Old 10-03-2019, 06:25 AM   #1
Question Newbie questions
I'll try to keep this brief, and not be annoying. I just began researching bus conversions this week as I'm quite serious about relocating back to the US in April 2020. I'm drawn to the shorter school buses for two reasons. 1. I'm a single guy living alone, so I don't need much space and 2. I think it would be MUCH easier to drive a 18 - 22 passenger bus around (both short and long trips) than a 72 passenger, or city bus.
For now, Just one basic questions, and again, apologies if this is annoying or redundant. I'm not a mechanic, or a bus aficionado, and I just want to know if there are certain manufacturers, or drive trains, or configurations that I should absolutely avoid when shopping for a bus. Also, if there are any profound changes at certain times that would make, say, a 90's bus much less desirable than an early 2000's bus.
Thanks in advance for any consideration. If this is in some way an inappropriate question, I apologize in advance, and please direct me to any preferable forum topic, or even other site.
Jon
Beachvbguy is offline   Reply With Quote
Old 10-03-2019, 06:46 AM   #2
farok's Avatar
Engine: 6.0L Gasser
There are a number of threads about the issues with diesel vehicles from 2004 and newer. I'd suggest staying away from them unless you know what you're getting into. 2003 and older diesels don't have all the new emissions garbage. For gas engines, this doesn't apply.
For a short bus, you'll get differing opinions on the Allison 545 transmission, which from what I understand is common on these. It doesn't have lock-up in 4th gear, but many have reported in the smaller buses that this isn't as critical as the larger ones. There's lots of threads on the 545 vs 643 and other transmissions as well.
Hope this helps start you on your journey!
Chris
My build thread: http://www.skoolie.net/forums/f27/fi...ild-25804.html
farok is offline   Reply With Quote
Old 10-03-2019, 08:52 AM   #3
If you're doing a lot of driving I'd hold out for a bus with o/d transmission and lock-up converter. better mpg and less wear on the engine!
My 2002 has anti-lock brakes -- being a full size bus that will mostly be empty (till a build plan develops), this is a good feature for me.
Pre-2004 avoids newer emissions add-ons... After 201* the emission designs are better integrated into the mechanical package rather than an engineering afterthought...
Old 10-03-2019, 11:20 AM   #4
Just start reading everything in this forum, your answers are here.
Old 10-03-2019, 12:45 PM   #5
Chassis: G30
Engine: 350 Chevy
Rated Cap: 10K
X2 on that...^
Welcome to the site, by the way!
Lurking or simply just reading old threads on builds, powerplants, you name it, are invaluable in learning from others on what works and what might work with hefty amounts of $$ thrown at it.
Making the best for you decision on just the right bus the first time, is good for morale throughout the build out process. You really don't want to spend $3,000+ on a bus with underlying rust issues or mechanical issues only to find out remedial works will bankrupt you before you even get to converting it to your liking.
Good luck on your research and ultimate decision on getting into the hobby.
