Old 05-09-2017, 08:07 PM   #1
Coachwork: Huh?
Please post mid bus and shorts floorplans
Hi I just bought a 6 window bus and I can't figure out how to do a layout. Would you mind posting your floor plans here? Thanks a bunch
heeranyi is offline   Reply With Quote
Old 05-11-2017, 10:03 AM   #2
Coachwork: GMC
Engine: Detroit 8.2L Diesel
Rated Cap: 53
Ours is a work in progress, and the wheel wells are only two to deal with. We are putting a bunk over ours, and the kitchen counter over the other one. Use photo shop. You can work in many layers, that way you can even do the underpinning area for storage. We have three layers to our plan, with the above shelving and cabinetry laid out as well.
Zombiepatrol is offline   Reply With Quote
Old 05-11-2017, 10:11 AM   #3
brokedown's Avatar
Floorplans for shorties can be pretty tough. I know that mine was only usable as a rough estimate, and once things started going in we ended up moving things around for practical reasons... But then, I'm a novice.
Old 05-11-2017, 10:34 AM   #4
Coachwork: GMC
Rated Cap: 53
Ours is a midsize so we have a bit more space to work with. The fuel tank is located under the work area, and everything was sort of planned around that. Plus, our underpinning space is all in the rear area, so it made sense to plan for our water tanks to go under there for gray water and all of the plumbing would be in one location.
Old 05-11-2017, 10:54 AM   #5
Coachwork: Huh?
Maybe it's too much for midbus
I drew a sketch on a piece of paper and when I showed it to my husband, he chuckled because I'm trying to lay it out like it's a 40 footer. I think it's only a 26 footer. At this rate, I'll have to put the toilet on top of the refrigerator. I'm going to have to get more realistic. I'm picking the bus up on Monday so I'll be able to tape stuff out and get a better idea.
Old 05-11-2017, 11:37 AM   #6
Coachwork: GMC
Rated Cap: 53
The tape definitely helped for us. I quickly had to discard my sketch after that. Having a grid that goes down to the inch like in photo shop is extremely helpful.
Old 08-29-2017, 04:19 AM   #7
6 Window Bus Floor Plan
Here's our floorplan!
Post 8: New Floor Plan
karlimh is offline   Reply With Quote
Old 08-29-2017, 12:34 PM   #8
Coachwork: Huh?
Hi, in this plan where do people eat?
Old 08-29-2017, 01:42 PM   #9
Where do people eat
The plan is between the sink and the bed there will be a table that folds up and down. There will be a bench that perfectly fits in the space. You can either eat at that table or you can use the bench as a coffee table infront of the couch to eat.
