Old 03-26-2017, 03:47 PM   #171
Originally Posted by yellowxj View Post
High of 82 today + 40 mile drive to mother in laws. Lets see if 5000 btu's can keep us cool driving.
We will build a better hold down for the generator and a fake dog house to cover it. That way when we Dismount it from the rack at the campgrounds and move it away from the bus we will put the dog house over it to help Shield the noise
Jeep, bus, repeat.
what is the white box by your tail light? looks maybe trailer light plug?, and also what king of generator is that?, and how well does it work?
thank you
Old 03-26-2017, 05:45 PM   #172
yellowxj's Avatar
The white box houses the outlet that the generator plugs into. We have a 25' extension cord so we can dismount the generator when we camp. The generator is a 2kw one from sam's club. Works great with the walmart ac.
Jeep, bus, repeat.
yellowxj is offline   Reply With Quote
Old 03-26-2017, 05:55 PM   #173
Jeep, bus, repeat.
sound great, tks
Old 03-26-2017, 05:57 PM   #174
yellowxj's Avatar
The outlet in the white box goes only to a 2 gang outlet box inside. Basically an extension cord for the generator but passes for 110 power to get our motor home qualification
Jeep, bus, repeat.
Old 03-26-2017, 06:04 PM   #175
Love the Red rack... thats gonna look rad on top!!
howd your 5k do on the road yesterday?
Old 03-26-2017, 06:12 PM   #176
yellowxj's Avatar
It did ok but we'll need better for june heat out west. Will be putting in evap and ac soon i think.
Jeep, bus, repeat.
Old 03-26-2017, 06:28 PM   #177
Jeep, bus, repeat.
hint: when you do it, remember to install the wierd mesh screen on the evaporator if it has it... it isnt a filter, but when the blower speed is on high it keeps the evaporator from slinging water into the heater duct and dripping on the floor...
and replace the blower motor while everything is apart..
Old 03-29-2017, 06:19 PM   #178
yellowxj's Avatar
Well that was a whole lot easier than I thought it was going to be. I'm headed to the junkyard Saturday morning to get my replacement evaporator, condenser, hoses compressor, and brackets.
Jeep, bus, repeat.
Old 04-04-2017, 08:00 AM   #179
yellowxj's Avatar
Got it all apart last night. My hydroboost brake system apparently used a different style ac compressor bracket than the vacuum booster system I got the brackets from. I'm going to be making some modifications.
Sent from my VS986 using Tapatalk
Old 04-04-2017, 08:27 AM   #180
what year is your van? there were 2 different compressors used on those depending on engine and packages..
the R-4 compressor (the little pancake one).. (the awful compressor). was used in most of the 80s.. but some of the early 80s stuff still got the good A-6 (frigidaire.. long skinny compressor)..
your best bet is to get a Sanden bracket for a 350 and put a Sanden 508 in there.
the hydroboost if I remember used a different power steering pump .. the standard 350 configuration has the A/C on the driver side but somehow I seem to remember the hydroboost had it on the passenger side.. I know the later modell 350s had moved it to the passenger side. but I Believe that happened only after they went SERP .
