height. No one would build a bus with a 5'4" ceiling height.
Old 06-02-2018, 02:30 PM   #3
I suspect that at SRW bus could be built shorter in order to save a bit of weight.
There was a daycare near where I lived that ran SRW 4 window cut aways that I pulled up next to at a stoplight while driving an E450 (DRW) 5 window Thomas. I didn't get out and measure but my best guess is that they were 10-14" shorter than the Thomas.
Every cut away that I have been inside has had around 6' of headroom. I think that is most common.
Personally, I would shy away from 3/4 or 1 ton chassis for a conversion. I prefer not pushing the load capacity to its limits.
Old 06-02-2018, 03:33 PM   #4
Short Bus
I believe these were day care vehicles. I do need to do more research on the chassis to handle what I want, thanks guys.
Old 06-02-2018, 03:34 PM   #5
bus
these had to be day care. ONe was a Collins and another was Girardin.
Old 06-02-2018, 09:00 PM   #6
The MBTA in Boston has a whole fleet of these Ford-based 4-wheel vans for disabled point-to-point travel. There are double doors on the right rear with a wheelchair lift.
They're fairly short, they look very easy to drive, and they'll fit in a normal parking space.
https://www.showbus.com/gallery/fore...a/bostont2.htm
If I was building a "stealth" van camper for myself, I'd totally look at one, assuming I could find one with reasonable miles that wasn't about to rust in half. (I'd have better luck finding a unicorn that farts rainbows.)
Old 06-02-2018, 11:57 PM   #7
Thomas1985's Avatar
Chassis: GMC G3500 Vandura
Engine: V-8 5.7L Gas
Mine was 6 ft which is why I raised it. Most are between 6 and 6 ft 6. The single rear wheels are often even shorter like vans.
- Thomas
The Daily Driver Bus Build
Thomas1985 is offline   Reply With Quote
Old 06-03-2018, 06:39 AM   #8
Year: 2010
Coachwork: Coach & Equipment MFG
Chassis: ford E350 superduty
Engine: 5.4 liter v8
Rated Cap: 7 passenger
my SRW e350 has about 6'1"+ headroom
2010 ford e350 superduty v8 7 passenger bus
pbeggs is offline   Reply With Quote
