Old 03-31-2019, 11:48 PM   #1
Payload and build weight
So I know that the curb weight and gvwr for the cutaway chassis donít leave much payload capacity for a build, maybe 4-8 thousand lbs? Is that plenty for a full time boondocking build? How much does your build come to weight wise? I can calculate the weight of water tanks and guess at some accessories I may end up with, but before I start making spreadsheets, Iíd just like to get rough estimates of what yíalls builds weigh when dry (empty water and auxiliary fuel tanks)thx!
Tawdbb is offline   Reply With Quote
Old 04-01-2019, 07:03 AM   #2
Coachwork: Startrans
Engine: 5.4 litre
Rated Cap: 12
4-8 thousand lbs. is a lot. I don't see a problem.
Old 04-01-2019, 11:11 AM   #3
That 8000#s you talk about would be equivalent to 90 wet third graders. How long is your bus? Is it actually a cutaway as in van cab with bus tacked on back or is it a dog nose on a heavy duty truck frame? What is the GVW and the CGVW per the factory? What does the bus actually weigh? Even 4000#s is a lot of stuff. As an example My bus is 22' long and is a dog nose. It is fully self contained and weighs in at 9,820#s. Empty (before build out and without the school bus body) it weighed 5,860 #s. It's GVW is 12,000 #s, CGVW 18,000#s. So my complete build out including the body is only 3,960 #s.
Old 04-01-2019, 02:39 PM   #4
I pulled the payload #ís from a website and Iím not sure it includes the bus body or not. I donít have a bus yet, Iím shopping. It seems like 3-4000# is pretty standard payload for a cutaway bus from what Iíve seen on otherís busses. Given the dry weight close to 4000# of your build, that would be much too close for comfort the the max GVWR of most cutaways
Old 04-01-2019, 06:11 PM   #5
zelseman's Avatar
Engine: 6.5L Turbo
We have a 4 window cab and chassis and the rated GVWR is 10,000# After our build, water, fuel, wood build out, 4 bikes, 3 solar panels, 2 kayaks, we weighed around 9500#. Our GVWR is with load D tires and we run load E tires. We didn't really exercise much caution to weight when we built and we feel pretty good driving down the road.
Okienomads 2000 Chevy Short Bus
Website
Instagram
Married couple full-timing in the American West-April 2018
zelseman is offline   Reply With Quote
