Old 05-07-2012, 06:26 PM   #11
Re: newbie - ICE CREAM truck
Originally Posted by docbdj
any way to mount / vent the generator safely so not visible
? under vehicle or inside and vent to outside - safely?
Biggest thing is to get exhaust away from any way for it to get inside,so you need a 100% sealed exhaust venting away from any vent that could let it inside,even if wind shifts.exhaust is not something you ever play with.
With enuf money or ingenuity(s/p) anything can be hidden.
Just make sure the exhaust can't be recirculated.
A pipe with a heat sheid painted like a straw would fit your "theme"
Just remeber safety first.
Raw Propane is heavier than air,so it settles,don't have it settle into an "enclosed" area where a spark froma leaky fitting could cause an explosion...that would be bad
Old 06-04-2012, 07:47 AM   #12
SDJunkMan's Avatar
Year: 1939
Coachwork: Union City?
Engine: 95hp Flathead
Ice Cream is considered a "hazardous food".
That depends on if you are serving soft serve, or dipped ice cream or pre packaged ice cream "treats". Many of the rules that apply to soft serve and dipped ice cream do not apply as "treats" are considered single serve. In South Dakota you are not required to have sinks, serve safe, a commissary or any other special accomadations if you are only serving single serve items.
As for a serving window, a metal fabrication shop can make one up for you, or you can do like many vendors do, and just install a sliding aluminum household type window, although you would want to replace the glass with tempered glass or plexiglass.
Jeff
1939 Ford Skoolie
1947 Flxible Clipper
SDJunkMan is offline   Reply With Quote
wiring my box truck conversionFUN Alternative Fuels | Electric, Propane, Wood Gasification, etc. 4 09-04-2014 08:23 AM
Off topic Big big truck frank-id Everything Else | General Skoolie Discussions 2 03-22-2013 07:33 PM
Bus as tow truck? stonestatue Conversion General Discussions 5 11-01-2012 12:58 PM
newbie looking at 1984 Ford E350 short bus-ice cream truck crazycal Short-Bus Conversion Projects 5 09-23-2010 02:04 PM
Towing a 4x4 truck (small truck) 4 down Abbott Everything Else | General Skoolie Discussions 13 12-31-2009 02:05 AM
